Results 1 to 19 of 19
    Established Member Two Rings Sp@cE418's Avatar
    Jan 07 2008
    Audi S4 2001.5
    Quebec
    Shifting problem
    Hi !
    I just recently change my differential and transmission oil.
    The next morning, i started the car and put the gear in reverse. No problem.
    After that , I put it in first and decides to put it in second ... No way ! Impossible to put in second. I stopped the car. Try all the gear and it's fine. Hummm...
    After that, i noticed that i can only go in second when i'm under like 15km/h ...Sound strange ...
    When the car warms up, the problem seems to be less present ...
    Any idea ? Wrong oil ? Bad syncro ?
    Thanks !
    Veteran Member Four Rings S4 John's Avatar
    Sep 19 2006
    The Man Cave
    Re: Shifting problem
    i know the transmission is very tempermental if you did not put in correct amount of transmission fluid. Also, are you sure you put the fluid in the correct fill hole?
    //NEVER FOLLOW
    B5 S4 Avant - Nogaro Blue - TTE550 - ETSPEC
    8J TTRS - Panther Black - United Motorsport
    8V RS3 - Mystic Blue - TTE700 - Unitronic
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    Did you put the correct fluid in. Also 1st,2nd gears go on these trans all the time. There is a new updated gears, synchros, and shift collers.
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Jan 07 2008
    Audi S4 2001.5
    Quebec
    Quote Originally Posted by jcanni View Post
    So you believe it's more a fluid problem than a syncro or gear problem ?
    Syncro is a PITA to change for the cost of the part ...
    Jan 07 2008
    Audi S4 2001.5
    Quebec
    We change the oil yesterday for a high temperature one.
    Today, Same thing ...Not able to put it in second until I warm the car for about 5 minutes ...
    I would understand if the outside weather was like -40 celcius but it was like -10 celcius
    What the hell ?!
    Sep 19 2006
    The Man Cave
    idk, i thought it was the fluid level because you just changed it. but, if you are having a hard time getting into 2nd it is probably the 2nd gear slider.
    //NEVER FOLLOW
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Do you have reverse?
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Jan 07 2008
    Audi S4 2001.5
    Quebec
    Quote Originally Posted by Matt@JHM View Post
    Yes !
    Facts :
    On cold startup, when i'm stop, i can go in each gear easily.
    So i put it in reverse, get out of my entry, put in it first and go.
    If I try to put it in second, there is no way to do it ! So i go in rev a little bit and put it directly in third or stop and put it in second directly.
    When my car warms up, the problem tend to disappear or at least it's better.
    I mean, the more the car warms up, the more I can put it in second for downshifting or upshifting...
    Let's explain a little bit.
    If my car is "cold", and i'm in third gear, i'm not able to put it in second until i'm at like 5km/h.
    If my car is "hot", and i'm in third gear, i'm able to put it in second at like 30km/h.
    Any ideas ?
    Jan 07 2008
    Audi S4 2001.5
    Quebec
    I don't think it's a matter of fluid level.
    Gear slider is the same as syncro ?
    Is it like 20 hours to change it ?
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    my car does the same thing when its cold. it will not let me into third unless it is rev-matched perfect, and even then sometimes it will lock me out or kick me back out. when it warms up the problem becomes less aparent, but will still grind if you shift fast
    Jan 07 2008
    Audi S4 2001.5
    Quebec
    Quote Originally Posted by b5s4tt View Post
    Have you figured out what is the problem ?
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Quote Originally Posted by Sp@cE418 View Post
    prolly bad syncros
    Jan 07 2008
    Audi S4 2001.5
    Quebec
    Quote Originally Posted by Evilevo View Post
    prolly bad syncros
    It was what I was thinking ...
    But why there is no problem when it warms up ?
    It's like a 20 hours job right for the syncro ?
    BTW, it's not grinding at all ...it goes into second or not ...
    Sep 19 2006
    The Man Cave
    you have bad syncros.
    //NEVER FOLLOW
    Sep 19 2006
    The Man Cave
    i really think it is your slider (also known as a shift collar). you should have your syncros swapped out while you are at it. i had my transmission rebuilt with new syncros, slider, and 2nd gear for 2200. this is without labor of removing and installing the transmission.
    //NEVER FOLLOW
    Jan 07 2008
    Audi S4 2001.5
    Quebec
    2200 without the labor ? sh%$
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    sounds more like a syncro is you cant get into gear unless you rev match it. Worm syncro plus cold fluid = bad time shifting. Baby it and start saving.
    Jan 07 2008
    Audi S4 2001.5
    Quebec
    Quote Originally Posted by haus4 View Post
    For your information, they put a fluid transmission but not the better one.
    They replaced the standard oil with the "race" one (75W/90)
    so, before changing your slider or syncro, maybe you should try to change your oil ...
    Here's the explaination on the ECS tuning Web Site ...
    This 70W80 GL-4 Gear Oil (SAE 5W30/10W30 engine oil viscosity) is designed for use in manual transmissions and transaxles. Provides excellent protection of gears and synchronizers and its balanced slipperiness provides a perfect coefficient of friction allowing easier shifting.
    Red Line Oil's MTL and MT-90 are designed to provide excellent protection and improved shiftability for manual transmissions and transaxles having cured the problem of hard shifting in thousands of transmissions with shifting troubles. How? They have the appropriate coefficient of friction for most manual transmission synchronizers (many gear oils engine oils and ATFs are too slippery for proper synchro engagement). And the wide viscosity of MTL and MT-90 allow proper shifting over the entire temperature range which the transmission will experience. The synthetic base oils used have a very high viscosity index which provides relatively constant viscosity as temperature changes. MTL is a low 70W at very low temperatures and a high 80W nearly an 85W at elevated temperatures providing adequate viscosity to prevent wear and deaden gear noise. MT-90 is a thicker 75W90 version of MTL. The shear stability and oxidation stability of these products are excellent thus the physical characteristics of Red Line MTL and MT-90 will change little with use.
    Manual Transmission Service Kit
    Red Line MT-90
    Looking to service your manual transmission? Does your transmission shift hard when it's cold or intermitantly grind when going into 2nd? It's quite possible that all you need is to change your fluid in your manual transmission case.
    http://www.ecstuning.com/stage/edpd/...oductID=252751
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Just to let you know there are cheaper options out there. http://www.jhmotorsports.com/shop/ca...1_56_60_102_26
    Our full rebuild is $1,199 but we now offer a minimum rebuild kit for $875. Minimal kit ONLY to patch up your trans and just fix the bad 1-2 shift collar and the 1st and 2nd gear synchros. You can watch our included DIY step-by-step video and save thousands.
    Lots 'o Goodies
