Results 1 to 7 of 7
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    cat failed readiness on vag com
    What would make the cat and evap fail the readiness on vag com? my cat doesnt stink or act clogged. maybe its just on its way... anything common that would make the evap fail?
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Feb 29 2008
    PA
    Re: cat failed readiness on vag com
    you have vagcom in lititz? you should meet up with pacman and i someday
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    when was the last time you cleared the codes (reset the ecu) its take a couple hundo miles for those codes to set readiness.
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Jun 26 2008
    00' Noggy Stg2
    Quote Originally Posted by merrigan View Post
    nic and i met up tonight, matt. my laptop died shortly after it was connected.
    nic and i also did 4-5 runs in mexico tonight. hehehe
    Jun 26 2008
    00' Noggy Stg2
    Quote Originally Posted by maxspeed View Post
    I just got chipped today, i had absolutely no stored codes at all.
    Dec 14 2005
    Quote Originally Posted by black99.5a4 View Post
    check your readniess again in another 200 or so miles, im sure theyll be set to passed as soon as you still have a cat.
    1999 Subaru Outback
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Should be able to force a readiness check by using block 086 IIRC.
    Here is some more info:
    http://www.mycarbl0ws.com/audi_b5/Fu...ess%20code.pdf
