Results 1 to 6 of 6
    May 04 2007
    Northeast
    OEM Bluetooth parts?
    I have the OEM Bluetooth in my car and since I upgraded my headunit, I don't need this anymore. I plan on selling these parts, but does anybody know which parts I need to remove? I believe there is a piece under the passenger seat and the mic located near the sunroof dial. Is there anything else?
    Veteran Member Three Rings mksap11's Avatar
    Apr 06 2005
    Boston, MA
    Re: OEM Bluetooth parts?
    Quote Originally Posted by GrandMarkie View Post
    The BT module is under the passenger seat. The Mic is in the headliner and the BT antenna is connected to the BT module.
    Once you remove things, you'll also probably want to VAG stuff to turn of the steering wheel controls
    Senior Member Three Rings blackbox619's Avatar
    Oct 24 2008
    nyc
    what oem head unit did you have before you upgraded it? symphony or an aftermarket?
    ~~ engineered in germany... modified in brooklyn ~~
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    not to hijack, but does anyone know if you could take the bluetooth unit out of an A4 and hook it up to the stock head unit in a VW (jetta)?
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    May 04 2007
    Northeast
    Quote Originally Posted by mksap11 View Post
    Excellent, thanks
    Quote Originally Posted by blackbox619 View Post
    Symphony II plus which was just sold.
    Nov 16 2007
    08 A4 2.0t DG S-line Titanium
    Queens
    Excellent, thanks
    How much do you want to for the BT unit and mic???? I'm interested in it possible.
