At STaSIS, our mission is to bring you the ultimate in automotive performance. We are passionate automotive enthusiasts, excited by the opportunity to help you transform your car into one of the best performing vehicles on the road. We focus on designing quality components to meet your performance goals. Each design is tailored to a specific chassis and can be fine tuned to meet the needs of our customers. Our customers are our number one priority. Your expectations and expertise provide the balance that is key to all STaSIS performance products.
FREE SHIPPING
Stasis Big Brake Kit
Monobloc4 - 328mm x 28mm (14") Big Brake System $2750
Monobloc4 - 355mm x 28mm (14") Big Brake System $2950
Monobloc4 - 370mm x 28mm (14.5") Big Brake System $3350
What's In the Kit:
ALCON 4 Piston Calipers
ALCON 326/355/370mm x 28mm(14/14.5") Floating Rotors
STaSIS Caliper Mounting ----------Bracket & Hardware
Goodridge Stainless Steel ---------------Braided Lines
Motul brake fluid
SBS Hi Performance Brake -------Pads
Fits:
Audi A3 2.0T 05-06
Audi A3 3.2 05-06
Audi A4 B5 FWD 2.8 97-01
Audi A4 B5 FWD 1.8T 97-01
Audi A4 B5 Quattro 2.8 97-01
Audi A4 B5 Quattro 1.8T 97-01
Audi S4 4.2 B6/B7 04-06
Audi S4 B5 2.7T 00-02
Audi RS4 B7 07+ (14.5 Inch Brake Kit Only)
Audi A5 08+ (14.5 Inch Brake Kit Only)
Audi RS6 C5 4.2T 2003 (14.5 Inch Brake Kit Only)
A4/S4 Rear Brake Kit $795
What's In the Kit:
ALCON 298x20mm vented, gas slotted rotors
STaSIS Vented Hats
STaSIS Caliper Mounting Bracket & Hardware
Goodridge Stainless Steel Braided Lines
Motul brake fluid
Ferodo High Performance Brake Pads
Fit:
Audi S4 B5 98-02
Audi A4 B6 02-05
Audi A4 B7 05-07
Signature Series Touring Brake System $995
What’s included in the kit?
· 2-piece Alcon rotors (345x26mm) w/ 6061-T6 hard anodized hats for long lasting finish and durability
· Genuine Audi backing plates (OE units do not clear)
· OEM caliper re-location brackets
· Mil-spec mounting hardware
BRAKE PADS ARE NOT INCLUDED IN THIS KIT. THEY ARE AVAILABLE FOR PURCHASE SEPARATELY.
Fits:
Audi A3 2.0T 05-06
Audi A4 B7 05-07
SBS Pro-Race Brake Pads and SBS Pro-Track Brake Pads $299
SBS Pad Technology
Nucap Retention System
Superior mechanical contact between the backing plate and the pad material ensures that pad separation cannot occur once assembled. This also eliminates vibration between the backing plate and the pad material.
Dynamic Energy Surface Treatment
A heating process to degass the pad material. This provides more consistent performance and simplifies pad bedding.
Unified Composite Technology
Proprietary system that creates a homogeneous pad material mixture
Street Sport Suspension $1075
Whats in the kit:
-KONI Cadmium Plated, Adjustable Dampers
-Koni Progressive Sport Springs
-UHMWPE Spring Perch Bearings
Fits:
Audi A4 B5 Quattro 1.8T & 2.8L 95-01
Audi S4 B5 Quattro 2.7T 98-02
Audi A4 B6 & B7 1.8T 2.0T 2.8L 3.0L 3.2L 02-07
Audi S4 B6 & B7 4.2L 03+
Audi TT AWD MK1 1.8T 3.2L 00-06
Track Sport Suspension $1895
What is in the kit:
KONI Linear Rate Springs
STaSIS Mounting Hardware
UHMW Spring Perch Bearings
Spring Options: Normal, Aggressive, Track
Fits:
Audi Torsen Center Differential Upgrade $550
For Manual Transmissions Only
Tuning the center differential provides one of the most significant performance gains available to the Quattro owner. The standard torsen center differential in the S4 and A4 provides a 2:1 torque distribution capability. This enables the end of the car with traction (generally the rear) to deliver twice the torque being delivered by the least tractive end of the vehicle (generally the front). For high performance street cars, we recommend a bias ratio of 4:1. This is the same bias ratio that Audi has provided in the stock RS4 driveline.
Torsen Differentials deliver more torque to the wheels that have more traction. The STaSIS high bias torsen provides a dramatic improvement in negotiating a turn quickly and efficiently. Now your car can be 3 cars in one( front, all and rear wheel drive)
Core Exchange
There is a core charge of $1000 if we send out a STaSIS center differential to you. When you exchange your center differential for a STaSIS unit, send your differential back to STaSIS and we will refund the $1000 core charge.
You may also send your differential to us for modification and not incur a core charge. We can usually modify and ship out your modified differential the same day we receive it.
Fits:
Audi A4 B5 95-01
Audi S4 B5 98-02
Audi A4 B6 5 Speed 02-05
Audi A4 B6 6 Speed 02-05
Audi S4 B6 03-05
Audi S4 B7 06+
Audi S5 B8 08+
Stasis Engineering’s Signature Series A3 2.0T Cat-back system $659
·Mandrel bent T-304 Stainless steel, 2.5” (63mm) free flowing system.
·Entire system is polished to a mirror shine for a brilliant luster
·Double walled dual - 3.0” polished tips with laser engraved STaSIS logo will withstand tarnishing over many years
·Stainless Borla muffler keeps sound levels deep and mellow
·10-15 TQ/HP increase
·Designed and manufactured in the U.S.A.
·Stasis Engineering’s Limited lifetime guarantee
StaSIS Signature Series Catback Exhaust System Audi A4 B7 2.0L 05-08 $985
- Mandrel bent T-304 Stainless steel, 3" (76mm) free flowing down pipe, blends into a divorced 2.25" (57mm) main pipe section.
- Entire system is polished to a mirror shine for a brilliant luster
- Double walled 3.5" polished tips with laser engraved STaSIS logo will with stand tarnishing over many years
- Twin resonators keep sound levels deep and mellow
- 10-15 TQ/HP increase
- Designed and manufactured in the U.S.A.
- Stasis Engineering's Limited lifetime guarantee
StaSIS Signature Series Catback Exhaust System Audi S4 B7 4.2L 06-08 $1395
- V-banded, mandrel bent dual T-304 Stainless steel, 2.50" (63mm) mid pipes with 'resonance chamber crossover' flows into twin rear mufflers with dual outlets.
- Double walled, dual 2.0" polished tips with laser engraved STaSIS logo will withstand tarnishing and look great for years.
- Resonance chamber crossover help control sound levels, keeping the exhaust note throaty yet mild mannered
- Stasis Engineering’s Limited lifetime guarantee
Stasis SigSeries Dual Outlet Catback Exhaust System Audi A5 08+ $1695
-Mandrel bent T-304 Stainless steel.
-Entire system is polished to a mirror shine for a brilliant luster
-Double walled 3.25" polished tips with laser engraved STaSIS logo will with-stand tarnishing over many years
-Twin resonators keep sound levels deep and mellow
-10-15 TQ/HP increase
-Designed and manufactured in the U.S.A.
-Stasis Engineering’s Limited lifetime guarantee
FREE SHIPPING
PM for any questions or call me at 703-772-2890 thanks
