Results 1 to 25 of 25
    Veteran Member Three Rings DGAFxxx's Avatar
    Nov 27 2006
    Salt Lake Shitty, UT
    Does this turbo look bad?
    So a couple days I expericened a loss of power. The turbo was making an unusual whining noise, there was tons of white smoke coming out of the exhaust . I figured it had to be a bad turbo:
    Not to mention the obvious on the fins on the intake side, it has quite a bit of shaft play. I'm guessing somehow some type of bolt went through the intake sytem. I was unable to find anything. I guess it gives me a reason to slap on a K04.
    Hooray for boobies!
    Registered Member Three Rings kovalevandrew's Avatar
    Oct 19 2008
    South Africa
    Re: Does this turbo look bad?
    Err... Holy crap... That's well broken right there. Good work!
    BAT that thing!
    Veteran Member Four Rings lowandslow4now's Avatar
    Jul 12 2008
    Cumming, GA
    WOW that looks pretty bad. Well now you have a reason to upgrade
    Now 2001 B5 S4
    Former B5 A4, 034 Stage 3 BT, Unitronics,H&R,etc,etc
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I have one sitting under my toolbox at work that looks about identical. The nut broke/fell off the front of the shaft and FUBAR'd the compressor wheel.
    Oct 19 2008
    South Africa
    Quote Originally Posted by djwimbo View Post
    That would explain where this one went to. Made a right mess it did.
    Oct 31 2004
    Michigan
    Is the wastegate good and do you still need it? I need one for my friends car. Let me know if you want to get rid of it.
    Established Member Two Rings DuviVr6's Avatar
    Jun 03 2008
    99.5 Avant 1.8TQM
    OKC, Oklahoma
    i think it looks good!!
    NOT!! haha
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Buenos Noches
    Nov 15 2007
    Audi A4
    Redding, California
    send it to g-pop shop and have it turned into a ko4...
    doesn't look good, but the housing is definitely worth saving...
    gl!
    Oct 31 2004
    Michigan
    I wonder where all the missing metal went? Hows your oil? Clean?
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Quote Originally Posted by dan4g63 View Post
    I'd try looking in the intercooler.
    Apr 22 2007
    Riverbank, Ca
    I'd be curious how your intercooler and pistons looked...
    Veteran Member Four Rings kampfer's Avatar
    May 18 2008
    Also on the Curb:: VW Passat
    SOOOOOO Cal
    yeah, i had a similar looking turbo about 2 months ago and was wondering if it could do damage with all the fragments to the engine.
    Saint Cloud, Fl
    You wouldnt think those chunks would make it through the intercooler
    instagram ------------> low_enforcement
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    lol looks like a realyl badly curbed rim :[
    TEAM|AXION
    Nov 09 2007
    Si,NY
    Damn!!!
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    that turbo looks great!
    and by great i mean it has a totally trashed compressor!
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    Where is half of your compressor?
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Senior Member Three Rings MOtown A4's Avatar
    Oct 06 2008
    2001 Audi A4 1.8 T
    Shelby Twp. MIchigan
    yuck!
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    how is his engine still running? How is that even possible!!!??
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by audiness View Post
    Read post #4
    The engine doesn't require the turbo to do anything at idle, or even cruise. WOT it wouldn't be happy at all.
    Basically, at idle or most situations in vacuum the turbo is just there for the ride, whether or not it's pushing air is almost irrelevant.
    Veteran Member Four Rings Quattro 4 Life's Avatar
    Feb 05 2008
    '64 Pontiac Catalina
    Kenmore
    yeah that sucks/ is wierd cause i had the same thing happen to mine
    it's dangerous becasue of all the little shards that are left throughout the intake
    G-pop shop is a quality rebuild center, they just took two months to even get to mine this summer. I would also look at skroll (sp) cause they might be able to make that K03 into a K04+ not totally sure what they can do with K03's.
    Check your DV and DV return pipe, thats where i found the nut that came off the front of the shft
    good luck!
    EDIT: oh and when you change your turbo, don't hesitate in replacing the oil supply line! i killed a K04 in a week by not doing this.
    2013 Phantom Black C7 S6 Stage 3 | 2007 Ibis White B7 A4 Avant 3.2QM Titanium - 1 of 2 | 2013 Glacier White Metallic 4L Q7 3.0 TDI
    Past: 2003 Brilliant Black C5 S6 Avant | 2011 Quartz Grey C6.5 A6 3.0T Prestige | 2000 Silver C5 A6 2.7TQM | 1999 Laser Red B5 A4 1.8TQM PC-16
    IG: tyscalzone
    Nov 27 2006
    Quote Originally Posted by Quattro 4 Life View Post
    good luck!
    Good info. I called GPOP Shop. They want $350 for a rebuild plus an extra $175 to put in a compressor that is 1mm larger than the k04. I think I am going to do that. Does anyone know how the k03/k04 gpop hybrid compares to a stardard k04-015?
    Hooray for boobies!
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    man whatever foreign object fell in there had to sit there for a few seconds just lathing away at the comp wheel. you didn't hear any of that? seems like it would have been loud.
    but that wheel looks pretty bad ass now. put that baby up on the mantle
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Nov 27 2006
    I didn't hear anything loud. It was making a whining noise. probably the sound of the comp wheel lathing away. I didnt put 2 and 2 together at the time.
    Quote Originally Posted by sean1.8t View Post
    Hooray for boobies!
