Results 1 to 7 of 7
    Nov 15 2008
    Symphony II+ upgrade on B7
    Searched and found plenty about this upgrade on a B6, but nothing specific to a B7.
    I have a 2006 B7 A4 with Symphony II (non-Bose, non-satellite) with factory Bluetooth. Would a Symphony II+ from a 2007 A4 be plug and play or would I need some type of harness/adapter? If so, where to get one in Canada (Toronto)?
    Any input is greatly appreciated.
    Established Member Two Rings remOOOO's Avatar
    Jul 10 2008
    A4/B7 Avant 2.0T Quattro
    Naples FL
    Re: Symphony II+ upgrade on B7
    Yeah if anyone knows the answer that would be great :)
    and what is the cheapest way to add AUX IN to Symphony II+ ?
    just a simple mini jack connector for mp3 player ( I don't need DICE or other expensive stuff)
    thanks
    Senior Member Two Rings AudiA4b6US's Avatar
    May 10 2005
    Chicago, IL
    The II+ radios use the same Quadlock connector as the RNS-E and therefore require a very similar adapter. The pin out is differnt to the RNS-E though. The II+ radios also use a different antenn system, replacing a II radio witha II+ radio may result in poor FM reception. The AUX IN are just 3 pins on the Quadlock connector, adding 3 repair wires and changing the coding will allow the use of the AUX in on the II+ radios.
    Jul 10 2008
    Naples FL
    how to connect a AUX in cable ? some help please?
    there is a pin for aux in in S2+
    how to activate it? should I just add stereo cable to the quadlock connector?
    here is a picture from the back of radio:
    Jul 10 2008
    Naples FL
    bump for help :)
    Jul 10 2008
    Naples FL
    so here I am conNecting everything right now. can someone just let me know do I understand it right?
    those are the pins for AUX IN ( stereo cable with LEFT, RIGHT, and GROUND wire)????
    PLEASE HELP :(
    edit: that Aux ground pin is taken by a purple wire that runs to red adapter end.
    May 06 2009
    New York, NY
    I'm about to buy a Symphony II+ for my 2006 A4. Just curious as to whether or not your install was a success, and if so, what you ultimately needed in terms of parts to make it work. Thanks!
