Results 1 to 14 of 14
    Nov 15 2008
    Istanbul, Turkey
    Thumbs up BRP Motorsport Cupra R 1.8T GT3076R Build, Unitronic 850cc @ 4 bar (Include Pictures)
    We assembled all the parts we need in following list and started over for building our car, Engine is completed, software tune made by Unitronic, we used 850cc bt file. Next thing to do is putting engine back in the car with its new specs then start the engine and see what will go on
    I will make a run in for engine first for about 700-800 miles then we can pull it and make a dyno run, I will share results here when done.
    BTW, Car is: BAM Engine 2004 Seat Leon Cupra R 1.8T 225 6SPD FWD
    Not Audi but same engine
    So here we go,
    Unitronic 850CC Big Turbo File
    Garrett Dual Ball Bearing GT3076R Turbo
    ATP Turbo Heatshield
    ATP Precision Cast High Flow Turbo Manifold - Polished by BRP
    ATP 3” V-Band Downpipe
    ATP 3” V-band Discharge Module
    ATP Oil Inlet/Outlet fittings w/oil control
    ATP Steel braided oil feed and return line assemblies
    ATP Coolant fittings with AN style discharge/return
    ATP Steel braided coolant line assemblies
    3” Turbo Back Exhaust /no cat
    Tial 38mm External Wastegate
    FORGE Supersize DV
    SCAT Forged Piston Rods
    ARP Rod Studs
    SUPERTECH Forged Pistons 8.8 Comp, 82.5mm Bore
    034 Motorsport Anti-Friction Coated Main Bearings
    034 Motorsport Anti-Friction Coated Rod Bearings
    New South Intake Power Gasket
    CAT 3652 CAMS
    CAT Adjustable CAM Gear
    CAT Springs
    Non-VVT Tensioner
    Greddy Oil Catch Can
    HKS New-Type Turbo Timer
    AEM Wideband UEGO Controller
    AEM Oil & Water Temp
    Greddy Profec B Spec II Boost Controller
    HKS RS Boost Gauge
    Digital EGT
    HKS Circle Earth System
    034 Motorsport Carbon Coil Cover
    BRP Motorsports Short Shift
    Bosch Motorsport 044 Fuel Pump
    Bosch 4Bar Fuel Pressure Regulator
    Delphi 850CC Injectors
    N75 Canceled
    N249 Canceled
    MAF Canceled
    Dahlback Intake Manifold
    Front Mount Intercooler
    2,5” Intercooler Piping
    4” Intake & 4” AEM Filter
    SPEC Stage 3+ Clutch
    SPEC Stage 3+ Flywheel
    Unorthodox Racing Underdrive Pulleys
    Vogtland Racing Performance Coilover
    Stock Brembo Brakes
    ECS Engine & Tranny Mounts
    MOTUL W-300 Race Oil
    And some pictures
    Nov 15 2008
    Istanbul, Turkey
    Re: BRP Motorsport Cupra R 1.8T GT3076R Build, Unitronic 850cc @ 4 bar (Include Pictu
    Nov 15 2008
    Istanbul, Turkey
    Special thanks to our best mechanic Firat Kucukbas :beer:
    Nov 15 2008
    Istanbul, Turkey
    Built by BRP Motorsport ( Oytun Öztümer & Tugrul Koselerden )
    Custom Software by: Unitronic BT
    Installation: Rosso Corsa ( Firat Kucukbas ) & BRP Motorsport
    Made in Turkey
    http://www.brpmotorsport.com
    http://www.unitronicturkey.com
    Veteran Member Four Rings DeanUW's Avatar
    Feb 22 2007
    Lots of stock parts :-)
    Auburn, WA
    Very nice!
    Deanophotography.com | The A4 (Updated 3/1/10)
    REVO Tuned GTRS Eliminator
    Caractere | Evolution Racewerks | Southbend | STSIS | ATP | QTP | Magnaflow | Samco | OEM | VMR | Defi | TurboXS Dtec w/ Gameboy
    Senior Member Three Rings MartyinCO's Avatar
    Sep 21 2008
    Ducati Monster 900
    Thornton Colorado
    First 4 pictures, amazing
    Then the 5th picture, Stickers
    Great engine build though
    It's so much easier to suggest solutions when you don't know too much about the problem.
    Malcolm Forbes
    Senior Member Three Rings Allan T's Avatar
    Sep 28 2006
    Audi a4 b7 2.0 Tfsi quattro avant sline
    Sweden
    Nice project and cool car
    Mod list = To long to write.
    http://www.garaget.org/?car=118660
    Nov 15 2008
    Istanbul, Turkey
    sorry for latement :) 30r detached...
    35R Coming now ;)
    Veteran Member Four Rings Monchichi8's Avatar
    Jul 03 2004
    2004 S4, 2005 Grand Cherokee Hemi
    Boulder,Colorado
    very nice!!!
    Veteran Member Two Rings rs_t's Avatar
    Mar 12 2005
    Norway
    Great build!!
    - 2016 RS6 - Nogaro Blue
    - 2017 718 Cayman
    - 1987 911 Carrera 3.2
    Nov 19 2005
    Pair of (. )( .)
    i love how Seat looks :)
    Nice build :)
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Senior Member Three Rings A4 Dream's Avatar
    Sep 01 2008
    B5 A4
    Tacoma, Wa
    looks great guys. keep it up
    Registered Member Two Rings Pedros4's Avatar
    Nov 04 2008
    2005 Audi S4 imola Yellow
    Lowell,Mass
    my cousin has one of those in brazil...
    had to send a couple of parts for him the other day....
    2005 b6 imola yellow S4 6mt...loving it
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    That car is amazignly beautiful!
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
