    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    Cheap RS4 reps on ebay...
    I dont know the company but this add is for a set of 4 just thought id pass what i saw on..
    http://cgi.ebay.com/ebaymotors/17-AU...ayphotohosting
    Or
    http://cgi.ebay.com/ebaymotors/18-B7...Q5fAccessories
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Re: Cheap RS4 reps on ebay...
    those are probably another low quality rep, I say dont buy- dont consider buying...
    Senior Member Three Rings fromGMCtoAUDI's Avatar
    Feb 03 2008
    '08 audi A4 2.0T
    alexandria, VA
    These reps don't look as good as the VMRs. The spokes are wider and shorter, the center is bigger and there is less curve than the VMR ones.
    Jan 27 2007
    NC
    I wasnt buying just posting incase they were good quality and someone needed them. Im deffinately not traying to step on toes by posting them.
    vizi
    Registered Member Two Rings b7ftw's Avatar
    Aug 06 2008
    2005.5 B7 A4 2.0t 6MT
    Phoenix, AZ (Tukee)
    wow, they really know what they are taling about...
    17x7.5 w/ 35 offset fits a b7? :p
    18x8 w/ 225/45/R17 tires.....
    i want to meet the genius that thought of putting a 17" tire on a 18" wheel...
    GIAC-X 91 / EVOMS Intake / APR Exhaust / ATP Testpipe / AWE Intercooler / Stage 2 South Bend Clutch Kit / VMR 710 GM / Neuspeed Springs (coils soon) / Depo Projectors w. MTECs / Reiger roof wing / JPUSA rear lip / debadged / Tint
