Results 1 to 19 of 19
    Active Member Four Rings 00s4slvr's Avatar
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Grinding Sound!?!?
    so when i start my car in the morning or if its been sitting for about 5 hours or so and its the first time im starting the car it makes this LOUD grinding noise, and after about a min or two it goes away and the car drives fine...
    anyone know what it is?
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: Grinding Sound!?!?
    throwout bearing? just a guess. i know when cold a bad one will make noise. try engaging the clutch when u hear it and see if it goes away.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Quote Originally Posted by ThirdStrike View Post
    i have an auto tip and dont have a clutch
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by 00s4slvr View Post
    oops i knew that
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    oops i knew that
    lol no biggie. just wanna fix this noise its really annoying...
    Active Member Two Rings quattroSD's Avatar
    Nov 03 2007
    B5 S4
    San Diego
    when's the last time belts were replaced?
    early morning startup (or restarting after its been sitting awhile) can sometimes cause belts (if worn) to slip on the rollers and the pulleys get a bit noisy as well.
    This sound is more of a "whiney grinding" though.
    After the belt(s) warms up a bit, it seats itself properly on the rollers and the slipping stops.
    Check the integrity of the belts first...
    The fact that it's happening on cold start doesn't seem coincidental.
    C. Murphy
    Drive Fast, Take Chances
    Deactivated Four Rings
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Is it RPM dependent? In other words, does the noise increase as the RPMs increase?
    Edit: Nevermind, re-read it, its not when you're moving.
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Dude (read: The OP), do you EVER search? And I know if you say "yes" your lying out your bottom.
    Registered Member Two Rings
    Aug 18 2008
    Wrong Island
    id say timming belt or starter... my 2cents
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    CRAP the timing belt. i have been driving around with that noise for about 10000 miles. I was planning on getting the belt replaced around 85k...
    Jun 14 2007
    2000 S4
    Connecticut
    check your PMs.
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    Grinding? you sure. Can you describe the sound a bit more. The only noise TIP drivers really complain about are when the 2ndry air injection pump is going bad it makes a noise on start up and then goes away after a while. My car does this.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Jan 29 2007
    08 S4 00 S4
    MD
    Tip-secondary air pump maybe?
    08 S4- Stock SOLD
    Senior Member Two Rings sti4now's Avatar
    Oct 21 2008
    Turbo M3
    NC
    starter maybe?
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    yeah i ahve a tip and someone told me about that secondery air pump. It sounds like one of the fans is hitting something like a high pitch grinding sound. like ZZZZZNNGGGGGGGG LOL i cant describe it lol. Il take a video of it tomorrow and post it.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    thats what i have only when the car is really cold otherwise it starts up no problem. (usually only on the morning start up it will do this for a little and then go away.)
    May 06 2004
    W124s
    PA
    sec air pump sounds most likely... Maybe the serpentine belt tensioner? if you can rev the engine and the noise stays constant i'd bet on the sec air pump..
    Keep right pass left, it's the law!!
    Feb 09 2006
    Huntington Beach
    yeah its your 2ndry pump guaranteed!!!! nothing to worrie about right now.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    here is the video i took of the startup noise...
    http://www.youtube.com/watch?v=udf1OvFIr6k
