    Feb 21 2008
    Cleveland
    Warm up issue, leaning towards thermostat
    Couple days ago I noticed that my car was not warming up on my ride back from night school, the oil temp had risen before the coolant temp. Half way home the car finally warmed up, but as I continued to drive on the highway the temperature dropped back down again. I have not had time to investigate this but, to me it seems like a thermostat issue. The part that throws me off is that it had never done this before, and only started when it got cold outside. I have read that you might as well do a timing belt if you are changing the thermostat, while it is almost time for me to do one, I was hoping to wait until the spring when it gets warmer to do the belt. Has anyone changed the thermostat without doing the timing belt, and how long did it take you, also if you guys dont think its the termostat let me know.
    Thanks-
    Roman
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Re: Warm up issue, leaning towards thermostat
    Yeah if you are close to needing a tbelt def worth it to do one while you are in ther. Water pump should be done also at this time. I had mine done last week w/out replacing the tbelt, took about 3 hours..
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Feb 21 2008
    Cleveland
    how long does a t-belt job typically take to do at home?
    -Roman
    Veteran Member Three Rings Bimmer2Audi's Avatar
    Sep 10 2007
    2001.5 Audi S4
    G.R. Michigan
    Try the coolant temp sensor. My car ran the same way until I swapped the sensor.
    B5 S4 6MT Stage 2+
    JFONZ GWERKS-AWE Twin 1-SSAC-JHM FMIC-H&R Springs-BBS CH's 18x8.5
    Feb 21 2008
    Cleveland
    changed the coolant temp sensor and all is well, minus me being pissed off lol. It was somehow lodged/rusted in there, I assume it was the orignal sensor since the o-ring was pretty much rotted 1/2 away, and the amount of force i had to yank it out with, ended up ripping the wires out of the harness trying to pull on them, and had to re-pin the damn thing. Good thing I have a buddy with a 2.7t around here, so I could compare the wiring. well at least I fixed it.
    -Roman
