Results 1 to 33 of 33
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Dual projector headlights? Yes, we can!
    Dibs on the design.... the high beam projector is just sitting inside a canibalized joey mod housing. I'm working out the details before using these two projectors as the high beams for the e-codes I just got. Then, I will be putting in LED's in the B8 pattern, joey-modding the e-codes, and hoping it turns out OK.
    So far:
    Again, before someone rips them for being "off", the high beam projector is just laying in there. It is not pointed exactly as I will have it once completed. I'm not fuzor-ing that in until I do the install on the e-codes. And imperfections are because these aren't done or even the housings the completed ones will be done in.
    And what you can't see in the pics, since the hood is closed, is that the front bumper is just resting in place, and most every hose and wire and anything I could pull of the block is completed. Tomorrow I'll get to service position and work a little more on the headlights.
    My 2004.5 APR Stage 3+ is SOLD
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    Re: Dual projector headlights? Yes, we can!
    Honestly...I think it looks great, even without having to explain yourself! Can't wait to see it done.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    I <3
    -Sami-
    Feb 28 2006
    Pittsburgh-Philly
    Quote Originally Posted by coowhip View Post
    Thanks. The advance disclaimer was just because we have some people who will stare at a pic for an hour just to find something wrong. Well, no ish on these 'cause they ain't done.
    I'm more interested in the opinion of how it would look finished based on this preliminary throw-together. Thanks for the props.
    Oh, and I did run the bulbs to see how the projector looks as a high beam. The mains are HID/Xenon, but I'll use a hyperwhite H7 for the highs. I was thinking HID, but the problem is that HID's take too long to fire up for a high beam. I did take out the metal beam blocker in the high beam projector housing, though. On the main low beam projector, that metal piece cuts off a lot of the light output, probably to keep it from being above a certain height and blinding oncoming drivers. But that beeyatch is gone in the high beam projector and it's like a Grizwald Christmas when that puppy fires up now.
    Veteran Member Four Rings 20A4Audi1.8t01's Avatar
    Oct 08 2005
    '16 SQ5 '07 Corvette
    Orlando, FL
    looks good so far!
    -Brilliant Black 01.5 A4 1.8T Fronttrack Tip-
    GIAC Hammer KO4|APR TIP|Modded Carbonio V2|RaceTec FMIC|Forge 007p|SPP EFK|PSI TP|TT 2.5 DP|Custom 2.5 Magnaflow Exhaust|15% LLumarTint|215/40/18x8.5 RS4 Reps/Nitto Neo Gen|Ecodes|RS4 Grill|H&R Coils|Rieger Roof Spoiler|Pioneer AVIC-D3 NAVI|Cadence 10|JL Audio A6450|Almani door speakers|Cadence amp|8000K HID|3000K HID Fogs|In Pro mirrors|S4 Front/Skirts/Brakes|Cupra R lip|Apikol snub|All Red Tails|Shaved Euro Trunk
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    I like it too. Hmmm, I have a spare set of lights also and a DD so....
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Dec 06 2007
    props Lee they look amazing, what i would've done was rotated the projector 180 degrees so the part that sits flat could make it look somewhat OEM, but other than that i think it looks killer.
    -Kirk
    BetaAlphaTau Member #58
    Oct 22 2005
    Reppin the Mitten.
    sik
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    I like it. It's definitely an improvement on the factory mismatched pair of highbeam and lowbeam reflectors/projectors.
    Thing is though, I cant see past the two chrome circles around the projector lens. I always though it looked pretty tacky.
    something about the design is too drab, and "afterthought"-like.
    Whereas our projector is more of a CONCAVE design, I really like more of a CONVEX design. Think, Frog eye vs. Satellite dish.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Feb 28 2006
    Pittsburgh-Philly
    Quote Originally Posted by AudiA4Turbo22 View Post
    Yeah, I'm messing with that tomorrow a little bit. I put that flattened out part on the bottom and it looked OK from some angles, but on others, it looked too asymetrical; it's almost like the flat parts should both face the same way or else something doesn't look right. And i can't really turn the low beam so the flat part faces down on it, as I need that curved in part to form around the high beam portion.
    Since my car will be up on blocks until maybe April, I'm in no rush. I'm gonna mess with it a little, take a day to step back, and then come back to it again over time until it flows the way I see it in my head.
    Quote Originally Posted by A4 Moda View Post
    I understand what you mean. But I gotta play the cards I was dealt.
    On that curved-in flat portion on the high beam projector, I was thinking of taking out the turn signal housing from the old headlights, rotating it so the curve matches the high beam flattend part, and install it as a "fourth ring" in the e-code housing medial to the high beam. I'm going to get a general idea of how that will look tomorrow. I just don't know what I'd use it for. Maybe retrofit it for another H7 and have it come on as a second high beam. I don't know. We'll see.
    Kind of like this:
    Mar 21 2006
    Lakeland, FL.
    City lights.
    I'm back bitches!
    Feb 28 2006
    Pittsburgh-Philly
    Quote Originally Posted by dirtybrd View Post
    City lights.
    But that would be too much with the devil eye LED's I'd think. I could even make it another turn signal, so both ends blink ambers.
    We'll see.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Looks cool
    Veteran Member Four Rings jon102034050's Avatar
    Oct 02 2006
    MN
    very nice, do u have any pics fabbing it?
    A4 1.8TQ - RS4 Sway - Avic-D1 - Neuspeed Sports - Bilstein Sports - Joey Mod
    Registered Member Three Rings
    Aug 06 2007
    02 Audi A4 1.8T Q Tip
    New Jersey, USA
    looking good Lee.... nice fore-sight and work
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    im on the fence. the chrome make it look like ugly angel eyes but i guess ill wait to see the final product.
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Jun 30 2007
    Raleigh, NC
    Quote Originally Posted by rxrep View Post
    hate to break it to you but i already tried this quite some time ago with some a6 xenon projectors (they were too big), and i may give it another go since a friend of mine has some TL bixenon projectors.
    its good to get a better idea of how it could look though, i focused mainly on getting the projector mounted inside the housing and never got around to the cover since i was already angry after doing the work just to realize it wouldn't ever fit right. are you using a second set of A4 low beam projectors?
    also, along this same note it might be worth mentioning that i found some VERY small projector fog lights (that were inside the headlight housing of some shitty old plymouth sedan) which im going to try and fit as some fogs since they're H3, much tinier than the stock fog housings, AND projectors. could be a good option if space is tight with intercooler pipes (not a problem for too many people on here) and if you're interested i can go back to the junkyard and find out what i ripped em off of.
    props for the work, lee.
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Veteran Member Three Rings supercooloptw's Avatar
    Feb 20 2006
    Minneapolis, MN
    I like it.
    In Limbo Four Rings
    Sep 27 2006
    2005 Audi B6 1.8t Ultrasport
    New Jersey
    wow.. how much for that.. haha. that looks HOTTT haha.
    Veteran Member Four Rings 3.0L AUDI A4's Avatar
    2004 A4
    Central Jersey
    Romell You don't have money!!!
    BTW Romell, I have my Vag Com with me so whenever you wanna stop by...
    PM ME
    Veteran Member Four Rings Turbo1A4's Avatar
    Aug 04 2008
    2002 s4 nogaro
    Jax
    looks sweet i cant wait for the finished product
    Veteran Member Four Rings Undisputed's Avatar
    Jun 29 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    Very nice. I think it looks great.
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
    Dec 06 2007
    u know what else u can do some dude on ebay sells projectors he made himself just the projector, u could cut the OE high beam reflector and add the projector in the center. Just putting it out there maybe u'll come up with something ingenious.
    -Kirk
    Feb 28 2006
    Pittsburgh-Philly
    Quote Originally Posted by B6Lovin View Post
    I knew that. I mean I have dibs on THIS design, lol, using the low beam projectors from my old set as the highs for me new e-code set. They fit with bulbs in. Back covers fit on and everything. It's tight, but it fits.
    I really wish I had a second set of e-code round turn signal housings, because I'd put those on the center side of the high beam projector. Then it would be like an abstract "four rings". Then I could always make that second turn signal housing in to a second high beam or added fog light that helps friggen turn the night in to daylight.
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    Lee, who gave you this idea?
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Feb 28 2006
    Pittsburgh-Philly
    Quote Originally Posted by Maverick View Post
    Between AZ and AW, people have talked about it for years. Nobody usually has the extra set, and not many know how to work with fuzor or duramix to reform plastic.
    May 03 2007
    german
    heaven/hell
    call this Lee's Projector lights
    Mar 21 2006
    Lakeland, FL.
    The "Lee Mod"
    I'm back bitches!
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    that will teach people to go under the speedlimit
    Feb 28 2006
    Pittsburgh-Philly
    I've expirimented with taking the turn signal of the old housings, flipping it, and moving it over medial to the high beam projector (closer to center of car). Its rounded contour follows the lines of that indented portion of the high beam projector perfectly and takes up the space that's left.
    With that, I wired in an H7 socket from out of the old high beam. So, when the high beams come on, it adds two extra H7 bulbs.
    It is bright. Blinding bright.
    But we'll see how the final design turns out.
    And the beauty of it all is that it's got Valeo stamped everywhere and a nice big DOT sticker on it from the old US-Spec housings, lol.
    Kind of like this pic below. But please note on this pic that the e-code turn signal, high beam projector housing, and old turn signal housing towards the center of the car are all just sitting inside there. As such, they are pointing every-which way. The center "old turn signal turned 2nd H7 high beam" won't sit up centered until it's fuzed in, so before anyone says it, of course it will be moved up, aligned, and centered in.
    This is just in the "idea" stage right now. When everything is held in place it does have an abstract "four rings" look to it as the e-code turn signal does come up against the low bean project when in the right spot. I wish I had a second pair of e-code turn signal housings for the center 2nd high-beams..
    I did have bulbs in everything, and even though it's all pointed every which way now.... it's really bright with two high beam bulbs. I think it will be sick when everything is lined up and fuzed in.
    Sep 02 2005
    Montreal
    I think it would look better if the inner projector was a Bi-Xenon.
    Veteran Member Three Rings Shak's Avatar
    A4 B6
    Northern VA
    whoa definitely kudos to you for trying this!
    And I thought the joey mod was difficult.. ths is just MADNESS.
    2002 A4 Quattro Tiptronic w/ Sport Package
    Mods:
    Cleared Corners; Headrest Mod; Symphony II+; Aero Wiper Arms and Blades; Painted Lowers; RS4 Rear Sway Bar, 35% Window Tint
    Feb 28 2006
    Pittsburgh-Philly
    Yeah, but like I said, I gotta play the hand that was dealt to me.
    I've got all kinds of ideas asto what to do, but I don't have the parts laying around to do it. So I'll do it to show it can be done and hope someone else down the line improves on it all.
