Results 1 to 14 of 14
    Senior Member Two Rings NYCS4Avant's Avatar
    Apr 23 2008
    B6 S4 Thunder Wagon
    Re-attaching emblems
    Anyone have any advice on an adhesive to use for re-attaching emblems? During my last hand wash I lost the "4" from my .
    B6 S4 Avant: Nogaro / JHM Tuned/ Piggied / Milltek Non-Res / JHM SS Trio / Hardwired V1 / SS Brake Lines / CC Mod / Stern Snub / LED License Plate / 18" TSW Vengeance / 20% Tint / DIY Blackout Grill / Black Window Trim / Thule Bike-Ski-Fishing Pole Rack / Full Timing Chain at 68k oh wel...
    Senior Member Three Rings a4mafia(Red)'s Avatar
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Re: Re-attaching emblems
    i'm pretty sure its just a double sided adhesive tape....thats what my autobody man told me
    work in progress....
    B5 A4 2.8 FWD Transmission:
    http://www.audizine.com/classifieds/...ct=9554&cat=12
    Registered Member Two Rings 4BLKRNGS's Avatar
    Oct 22 2008
    Monrovia, MD
    i used super glue with a small applicator so i wouldnt use too much of it and have it ooze out
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Quote Originally Posted by 4BLKRNGS View Post
    OUCH! Why in the world would you use that? I hope you don't have plans taking it off.
    Anyway, 3M Exterior Mounting Tape (4011T) is very thin and will hold really strong. Super easy to take off as well. Leaves no residue.
    Registered Member Three Rings Buegie's Avatar
    Sep 18 2007
    e90
    Quote Originally Posted by 40valve View Post
    x2, super glue is definitely not what you want to use. 3M double sided tape is the way to go
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Super glue??
    Regardless on whether you plan removing the badge or not, super glue actually burns the paint, and is likely to begin blistering from underneath the badge, to surrounding area.
    Veteran Member Three Rings VR2V8's Avatar
    Dec 20 2007
    Philly Area, PA
    I'd use the 3M tape as mentioned above. Just make sure to remove all of the old tape from the badge and clean it and the car really well first.
    2022 SQ7: P+, Daytona Gray Pearl/Black, Alu Optics, Ambient Lighting Package, Extended Leather Package
    Audi All-Season Floormats/Trunkliner, Llumar CTX 35%
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    what about on the grill? I'm about to get a new RS4 grill, and will need to attach my S4 logo to it.
    tape definitely won't work since it's kind of 'floating'
    super glue ok for that?
    Dec 20 2007
    Philly Area, PA
    Quote Originally Posted by sakimano View Post
    Honestly, I'd wait until you have an RS4 grille installed. You may decide you like without the badge. Otherwise, yes, I'd superglue or epoxy it on there, or make yourself some kind of custom mounting clip.
    Mar 24 2008
    khgkhg
    And just for those that need this, proper way to put emblems/badges back on:
    1. Clean all residue from the back of the emblem/badge by using warm water and some sort of adhesive removing agent (Goo Gone for an example). Once clean, handle it with gloves so you don't leave any oils on the area where the adhesive tape will go thus hindering it's effectiveness.
    2. Thoroughly clean the area on the car where the badge goes with adhesive removing agent. Using a hairdryer on low setting will help with removal but be careful not to burn the paint. Note that with all the scrubbing you will most likely strip wax coating so it's a good idea to put on a thick coat of wax before you re-apply the badge.
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    Seems counter-productive to wax before you apply the emblem. The wax would act in a similar manner to the finger oils you were so careful to avoid...no?
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Senior Member Three Rings Rodknock's Avatar
    Jun 25 2008
    The Dirty T, WA
    This works the best!
    Mar 24 2008
    khgkhg
    Quote Originally Posted by S4J View Post
    You can't compare wax with oils from your fingers. Besides I'd much rather have a nice coat of it over paint when introducing adhesives. Have done it for years and never had any of the fall off.
    Apr 23 2008
    B6 S4 Thunder Wagon
    Thanks! Just put my "4" back on. Followed your advice and cleaned everything off before hand. The back of the emblem was super grimy and needed to be scrubbed with a firm brush. I also washed the car this afternoon to make sure it was clean and ready to be an S4 (it wasn't very happy being just an "S")
