Results 1 to 40 of 58
    Feb 18 2004
    cape cod
    GTRS ---> 3076R, what hardware do I need to change?
    I've decided to ditch the GTRS and go with the 3076R. What hardware do I need to change out to make the swap? I've already got a nicely built motor from QED.
    http://i78.photobucket.com/albums/j1...gpicCustom.jpg
    QED Built Motor/PP'd head, Revo GTRS.
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Re: GTRS ---> 3076R, what hardware do I need to change?
    Quote Originally Posted by jayt991 View Post
    * Manifold
    * Downpipe
    * Turbocharger
    * Compressor inlet silicone hose
    * Turbo coolant/oil feed and return lines.
    If you are interested send me a PM as we are just getting ready to release the complete GT30XX hardware kit.
    Jun 30 2007
    Raleigh, NC
    ^don't forget new rods...
    or if not that: a new block, pistons, rods, crank.... etc
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    May 24 2007
    Southern California
    it says he already has a builld motor from QED tho^^^
    Kyle
    2.0L Revo GTRS Eliminator
    Feb 26 2006
    Earth
    Quote Originally Posted by B6Lovin View Post
    Ah yes...forgot about the rods
    Jun 30 2007
    Raleigh, NC
    Quote Originally Posted by A4natomical View Post
    yeah, i didn't word that very well.
    i was talking more to issam about a "complete" hardware kit for a 1.8T to jump right to a 30 series
    The Awesome™
    May 24 2007
    Southern California
    oh gotcha.
    Kyle
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    And probably new injectors unless you have 630's.
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Obviously new hot side piping for the intercooler
    -Sami-
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Better clutch and bigger FMIC.
    Jun 30 2007
    Raleigh, NC
    and possibly cold side too if he gets one of the intake manifolds and a bigger TB that are out/coming out. nobody makes a kit that will fit those yet... so custom piping it is.
    The Awesome™
    Feb 19 2007
    Charleston, SC
    quick off topic question:
    On intercooler piping if you are using worm-style clamps and have rolled edged on teh pipe....how tight do the clamps really have to be? I ALWAYS seem to pop the T-bolt and worm style clamps all the time....I guess I am tightening them way too much...
    -Sami-
    Jun 30 2007
    Raleigh, NC
    how flush do your pipes sit? you want them to sit as close to end-to-end as you can get them so that the couplers just have to be snugged up on them. if the pipes have to be pushed into place or have a gap between themselves and the next pipe it's a lot more likely to blow off - no matter what you do. (ask me how i know)
    and i get my clamps pretty tight just to make sure
    The Awesome™
    Feb 18 2004
    cape cod
    I've already done the clutch, FMIC.
    Head's been port and polished, 20mm wrist pins. Blocks ready for sure.
    Whats the difference with going with a TIP or without one?
    Veteran Member Four Rings Siggiepop's Avatar
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    i'll take your injectors if you're selling em
    CT4952
    Jul 07 2004
    socal
    What clutch and FMIC?
    TIP = MAF setup or intake placement away from turbo
    No TIP = Mafless and filter bolted to turbo, less restriction
    Feb 18 2004
    cape cod
    OCT FMIC, and OFE SS.
    Which setup is more recommended for a DD, MAF-less, or with the MAF?
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    I would like to know more about that as well. I'm assuming its all in the programming?
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Jul 07 2004
    socal
    Quote Originally Posted by HIERLEVELZ View Post
    Well the nice thing about mafless is that there is 1 less wear item that can throw off the tuning. But with mafless the tuning has to be much more refined since it is no longer using the MAF to figure out load.
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    MAF is better for DD.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Feb 18 2004
    cape cod
    I'll be running the old REVO 430 file, what's the general consensus on injectors...550's, or 630's?
    Jun 13 2005
    Audi
    Depends on what MAF size.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    You'll need 630's for the 3076R. 550's won't be able to keep up.
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    630s cant keep up either on my 2.0
    Dont know if it is because I have 2.0 and cams and the 3076 or what but I am in the 90s for duty cycle at 24psi in the upper rpm range. That is only going to 7200, I dont know what will happen revving to 8000+
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Jul 07 2004
    socal
    Quote Originally Posted by actlsub9 View Post
    Well that really doesn't matter unless the ecu has to pull back so much fuel that it causes the fuel trim readings to max out. This is the advantage the 2001+ A4's have because of the wide band 02. Now if we were talking narrow band it would have a huge effect during WOT.
    Quote Originally Posted by A4 TSCHUSS View Post
    Well you really won't know that till the car actual starts to lean out up top even though you keep throwing more fuel at it.
    Feb 18 2004
    cape cod
    Quote Originally Posted by Condo View Post
    630's with a 3" housing?
    Apr 16 2007
    Queens
    Does Unitronics and the like provide a Mafless tune? I need to remove that cluster fuck intake I have and put a filter straight onto the turbo.
    2003 A4 1.8TQM
    Jun 13 2005
    Audi
    I was under the impression that the ECU could pull back up to 25%.
    630s are 43% larger then 440s.
    That is, if you are still using the stock MAF size.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Since when? Your logs of the new fuel pump show things are alright. And the REVO files run a tad on the lean side anyway (relatively speaking). Our engines like to run slighty rich.
    -Doug
    Oct 29 2005
    10speed
    San Francisco, CA
    yes
    - Clint
    Feb 26 2006
    Earth
    Eurodyne offer MAFLESS tunes but your set up must be constant to the package.No deviation or else you are looking @ mail order tuning for 3 weeks.
    Jul 07 2004
    socal
    Yes for idle/part throttle and I dont think that counts for decreasing fueling thru lemmiwinks.
    Jun 30 2007
    Raleigh, NC
    how do you figure that? other than my current problem which is due to a totally unrelated issue, my car has always driven, idled, started hot or cold, and boosted just like normal. GTRS and 3071R
    yes they do, and it makes things a lot easier to work on/look at when it's time to get under the hood if all that crap is gone.
    The Awesome™
    Apr 16 2007
    Queens
    Anyone running a MAFless Elim setup? Just curious how they setup up their filter.
    2003 A4 1.8TQM
    Apr 24 2005
    E55 AMG, CTS-V
    I am at like 94% duty cycle at 24psi and I have a 7200rpm limiter so I dont even know what it will do if I spun 8200 which my head is ready for. So I dont see how that is alright. If I turn my boost to 27psi like Shawn was running I would be over 100% duty cycle. Last time I checked tuners want the injectors running in the 80s and 100% duty cycle is not a good thing. So call me crazy but that is definitely not alright.
    ~David~
    CTS-V 9.6@148
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I did not realize that.
    Guess you need some 880s then.
    -Doug
    Jun 13 2005
    Audi
    Why would you want to run MAFless with a filter with an eliminator?
    The stock MAF is larger then the compressor inlet, so the MAF is not going to be a restriction.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Apr 16 2007
    Queens
    When I say filter I mean a screen so no FOD gets into the turbo and messes up the compressor/turbine blades.
    2003 A4 1.8TQM
    Feb 17 2005
    Sarasota, FL
    What Greg said still applies, the stock MAF diameter is larger than the GTRS inlet so it is not a restriction. And FYI, a screen provides more restriction than a filter
    Dec 03 2005
    2 pedals 1FG
    connecticut
    just so it looks 'cool' when you pop the hood
    the whole point (as i see it) with the eliminators is to make the engine bay look 'stock-like' yet the car makes more than double the power than it did stock.
    -Doug
