Results 1 to 4 of 4
    Registered Member Two Rings
    Sep 20 2008
    colorado
    anyone know how long the hazard lights flash after the the OEM Alarm is triggered?
    so i was adding a shock sensor to the factory alarm last night and everything worked. i have the sensor trigger the hood pin wire and it set off the alarm. lights flash, horn beep for about one minute then turned off but the lights keep flashing. i waited for about another 3 to 4 minutes but the lights were still flashing. anyone know how long the lights are suppose to flash after an alarm trigger? i wanted to wait and see how long there would flash but afraid of draining the battery.
    Established Member Two Rings dmott11's Avatar
    Jan 28 2008
    MA.USA
    Re: anyone know how long the hazard lights flash after the the OEM Alarm is triggered
    I cant give you the exact amount of time that they stay on,Maybe 5 to 10 minutes, but it certainly isnt enough to kill your battery.
    "slow is smooth and smooth is fast"
    Senior Member Three Rings ColinGruenfeld's Avatar
    Oct 24 2006
    Stage III Tiptronic B5 S4
    Colorado
    If you're good with that kind of stuff you should electrify the door handles and post a write-up on it. I'd even pay you for the write-up!
    Audacity - The Nogaro 2000 S4
    STAGE 3 PJ K04's + IPT Tranny/TC + This and that
    Full Stage III TIPTRONIC
    Sep 20 2008
    colorado
    Quote Originally Posted by ColinGruenfeld View Post
