Results 1 to 14 of 14
    Senior Member Two Rings 97ss10's Avatar
    Jul 24 2008
    2003 A4 Quattro 3.0 / 2005 Nissan Frontier NISMO
    Louisiana
    Can you make the alarm honk instead of beep?
    Simple question...can you make the alarm, when triggered, honk the horn instead of beeping. I want something that will wake me up in the middle of the night if somebody's trying to jack my stuff (not that I live in that bad of a neighborhood) and a little chirping is not going to do that. I noticed that my horn doesn't even work if the car's not running so I'm doubting that it can be done with the stock system but I'm new to this so I figured I'd give it a shot. Thanks a lot!
    2003 A4 3.0L Quattro
    1998 Camaro SS 6spd
    2005 Frontier CC Nismo
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: Can you make the alarm honk instead of beep?
    Yes, take the car to a stereo/alarm shop and they can do it for you...
    Basically they will tap into the signal for the alarm horn into the trunk, add a relay that will trigger a second horn that does not beep, but rather makes real noise.
    Veteran Member Three Rings b6a4's Avatar
    Oct 09 2006
    Asheville, NC
    mine is quite now. how can i make it beep again. after I VAG'd it it got silent.
    __________________________________________________ __________________________________________________ ____________________
    2001 Audi S4 Avant. Black/Blue Sport. SRM K24 Hybrids. (Totaled)
    2017 Audi Q7 3.0T
    2010 Audi Q7 TDI(sold)
    Veteran Member Four Rings A4TUNE's Avatar
    Sep 14 2006
    Mass
    what the hell is with that stupid alarm anyway?
    -Max
    2004 A4 1.8T M6 Quattro Ultrasport
    REVO Stage 1 | AWE Boost Gauge | Carbonio CAI | Valeo Single Xenon Black Ecodes | RS4 Rear Sway Bar | 18x8 OZ Superleggera | DTH USP Splitter
    Dec 06 2007
    it will start honking in 30 seconds, if someone punches out th window in ur car or something it'll be loud.
    -Kirk
    BetaAlphaTau Member #58
    Jul 24 2008
    Louisiana
    So if you press the panic button, while some bastard is beating you down and robbing you, the horn starts honking after 30 seconds? Now that would be an insult after you're laying on the ground and the guy runs off then your car starts honking at you.
    1998 Camaro SS 6spd
    Jul 24 2008
    Louisiana
    So something has to happen to the car to make it start honking? I pressed the panic button today and it just beeped, never started honking.
    1998 Camaro SS 6spd
    Senior Member Three Rings khmerguy978's Avatar
    Sep 14 2008
    B8 A4 Prestige
    Boston, MA
    i swear that beep is meant to attract killer dogs to come rescue us. what other reason would they make it have it beep like that?!
    cheers... rocco
    B8 A4 Prestige
    Wrangler Sport
    CBR600RR
    Prelude
    Jul 24 2008
    Louisiana
    Maybe it's so everyone will stop and look around to make sure there's not a vehicle about to back over them then they'll see the panicked Audi driver kicking his/her car because it's not honking.
    1998 Camaro SS 6spd
    Veteran Member Three Rings pa4ul's Avatar
    Mar 20 2008
    03 Audi A4 1.8T/ 72 Ford F-100
    south
    yea i found it strange that the horn dosent work when the car is not turned on
    Joooe Mamma!
    Senior Member Three Rings ThreePointOhh's Avatar
    Dec 24 2007
    |2004 A4 3.0Q 6SPD MT|
    New York, NY
    Quote Originally Posted by pa4ul View Post
    X2... major fail!
    ** I'm Gonna Drive it Till the Rings Fall OFF!! **
    Veteran Member Three Rings AudiBama's Avatar
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    audi's suck at making sounds other than vrrooooooom pshhh
    2003 A4 1.8T
    APR K04, APR Snub Mount, Forge 008 DV, Custom Magnaflow Exhaust, 034 Motorsport Catless Downpipe, K&N, VHT, Hitachi "e" Style Coilpacks, 6000k HIDs, CC Mod, Neuspeed Race Springs, Bilstein, Southbend Stage 2 Endurance Clutch, Lightweight Flywheel, Valentine 1, Driver Mod.
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    A lot of cars are like this.
    Jul 24 2008
    Louisiana
    I thought it was odd also that the headlights don't work unless the car is on?
    1998 Camaro SS 6spd
