Results 1 to 14 of 14
    Senior Member Two Rings dreVanHalen's Avatar
    Aug 19 2008
    B5 a4 1.8TQM
    San Marcos, CA
    Need Help Asap!!
    so just drove down to 711 and when I came out to go go home, the car wouldn't start. tried to jump start to no avail. one of my friends ended up showing up at 711 and we were able to push start it no problem. what could this problem be? could it be as simple as needing a new battery? or do you think I need a new starter.
    any help would be appreciated.
    Oct 27 2006
    Pearl 98.5 Audi A4 1.8T
    Fargo, ND
    Re: Need Help Asap!!
    Need more info:
    It was cranking over but wouldn't start?
    was it just cranking and firing?
    I hit the key and nothing, so that's why the jump?
    could hear starter going but engine wasn't cranking?
    It's fine now....or still doesn't start
    Go get your battery and alternator tested at autozone or similar place
    1998.5 1.8TQT (SOLD)
    Joined the Dark Side
    2008 Honda Pilot SE
    Established Member Two Rings Ghostrider's Avatar
    Jan 31 2007
    86 Alfa GTV6, 91 Toyota HDJ80 Land Cruiser, 2005 Miata, 2020 Miata, and Lexus GX 460
    Charlotte, NC
    How I know that feeling, except mine didn't even turn over. Starter has crapped out. Get it rebuilt.
    Dec 05 2007
    If your cluster has a battery meter, place the key in the starting position and see what the gauge reads. If it says ~12.5v, then your battery is just fine. When engine is running, the car runs off the alternator and that gives off ~14.5v. The gauge on the cluster should tell you that.
    -To test if your alternator is bad (which I highly doubt), is to turn on many electronics on your vehicle while engine is running (heat, radio turned up, headlights, etc), go for a spin, and see if the voltage drops.
    -To test the battery, simply place key in starting position and look at the gauge. Or use a simple volt meter to your battery.
    But I doubt your issue has to do with the battery or alternator.
    Account Terminated Four Rings
    Nov 09 2007
    Si,NY
    Or pull a battery cable off with the engine running, it stalls its the alternator, it runs its the battery.
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    clutch switch maybe?
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Aug 19 2008
    B5 a4 1.8TQM
    San Marcos, CA
    battery is reading over 12 volts. getting a clicking noise when trying to start but that is it. sometimes the click isnt even there. cant find the starter to try to hit, thinking maybe it stopped on a flat spot? although unlikely because we have tried starting it in several different spots.
    Dec 05 2007
    Starter relay? Or actual starter?
    Dec 20 2007
    1999.5 Audi A4qm AEB
    iowa
    It's the starter.
    Aug 19 2008
    B5 a4 1.8TQM
    San Marcos, CA
    anyone have a right up on how to get to the starter?
    Aug 19 2008
    B5 a4 1.8TQM
    San Marcos, CA
    or starter relay?
    Dec 05 2007
    I would go by the tech's advice and replace the starter. Autohausaz has the best prices I have come across thus far, unless you can find one on ebay (not an ebay knock off). As for replacing, I have never replaced one, so I do not know. But here is a link to the service manual. Procedure will be in there somewhere.
    And if you decide to replace the relay, the procedure should also be in there somewhere. They usually have procedures to test the relays before even having to replace it. So, if the relay is bad then replace it. If not, then replace the starter.
    Registered Member Two Rings CreamAudi's Avatar
    Jun 12 2008
    hempstead,ny
    it could be that the magnetic brushes in ur starter are contradicting them selves and intead of changing the charge they are attracting them if thats the case u might as well just get a new starter>
    Cream 98 quattro
    mods
    3MM 20% tint,2 12 jlaudio subwoofers, k04-15,forge 007,Unitronic stage 2+,380cc injectors,18x8.5 asa ar2,rs4 grill,and customized floor mats(adds 25 whp), Infinity Kappa speakers and tweeters, fmic, v-maxx coilovers, custom exhaust, small lip spoiler
    Aug 19 2008
    B5 a4 1.8TQM
    San Marcos, CA
    took it to a shop today because i just dont have time to try to figure it out myself. mechanic is thinking it could be the ignition switch. said starters are more rare to see going on our cars than ignition switch. not to say it is not possible. hopefully will have the car back tomorrow
