Results 1 to 8 of 8
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    block 115 wont log
    I know i have a lot of vag com threads lately, but i'm new to it and finally got it all figured out and working. i went to log 115 and it only comes up and says 'n/a' across all the blocks.
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Oct 27 2006
    Pearl 98.5 Audi A4 1.8T
    Fargo, ND
    Re: block 115 wont log
    Are you using the full version on vag-com?
    1998.5 1.8TQT (SOLD)
    Joined the Dark Side
    2008 Honda Pilot SE
    Jun 26 2008
    00' Noggy Stg2
    Yes its the full version of 311.2
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    the current release is 805...? are you using the "free" trial version of vagcom? can you log any blocks above 025?
    Oct 27 2006
    Fargo, ND
    115 is for seeing requested vs actual boost right?
    your car is an AEB and does not have a MAP sensor which is what 115 uses to get the actual vs requested values I think. Someone else feel free to chime in, but I think maybe these are values your car does not produce and therefore are N/A
    2008 Honda Pilot SE
    Feb 27 2005
    North Wales, PA
    no map sensor so there is nothing to log
    Jun 26 2008
    00' Noggy Stg2
    I know the current release is 805, I'm using a registered version of 311. Yes I can log above 025. I didn't know 115 was the map. I'm guessing there is no way to check boost on an aeb with vag com?
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by black99.5a4 View Post
    Correct, there is no way to log boost with the vagcom on a ndbw. If you do want to log boost you would need a data recorder and a map sensor. There are wide band setups that will do this so can actual log boost and AFR at the same time.
