Results 1 to 6 of 6
Thread: b6-b5.swap?
    Registered Member One Ring audimadness's Avatar
    Dec 19 2007
    nnj
    Question b6-b5.swap?
    I have a 2004 a4 1.8tq,and a 99 a4 1.8tq.
    Does anyone know if I can put my b6 a4 1.8tq 6sp tran's in my 5sp b5 a4 1.8t?.
    im planning to keep my b5 and get rid of the b6.My b6 has revo stage1 plus and id like to swap out what i can before i get rid of it.
    is the stock ko3 the same on both? or is the b6 turbo better idk?and I think the down pipe is the same by just by eye.to bad i cant use my b6 GHL exaust either .i have evo raceworks dp. and forge dv.and i think the injectors should work also. but Im not sure.
    this might sound silly but i like my b5 more . and im gonna mod my b5 so id like to swap what i can instead of buying the same mod's for it that i have done on my b6 lol.
    Instead of taking both car's apart and wasting time to see what is going to fit and not, if somebody has the right answer's that would be great.thanks!!!!
    Registered Member Two Rings
    Aug 18 2008
    Wrong Island
    Re: b6-b5.swap?
    If i knew what to tell you i would but, everything is possible...
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: b6-b5.swap?
    Should work. A guy put a B5 2.8 transmission on his B6 1.8T model before. Might be a different story if your B6 is 6speed.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Dec 19 2007
    nnj
    Re: b6-b5.swap?
    thanks,I think it will.but i wanna make sure both cars work right after to lol.
    iv'e even called a few audi performance shop's and they havent done that and are not sure if it will work.
    it should ,but like i said i need the b6 to be drivable.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: b6-b5.swap?
    The K03's are different. The 2004 Has the K03s, vs the B5's K03 (unless it's an 01-01.5). They're interchangeable, but I wouldn't swap turbos.
    The 6 speed will fit, and I believe it's a straight bolt up. However, make sure you let the purchaser of the B6 know that it's a 5 speed. If an enthusiast buys the car, or if it's an Ultrasport, most people would know that it's supposed to have a 6 speed.
    Account Terminated Four Rings
    Nov 09 2007
    Si,NY
    Re: b6-b5.swap?
    Quote Originally Posted by djwimbo View Post
    Put a 6spd shift knob on and limit the test drive 2 a small parking lot.
