Results 1 to 26 of 26
    Veteran Member Four Rings apatchin's Avatar
    May 28 2008
    PDX/DEN
    ZiZa LED City Lights Quick DIY (w/ pics)
    So i know there have been a few posts around but i couldn't find one with pics. So I just snapped a few for those who like pics.
    tools: mirror / screwdriver / needle nose / flash light
    (right side) remove snorkel to access headlight housing
    access housing (same on both sides)
    locate burnt orange connector, it will be located in the upper corner. this is where i used a mirror and flash light to find the connector easier. very awkward space but once there out its cake.
    with the needle nose snag the connector and pry off...takes a couple minutes, kind of a pain but it will come.
    unplug bulb, plug in ZiZa Citylights, after plugged in test it, make sure it works. plug the new led into the housing and stuff the excess wires back into the housing. close the housing. replace snorkel...etc.
    no codes. lookin good.
    Veteran Member Four Rings CZA420tAvant's Avatar
    May 24 2008
    06 A4 Avant 6MTQ Brilliant Red
    Orange County, NY
    Re: ZiZa LED City Lights Quick DIY (w/ pics)
    so people are not having any problems with these anymore, as mentioned in many posts?
    Nice write up
    Z
    Driving: 2006 Brilliant Red A4 Avant 2.0TQM
    Revo Stage 2|Carbonio Intake|Stasis SS coils|Podi Gauge|iForged 19"|H&R spacers|RS4 F/R sways|custom inlet pipe|Milltek turbo back with custom twin tips
    Endorsing:
    Senior Member Three Rings Turn10's Avatar
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Yeah i still dont know. SO you obvioulsy have a B7, but do you have a red or colored DIS.
    When life passes you by, downshift.
    Tri-State Southern Audi Chapter
    http://www.audizine.com/forum/group.php?groupid=14
    May 28 2008
    PDX/DEN
    I have a red display.
    i didnt have any issues. have only had them for a few days, but ill keep you posted.
    thanks z.
    Apr 15 2007
    WNC
    nice hemostat.
    2013 RS5, 2014 Q7
    Nov 12 2007
    Grand Junction, CO
    I've had these for over a month now with not one issue.
    May 28 2008
    PDX/DEN
    good to know. thanks
    Registered Member Two Rings
    Jun 18 2008
    NE
    no problems either with codes...had them in for about a month and a half... and before that about 2 weeks stuck in the housing lol
    Senior Member Three Rings fromGMCtoAUDI's Avatar
    Feb 03 2008
    '08 audi A4 2.0T
    alexandria, VA
    so '08s with red DIS have no issues. I think this will be my next mod
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    the only issue people were having were them falling into the housing of the headlights. so if you are worried use some tape to hold them down.
    The usual things!!
    Resistor Install
    Established Member Two Rings e-baby's Avatar
    Dec 20 2008
    Sylmar/ santa clarita
    i know this is an old post but did you guys who've installed these pull on the wires somewhat or on the orange connector because it's hard to get my fingers on the orange connector.
    Veteran Member Four Rings xULx's Avatar
    Jan 20 2010
    07 Brilliant Black A4
    San Diego
    I have a 2007 A4 B7 with color display. It took me 30 mins from start to finish with this. I didn't end up using the mirror. You just kinda have to feel your way around, but eventually you know exactly where the lights are. I have no errors with the color display, also when you connect the zizas try some electrical tape to secure the connection to the wiring harness. I can field any further ?s you may have. Ups to Apatchin for getting the pics up
    -Jesse
    Senior Member Three Rings WasGTIguy's Avatar
    Jun 09 2009
    Orangeville, Ont
    I just put a set in last week. On a cold start, the display says right parking light out. When I turn the car off and back on again it works again
    here is what they look like in my car
    And here they are with the xenons, and Hoen fogs
    I love the look all matching
    Jan 20 2010
    San Diego
    Looks Good
    -Jesse
    Established Member Two Rings cjnesher's Avatar
    Oct 31 2008
    DG 05 A4 2.0T 07 Passat 2.0T
    Tampa, FL
    Can someone post a link to the correct ones on ECS? I think I finally found the right lights.
    Jan 20 2010
    San Diego
    Quote Originally Posted by cjnesher View Post
    These are what I have. They look great.
    http://www.ecstuning.com/Search/Audi...t_ES/ES252273/
    -Jesse
    Oct 31 2008
    Tampa, FL
    Perfect, Thanks! Added positive to your REP.
    Jan 20 2010
    San Diego
    Anytime Sir, Anytime
    -Jesse
    Active Member Two Rings BostonDriverS4's Avatar
    Jan 24 2010
    Massachusetts
    I just installed these in my B7 S4 and wanted to give everyone some pointers on the install. As mentioned this can be done very easily without removing the headlights, just takes a little feeling around. I found it to be much easier if you take out the high beam bulb (i think that's what it was, but you'll see it because its kind of in the way) when doing the install. Unfortunately this can only be done on the drivers side because on the passengers side you have the radiator hose in the way. You'd have to have some pretty strong and limber fingers to unlock it and then lock it back in to place when done. For some reason the passengers side city light was easier for me to grab than the drivers side. Also, I didn't need to use a mirror or pliers to grab the bulb housing either. Just trace the wires to the back of the housing a give it a wiggle and it should pop right out. No twisting is needed since they just lightly snap straight in/out.
    Definitely connect and test them before inserting back into the headlight. I did one side tested it and then installed it in the headlight then moved onto the passengers side only to find the drivers one was no longer lit. I pulled it out and tested both while they were out and it turned out to be just a bad connection from when i put in back into the headlight. Also, I wrapped the ziza and factory connector with electrical tape because they didn't clip in and feel that secure.
    Lastly, after i was sure both were working with the parking lights on I noticed that if I turned the headlights on while not running only one side would light after checking the connections again and then repeating the test with parking lights on followed by the headlights I had the same issue. I was now annoyed and about to pull them out when i thought to repeat the test with the car running. All was good while the car is running, both lit up when the parking and headlights were on. Turned the car off and tried it again and sure enough, only one side lights up when the headlights are on.
    As for the error code, I haven't had one yet. Even when the car wasn't running and only one was lighting up...? I'm not sure why this is the case, but curious to know if they have experienced the same. Maybe someone from ECS can explain why this happens. I'm thinking it just has something to do with how the power is supplied when the car is off with the ignition on vs. when the car is running.
    Veteran Member Four Rings bmc333's Avatar
    Feb 12 2009
    NoVA
    On the A4, there's nothing in the way of the city lights when removing or installing - very easy 5 minute job. I've had mine in for about 4 months and they've worked perfectly and look great with my 6000k HIDs.
    2015 S3 - Panther Black P+ / LED Lights / B&O / APR Stage 1 ECU & TCU / APR Turbo Muffler delete / CTS Turbo Inlet/Discharge/Intercooler Pipes / X34 Intake / Superpro end links / VWR springs / 35% Tint / ED CF rear diffuser / 034 CF engine & fuse box covers / ECS CF battery cover / BBS SR's
    Mar 31 2008
    A4 B7 2.0L TFSI
    Australia
    Quote Originally Posted by BostonDriverS4 View Post
    Exactly the same experience for me, only Left side lights when car is off. Certainly check the connection and test, with the car running, before you pop them in. No error code, can't say the same thing for the rear LicencePlate LED's.
    Jan 24 2010
    Massachusetts
    Quote Originally Posted by Esquire View Post
    Update... I just went out and removed and reinstalled (in about 10 minutes this time) after reading about some of the led bulbs not being siliconed into the socket and falling into the headlight. I don't want to deal with that so I took the advice of ECS and wrapped some electrical tape around the led bulb and socket as well to make sure it didn't come out. Turned out mine were siliconed in place, but I figured it was extra protection if not just piece of mind knowing that it shouldn't fall out now. Advice - only put on enough tape to go around once or it will be a very tight fit getting the socket into the headlight.
    I also wanted to add that after doing this both lit up even when the car was not started where as one one would before unless the car was running.
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    Sorry to resurrect an old thread but can someone that has actually replaced the city light on their B7 A4 advise whether the wire/s leading the city bulb are silver wrapped or colored wires? The space is really tight in there, and I want to ensure I am following/pulling on the correct wires. Thanks.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Aug 13 2007
    NH
    Just replaced mine Saturday (still got the cut up hands to prove it). I am fairly sure the wires were colors. There were only two of them and you can rotate the bulb housing around endlessly, but to remove it you just pull it straight back. I actually found it easier to pull out the DRLs first and move them out of the way. Glad I got mine when I did. There were W5W bulbs in there that had already started to melt the housings.
    Aug 05 2010
    Central IL
    Quote Originally Posted by ThatGuyRyan View Post
    Thanks so much! I wondered whether I needed to remove the DRLs to get at the city light; it was just too late last night and the engine still too hot for me to be comfortable doing that. I told my 11 year old daughter that I would need her small hands and slender fingers next weekend.
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    They are colored wires. And it is much easier to remove the DRLs to get to the city lights. Just did mine a few weeks ago, cost me $11
