Results 1 to 13 of 13
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    Coolant leak at the back of engine. Anyone gone through this?
    I have a coolant leak at the back of my engine. I can't find my inspection mirror anywhere, so can't tell exactly where it is coming from. It is near where the rear coolant flange is (which I replaced last year) but does not seem to be coming from it. At least not on top.
    I can see coolant collected on top of my transmission housing, but just can't identify where it is coming out. From what I can see it is possibly:
    Bottom of coolant flange plumbing.
    or
    Head gasket (between head and block) I REALLY hope that it is not this!!! No moisture in my oil, or oil in coolant so that is a good sign.
    I was hoping someone had gone through this, and had a suggestion on what it might be. It is not a fast leak, only have to top up coolant every couple weeks, but still smell it and would like to fix it before it gets worse and strands me.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    May 22 2007
    oakland ca
    Re: Coolant leak at the back of engine. Anyone gone through this?
    for further clarification:
    leak is at the back of the engine right at the firewall up top somewhere. no view available without some sort of scope or mirror and I don't have either.
    I am looking for likely suspects on what to check
    Feb 17 2005
    Sarasota, FL
    Most likely the coolant flange or the coolant flange o-ring. The quick disconnect on the hose coming from the heater core is also o-ring sealed to the flange as well as the CTS, could be one or any combination of those parts.
    Saint Cloud, Fl
    depending on if it is actually your rear coolant flange, I would advised doing this mod first
    http://www.audizine.com/forum/showth...19#post2877619 it will save you countless hours
    instagram ------------> low_enforcement
    May 22 2007
    oakland ca
    Quote Originally Posted by 7speed View Post
    I have not really been following this mod, been to busy lately to worry about any mods for the moment. What are the advantages of this aside from simplification of the system. What does it affect? still be able to pass smog etc?
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by cjonesgo View Post
    Not something you want to do being in Cali. It will cause your car to fail all actual emissions test yes, however readiness codes can be set to passed with the correct software
    Saint Cloud, Fl
    Quote Originally Posted by A4ringedONE8T View Post
    oh Cali ......
    Veteran Member Four Rings Turbo1A4's Avatar
    Aug 04 2008
    2002 s4 nogaro
    Jax
    i had the same problem it was the o-ring in the flange
    May 22 2007
    oakland ca
    I replaced the flange and o-ring a little over a year ago. I hope it is that, because it is a straight forward fix, but I sort of doubt I am that lucky.
    What else is back there that could be leaking?
    Senior Member Three Rings dirtyserby's Avatar
    Jan 28 2007
    Bay Area, Norcal
    Quote Originally Posted by Turbo1A4 View Post
    for me it was the flange....the biggest Pain in the ass job I ever had to do.
    if you have big hands, you will hate your life.
    I have scars on my right hand because of that god-damn flange, so I will remember it forever.
    Veteran Member Three Rings B8Buckeye's Avatar
    Mar 14 2005
    2011 Audi A5 Cabriolet - Ibis White and 2016 Mercedes Benx Metris conversion van - Obsidian Black
    NW Ohio
    i had the same problem. it was the coolant flange. i replaced the temp sensor while doing it.
    the job was a piece of cake for me. all i did was watch shawn and his tech, adrian, burn their arms trying to get past all the hot stuff back there. LOL.
    2011 A4 Avant 2.0T Quattro ZF8 - Brilliant Black - Sport & Cold Weather Packages
    Magma S4 Seats & Door Cards with Brushed Aluminum Trim, B8.5 S-line Auto Shift Knob, RSNav S3 10.25", 19" OEM 5-Arm Cutters, RS4-style Honeycomb Center & Fog Grilles, deAutoLED Turns & Fogs, OEM B8.5 Euro LED Tails, OEM S-line Stone Guards & Rear Valence, IE HFC/DP, Milltek CBE, UM Stage 2, ECS Coilovers
    Aug 25 2007
    New York
    yup. had to replace mine. its deff the coolant flange or the coolant flange o-ring
    2004 A41.8TQM USP
    Dolphin/Black
    Titanium 18x8.5 ET35 Forgelines
    REVO//GTRS
    Veteran Member Four Rings jon102034050's Avatar
    Oct 02 2006
    MN
    seems pretty common, i had it as well
    A4 1.8TQ - RS4 Sway - Avic-D1 - Neuspeed Sports - Bilstein Sports - Joey Mod
