Results 1 to 15 of 15
    Nov 11 2008
    skokkie
    Can i get away with changing break pads without resurfacing the rotors?
    My breaks are getting squeaky so i got me front and back break pads but i have a question im at 84k miles on stock rotors, can i get away with just changing the break pads? b\c everywhere i go they want to charge me 300 extra just for resurfacing my rotors is it even that necessary?
    Dec 05 2007
    Re: Can i get away with changing break pads without resurfacing the rotors?
    It is recommended to change pads and rotors at the same time because they have already created thier own contact surface area over time. You can always just place pads if you want, but be prepared to have uneven wear on the pads.
    There is a member on this forum board whom runs ebay rotors with absolutely no issues. I can not recall whom though. Just something to consider.
    Oct 25 2006
    '98.5 A4 1.8tqm Sport, '01 MDX
    Oxford, CT
    Something is very wrong here.
    I just bought rotors and pads for the rear of my car for less than $100...An additional $300 to resurface the rotors is robbery. Parts stores, if they even offer the service anymore, usually charge like $10-$20 per rotor to turn them. A lot of places don't even do it as the rotors become cheaper and cheaper...
    New brake pads on original equipment, 84,000 mile rotors is a bit of a stretch...They might last 6 months...
    Established Member Two Rings dmott11's Avatar
    Jan 28 2008
    MA.USA
    yeah thats not right. 300 to resurface? youde better be getting alittle sucky sucky on the side for that.
    "slow is smooth and smooth is fast"
    Senior Member Three Rings Spykce's Avatar
    Aug 06 2008
    Indiana
    You can buy new rotors and pads, good ones, for less than $300.
    Also I am running rotors from Autozone on the rear without any issues so far. However I plan upgrade at some point.
    Rotors: http://www.germanautoparts.com/Audi/A4/Brake/72/1
    Pads (Facelift): http://www.germanautoparts.com/Audi/A4/Brake/153/2
    Current Car: 2000 A4 1.8TQ Frankenturbo Build | 2012 Passat TDI
    History: C6 A6 4.2, B7 S4, Mk V GTI, Mk IV GTI Vr6, Audi 80, Audi 4000 Q, B5 A4 1.8TQ x 5, B5 A4 V6, Mk II Cabriolet x 4, B5 Passat 1.8T, Mk II Scirocco, Audi TT 1.8TQ, Mk III GTI Vr6, C5 Allroad 2.7T x 3, '86 VW Quantum Wagon
    Veteran Member Three Rings dingguhlbary's Avatar
    Jul 17 2007
    New Jerzzzzzzzzzzzzzzzzzzzzzzz
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    just brakes offers a special for 99.95 for front and rear pads and resurface all rotors. im sure "import/exotic" audi is more expensive but definetly wont be 300 bucks just for resurface. if you have a spare vehicle, do the pads yourself, and just take off the rotors and take them to a tire shop or brake shop and have them resurface them off the car. should be even cheaper seeing as how you already have pads and wouldnt be paying for install labor.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Veteran Member Four Rings ryannorthcott's Avatar
    Jul 10 2008
    2002 A4 1.8T Quattro
    Kelowna BC
    yeah i just went about replacing all my rotors and pads with ebay rotors and posi-quiet pads. i did this however, because my rotors were warped, and because i wanted a bit of a step up from stock braking performance. if you're going to go with all new rotors and pads i would suggest buying them from ebay seller top_brakes they cost $250 plus shipping, and they work great. i'm sure you could just as easily get all your rotors turned and just buy pads from somewhere else, but for the price you might as well upgrade the rotors while your at it...
    EDIT: nevermind, you said you already bought pads. well then it's even cheaper for those rotors without pads, $190 i believe...
    just something to consider
    two thousand two audi a-four quattro five speed
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Wow, 300 for turning rotors? Go to a new shop, if they are trying to rob you there, who knows what else they will "find" wrong with your car that they "have" to do...
    981CGTS, Cayenne Turbo, '22 A4 Allroad
    Chicago 'burbs
    Quote Originally Posted by enik23 View Post
    Skokkie? as in Skokie next to Evanston IL? If so go to Phil's Inc in Evanston they have new brake rotors in stock for a whole lot less than that and you can get a set of ceramic pads while you are there too.
    2014 A4Q Red w/ black optic black interior
    Veteran Member Four Rings 4A Play's Avatar
    Jun 12 2008
    Allentown PA
    I just replaced my rear pads with autozone Gold pads, Front pads were still in good shape. 80% less dust with the Duralast Golds. $30 and they were in stock. The rotors were $23 in stock new. I would have replaced the rotors too but there was no grooves in them.
    Self made, NOT Mommy paid.
    2001 1.8 qtm, GT2781R, 680cc Siemens, 3" turbo back, Autopower, Mafless Stage 3 Unitronics, Tial 38mm external wastegate, STS, Corbeau seats
    Veteran Member Three Rings passatkid's Avatar
    Sep 19 2006
    ND
    They usually only charge 20-40 for a pair of rotors to be resurfaced.
    Chicago 'burbs
    Quote Originally Posted by passatkid View Post
    Around here it seems to be more like $40 a pair to have them machined plus a days wait. Considering 84k miles and cheap stock rotors are about $80 a pair. I would buy new rotors and have full thickness rotors than a pair that are close to thier wear limit.
    Nov 11 2008
    skokkie
    what does "wrapage " of the rotors mean?
    Jun 12 2008
    Allentown PA
    That they aren't flat, the contact surface is warped and you get a squeek or uneven braking (pull to one side). Grooves you can tell by just running your finger on the lip of the rotor and feel for any digging in.
