Results 1 to 15 of 15
    Registered Member Three Rings
    Aug 14 2008
    Salt Lake City, UT
    Free shipping on ARP 1.8t Head Bolts from IE!
    We have been an ARP distributor for a LONG time due to the rod bolts we buy. We finally decided to get going and start selling some of their regular applications as well. That said, we have picked up a couple of big stacks of these ARP 1.8t head bolts, and would like to get them MOVIN.
    10MM ARP 1.8t Head Bolt w/o Tool $124.95
    10MM ARP 1.8t Head Bolt with Tool $149.95
    To get your free shipping (Fedex Ground) in the lower 48 states, use code: azenginefreeship
    Integrated Engineering LLC
    Your source for fine quality VW/Audi Connecting rods and engine hard parts. Applications including: 1.8t, 8v, 10v, 20v, V6 and V8...
    www.intengineering.com
    Aug 14 2008
    Salt Lake City, UT
    Re: Free shipping on ARP 1.8t Head Bolts from IE!
    Lots in stock...
    Aug 14 2008
    Salt Lake City, UT
    Orders shipped today, Thanks!
    Oct 29 2005
    10speed
    San Francisco, CA
    ballin
    - Clint
    Aug 14 2008
    Salt Lake City, UT
    Got 2 whole shelves full of ARP stuff now guys, every vw part number now stocked. -Pete
    Aug 14 2008
    Salt Lake City, UT
    up?
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    I bought a set of these and I highly recommend them. I did not want to install studs/nuts so this was perfect for me. Even installed them with the head still on the car one bolt at a time in audi specific order. If you install one at a time and in the proper order you will not have any problems with leaks. I don't...
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Pete,
    What 'tool' is used for these bolts? The 6point poly drive like OEM? I don't see it called out in the description on your website.
    Torque spec is the same as OEM bolts?
    -Doug
    Feb 12 2004
    Everywhere
    It is a different tool than oem. 12pt instead of poly drive iirc. I have one you can borrow any time you need.
    Buncha motorcycles
    Memphis, TN
    spline drive? like on the flywheel bolts?
    APR Stage 2/AWE Intake
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by CO AVANT View Post
    Shit. I was hoping to be able to use my poly drive tool so I won't have to buy the tool with the bolts. If I decide to buy the bolts I'll just buy the tool. You know what its like to collect the proper tools for the job.
    -Doug
    Aug 14 2008
    Salt Lake City, UT
    There are two OEM styles also- this is the 12pt one, there is also poly drive. If you work on a lot of 1.8t's it's best to have both anyways because the early motors came 12pt and all the later poly drive.
    Pete
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by pete@integrated View Post
    Pete
    Older motors have 12pt as in... lets say... '91 VW 2.0L 16V? I recall that motor I had having 12point head bolts and I have that tool already (had to buy it for the work I was doing on that motor). Same tool I use on my front driveshaft flanges.
    -Doug
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    What size 12pt? 10 or 12mm?
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Aug 14 2008
    Salt Lake City, UT
    They are 10mm.
    -Pete
