Results 1 to 3 of 3
    Senior Member Two Rings GermanAudi's Avatar
    Jun 01 2008
    2003 Audi A4 1.8T Multitronic
    San Diego, CA
    Vibration at certain RPM
    Does anyone feel a slight vibration at idle when the engine is revving at around 700 RPM? It seems like it goes away whenever it idles at 900-1000 RPM.
    I have a CVT and I read from somewhere that the transmission just does that. Is this true? Or is it a motor mount problem?
    2003 1.8T Multitronic CVT, Canvas Beige Metallic
    GIAC Stage 1 || 710N TT Diverter Valve || 6000K Xenon HIDs || VMR Vent Boost Gauge || Eibach Pro/Bilstein Sport Suspension
    Established Member Two Rings sloweryucf's Avatar
    Feb 21 2008
    2003 A4 1.8T (sport package)
    Orlando, FL
    Re: Vibration at certain RPM
    I have new motor mounts and it's still there. Must be a vacuum leak. Gonna built a tester this weekend and try it out.
    GO KNIGHTS!
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    Vacuum leak would most likely make your car misfire.
    Could be the engine mounts, see if u can see any unusual fluid around them.
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
