Results 1 to 8 of 8
    Veteran Member Four Rings AudiXS4X01's Avatar
    Nov 11 2006
    01 Audi S4-Santorin Blue
    Tri-State
    x-post: What size air compressor?
    Hey guys,
    I'm looking to get an air compressor in my garage. I'm just not sure what size I need. I only need it for basic stuff such as pressure testing the S4, installing and removing tires, filling up tires,possibly painting, etc. Should I be looking at 5lb, 10lb, 30lb tanks? Thanks for your inputs!
    Veteran Member Four Rings audimeister's Avatar
    Jan 05 2006
    '07 A4 Avant S line Ti 6MT Quattro
    Oakland, CA
    Re: x-post: What size air compressor?
    Impact wrenches and painting need big compressors.
    Look at the ratings on the tools you want to use and buy accordingly- they will be rated in CFM @ a certain pressure. Buying the minumum rating of the tool will ensure that the tool will barely work. Always buy more compressor than you need.
    "Obsessed" is a word that the lazy use to describe the committed.
    Nov 11 2006
    Tri-State
    what would a "big" compressor be considered? 30+? 20+? I've used a compressor at my dad's job, but never bought one..he has an industrial sized one and that worked for everything so I never considered needing one. Now we moved houses and his garage is further and it would be more convenient to have one in the house garage. But, obviously an industrial sized one won't be needed. So i really have no experience in buying these.
    Registered Member Two Rings
    May 07 2008
    98' Jetta GLX, 68' Coronet
    Dalton Oh,
    My dad's got a 20 gal I think and it's worked fine for everything. We've also got a small 5 gal tank to use to fill up tires and everything but the 20 runs impact guns just fine for us.
    Jan 05 2006
    Oakland, CA
    It's not just about tank size, but also compressor size. Some manufacturers put a huge tank on a wimpy compressor and fool people into thinking it's a good deal...until the compressor eats itself trying to keep up with high demand and filling a large tank.
    Trust me, I've bought three compressors now. Buy a big brand name, and get AT LEAST 20-30% higher CFM @ whatever pressure your tools say they require.
    To recap: ignore tank size, and go by CFM's @ pressure ratings.
    Apr 18 2007
    b5 s4 nogaro , 1991 bmw 325is 5spd
    florida,wellington & hollywood
    ehh i just have a 120 gal hehe i got it for free to lol the previous owner thought it was broken .. silly him hahah
    cheers
    and as said b4 lpook at the ratings the toools you want to use have
    --daniel
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    if youre going to buy one just go for the 300+ gallon sizes. someday you may want to use impact and you will need a large one for it. sears credit ftMFw
    Aug 06 2008
    Canadia
    bigger tank makes it more consistent because the pump does not need to cycle as much, as someone else said, they often make huge tanks with tiny ass compressors to make people think they will perform well.
    for impact wrenches, 5CFM at 90PSI is adequate, for painting, i would be looking at 10CFM.
    I'd also go for an oil lubricated pump(if you get a 5cfm), much much quieter than dry pumps.
    the B5 S4 is like the mafia... there is only one way out!
