Results 1 to 40 of 57
    Veteran Member Four Rings S4evr's Avatar
    Mar 07 2007
    Belmont, MA
    Crazy cylinder misfires = need cylinder diagram?
    Hey guys, my car's been having a lot of misfire problems lately, it has progressively gotten worse over the past 2 weeks. Before i could run just about full boost with out it misfiring, but now i can barely hit any boost at all before the car feels like its not moving anywhere and misfires across all cylinders.
    When looking through VAG-COM with J-tec, we tested group 015 and 016 (the idle misfires, 015 = cyl 1-3, 016 = cyl 4-6.) Here are the results of the misfires at idle(based over 1 minute)
    Cylinder 1: 4 misfires
    Cylinder 2: 8 misfires
    Cylinder 3: 12 misfires
    Cylinder 4: 35 misfires
    Cylinder 5: 30 misfires
    Cylinder 6: 20 misfires
    Now what J-tec was thinking is that its both of my ignition control modules, based on this reading and the fact that i have no misfire fault codes. I was thinking that it could be coil packs? I just replaced my spark plugs about 400 miles ago and that seemed to 'bandaid' the problem for a little while, but it came right back soon after. The plugs i'm running are NGK BKR7E's and are gapped to .28. I'm AWE Stage 3+ and would like to feel what full boost feels like again lol
    Does any one have a cylinder diagram of the 2.7t motor? or know what order the cylinders are?
    If anyone has any ideas, post up!
    The S4 and J-tec's jetta
    ThorTechnik.com
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: Crazy cylinder misfires = need cylinder diagram?
    Looking @ the car from the nose to the trunk its
    1 6
    2 5
    3 4
    Sounds like ICMs, your plugs aren't really gapped right, or somehow all 6 of your coils went out (most unlikely) swap your ICMs with a friend.
    Unless you somehow have some MAJOR boost leak, but I think with those kind of misfires being caused by a leak you would hear the hissing from a mile away.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    4,5,6 def look like an ICM. Its kinda werid that both went out at the same time, but it could be a combo of older coil packs and spark plugs not gapped properly.
    if you narrow it down to a bad ICM or coil packs, mine were all fine wen my car got totaled. And im in buffalo. Its just an option if you find out wats bad.
    Oct 31 2005
    Ashburn
    ICM, coilpacks def.
    - Instagram: @Sinister_rs5-
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    How's your AFR?
    I had multiple missfire also and changed plugs, icm's and still missfires.
    We found that my EGT's are bad and make my ecu throwing gaz like crasy to cool things down. I Was going down as low as 9.6:1 to 10.2:1 ratio and gaved me very bad missfires.
    It was missfiring under load tho.
    We only eliminate them in the tune until i find new ones. They are rare and expensive.
    You could have something else there. Check vaccum leaks or boost leaks.
    I don't believe that all coil packs can fail at same time
    Hope that helped G.L.
    Mar 07 2007
    Belmont, MA
    all of the coilpacks may not fail, but could it be a combination of a bad icm, and a few bad coilpacks? i dont think i have a vac leak, my boost gauge sits right at 19 during idle, always has. and i dont feel like it is a boost leak either. the problem has gotten progressively worse. at first i couldnt do more than 15lbs of boost, then switched to new plugs and that bandaided it for a day, next day came back; couldnt boost past 15lbs. a few days later couldnt get past 10lbs without it misfiring, then a few days later 7 lbs, and currently its at 5 lbs with an occasional misfire within vacuum/5psi. The car does have 105,000 miles on it and has been stage 3 for 20,000 miles. to my knowledge ICM's, or coilpacks have never been changed.
    ThorTechnik.com
    Mar 07 2007
    Belmont, MA
    Quote Originally Posted by Rated S View Post
    1 6
    2 5
    3 4
    So, cylinders 1-3 are on the passenger side, 4-6 on the driver side and cylinders 3 and 4 are the ones closest to the front of the car?
    ThorTechnik.com
    Veteran Member Four Rings jballou's Avatar
    Mar 19 2005
    2007 Honda Fit
    Corona, SOCAL
    Ah that picture is wrong.. Don't post up wrong information.... All ways check before you post.
    2000 Audi S4 Stage 3,000 Million +
    Some crap just thrown together, puzzlingly making more power....
    YouTube Channel: http://www.youtube.com/user/jsballou
    www.tvme.info
    Mar 07 2007
    Belmont, MA
    if the diagram is incorrect, how is it supposed to be?
    ThorTechnik.com
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    wish i was at home and not at work, i have every diagram for everything on my computer...
    Oct 14 2007
    Val-Belair
    Cylinder 4 to 6 are ok on the pic above.
    Cylinder 1 is here
    through 3 at the back of passenger side.
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    You've got to be kidding me. I've got to go find and beat up the person that informed me differently then.
    Mar 19 2005
    2007 Honda Fit
    Corona, SOCAL
    Allways take information on any Forum with a grain of salt until you can back it up with information from researching yourself.
    www.tvme.info
    Mar 07 2007
    Belmont, MA
    alright so i talked to my mechanic today that has done some maintenance work on my car before and told him my problems. i told him its been getting worse and worse slowly (at this point i can barely drive it, its starting to misfire at idle). he asked if the misfiring worsened when the car was cold or hot. i had to think about it for a second but i realized it definetly gets worse as the car warms up. he told me it was probably my preliminary o2 sensors that were dieing.
    any ideas on that, dead primary 02 sensors? here are the codes i pulled approximetly 4 weeks ago when the car started acting up. pulled them again yesterday, same thing
    16815 - Warm Up Catalyst: Bank 2: Efficiency Below Threshold
    P0431 - 35-00 - -
    16805 - Warm Up Catalyst: Bank 1: Efficiency Below Threshold
    P0421 - 35-00 - -
    i always thought those codes were because i have no cats at all, but are they related to dieing preliminary 02 sensors?
    ThorTechnik.com
    Oct 31 2005
    Ashburn
    Those codes should be from not having cats and should not cause the issue's your having.
    On a side note, The o2 sensors in B1 will cause misfire badly as well as a EGT.
    I was getting misfires just like you and i had a o2 code for B1 S1 replaced the sensor and it still misfired but threw no codes for months until 2 days ago. Same B1 S1 code/ no activity so i respliced the sensor and took it for a drive and did some WOT pulls and it pulls hard and no CEL so far. See if you can log your front o2's. That's probally what it is.
    Senior Member Two Rings J-tec's Avatar
    Jun 27 2008
    2001 Jetta 1.8t - 50 Trim .63
    Boston
    ^^ your post is kind of confusing, so you're saying that the codes he's getting won't cause the misfires, but the front o2's will? isn't bank 1 a front o2 sensor?
    Nov 23 2004
    B5 S4 Built Motor GTX28's
    NH
    Long shot, have you tried unplugging the MAF sensor? See how it runs, could be a bad MAF.
    B5 S4 Built motor GT28X's
    08 3.2 A3 DSG DD
    Mar 07 2007
    Belmont, MA
    if it were a bad maf and i unplugged it, it would run fine but make no boost correct?
    ThorTechnik.com
    Mar 07 2007
    Belmont, MA
    Quote Originally Posted by J-tec View Post
    bank 1 is passenger side cylinders, bank 2 is driver side cylinders.
    ThorTechnik.com
    Nov 23 2004
    NH
    You should be able to make boost, car will run in speed density mode, will run a bit rich. If its gone bad it will run normal when unplugged.
    08 3.2 A3 DSG DD
    Oct 31 2005
    Ashburn
    Didn't he say the codes were from not having cats. Not pre-cats. the o2 sensors located near the precats are the ones to worry about not the ones near/or on the main cats.
    Mar 07 2007
    Belmont, MA
    i have no cats, and no pre-cats. i always thought those codes were for no pre-cats.
    ThorTechnik.com
    Mar 07 2007
    Belmont, MA
    Quote Originally Posted by Blue AWD View Post
    if the maf is still good, will it run bad if i unplug it, or notice no difference?
    ThorTechnik.com
    Nov 23 2004
    NH
    Should run about the same, if its gone bad, you will know it.
    08 3.2 A3 DSG DD
    Mar 19 2005
    2007 Honda Fit
    Corona, SOCAL
    Did you check your ignition amp modules. Those cause the car to mis-fire.
    www.tvme.info
    Veteran Member Four Rings Big Boost's Avatar
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    I just replaced the unit for bank one and I'm still throwing codes. I don't have any O2 codes at all, so I guess I'll check the EGT.
    2015 Audi A3 Stage 3+
    2001.5 Audi S4 VRT
    Mar 07 2007
    Belmont, MA
    ok, sort of an update:
    i unplugged the maf today to see how it would run. ran beautifully during start up, and my 5 minute drive to the gym. the coolant temp gauge didnt budge on the trip so the car was cold the whole time. as soon as i leave the gym, i take a longer way home to let the car warm up. once the coolant temp gauge reaches the midway point where it is supposed to sit, about a minute later the misfires start to happen. not too bad, just when i reach 0 vac, 0 boost. about 5 minutes later my oil temp gauge starts to budge, and at this point its idling pretty bad, sounds and feels like a cammed muscle car.
    So, from this test i can conclude that the car only misfires when it is fully warmed up, even with the maf unplugged. is this a sign of dead preliminary 02's, egt sensor? whats goin on?!?!
    ThorTechnik.com
    Mar 19 2005
    2007 Honda Fit
    Corona, SOCAL
    Could be a leaky Injector...
    www.tvme.info
    Mar 07 2007
    Belmont, MA
    ^ doubt it, i dont smell any fuel. Also, keep in mind the misfiring really only happens once the car is fully warmed up.
    i have been talking with marc and he thinks it is the coolant temp sensor. can a coolant temp sensor cause misfires like this?? i was not aware they could
    ThorTechnik.com
    Mar 07 2007
    Belmont, MA
    update:
    replaced coolant temp sensor, and #4 coilpack. does not misfire at idle anymore, but still misfires under low boost. havent tried making full boost yet. could it be more than one coilpack that was bad?
    ThorTechnik.com
    Mar 07 2007
    Belmont, MA
    update #2:
    just got back from a drive and did 2 WOT runs. first run got it up to 20psi but when i got there there was SEVERE backfiring. the car behind probably got a torched bumper lol. big cloud of blackish/grey smoke. basically sounded like the car was breaking up. no cel came up, so i did it again. same thing happened, real loud backfires and this time a flashing cel. i let off the gas and drove normally, and then the flashing cel went away completely. continues to drive fine up to about 5 lbs.
    what the heck is going on?
    ThorTechnik.com
    Oct 31 2005
    Ashburn
    The Benley manual protcol for misfires , obv. there are some tools we don't have that the dealer does. But first is to check coilpacks and plugs, then injectors. there's more to it but i have to cut and paste it if i can.
    As stated before i have same issue as you but i'm getting misfires at 5psi/ partial throttle
    I still say it's your front/bank 1 o2 sensors. I'll include a link that might have some good info, as my laptop is shit i did see that my o2 bank 1 sesor 1 @ idle is at zero and @ partial it's -.8 as the Bank 2 sensor 1 has the same value at idle and partial. If you read the link you'll know what i meen.
    Hell i'll just copy it into the post.
    Fuel Trim Info
    Updated 29 Mar. 2005
    Ross-Tech is not responsible for any damage or problems that may result from following these instructions. They are to be used at your own risk.
    Understanding Fuel Trim:
    Some of the most common fault codes (DTC's) pertain to fuel trim (rich mixture, lean mixture, etc.) Here is an explanation of fuel trim and what it does for us.
    The ECU controls Air/Fuel mixture in order to maintain power, efficiency, and emissions. A/F is expressed as either a ratio (14.7:1 for example) or as a Lambda value. With iso-octane ("ideal" gasoline), Lambda of 1.0 is equal to 14.7:1 A/F. This is known as "Stoichiometric", a condition where there is a perfect balance between oxygen molecules and the various hydrogen and carbon based molecules in petroleum. With the oxygenated gasoline that most of us use, actual A/F ratio of 15:1 is closer to stoichiometric.
    If Lambda is greater than 1.0, then there is a surplus of air and the engine is running lean. If Lambda is less than 1.0, then there is a surplus of fuel and the engine is running rich. It should be noted that the ratios are mass-based, not volume-based.
    So, why don't we always run at 1.0 all the time? Well, we do MOST of the time. At cruise and idle, mixture is held tightly to 1.0 to keep the catalytic convertor at optimal efficiency, so the emissions are minimized. However, when we need acceleration, the mixture gets richer. Why? Maximum power is made between 0.85 to 0.95 Lambda (12.5 to 14.0 A/F with iso-octane). So, under acceleration, mixtures get richer. Sometimes you want to get even richer under acceleration to keep detonation (pre-ignition of the mixture from excess cylinder temperatures) away. The 1.8T has a relatively high compression ratio for a turbocharged engine, which especially under lots of boost, is very succeptible to detonation).
    So, now that we know that the ECU wants to be able to control the A/F ratio. It has a prescribed set of values (maps) for a given RPM, Load, etc. So, the ECU tells the injectors to pulse for exactly XX.X milliseconds and that SHOULD get us the proper A/F ratio that we want. Well, if you tell an employee to go do something, you want to make sure they actually did it, right? The ECU has some snitches (the front O2 sensor and the MAF, for the most part) that will report back whether or not the desired mixture has been attained. The rear O2 sensor is used mostly to monitor the condition of the catalytic convertor, although in some applications it also contributes to trim information.
    Based on feedback from the snitches, the ECU learns to apply a correction factor to its commands to the fuel injectors. If you know that your employees take longer than the standard allotted time to do a specified job, you will need to adjust for that in your planning (injectors are in a union, so it is tough to fire them ). The learned values go between the maps in the ECU's Flash ROM (the "chip") and the signal to the fuel injectors. These learned compensations are known as "trim". So, when you see "trim", it means "compensation".
    "Add" means additive trim, which is addressing an imbalance at idle. When the ECU is using additive trim, it is telling the injectors to stay open a fixed amount longer or shorter. The malfunction (e.g. vacuum leak) becomes less significant as RPM increase. For additive adaptation values, the injection timing is changed by a fixed amount. This value is not dependent on the basic injection timing.
    "Mult" mean multiplicative trim, which is addressing an imbalance at all engine speeds. The malfunction (e.g. clogged injector) becomes more severe at increased RPM. For multiplicative adaptation values, there is a percentage change in injection timing. This change is dependent on the basic injection timing.
    You can check your current state of trim by using VAG-COM or equivalent to look in Group 032 in your engine measuring blocks. The first two fields will have percentages. The first field tells the fuel trim at idle (Additive). The second field tells the fuel trim at elevated engine speeds (Multiplicative). Negative values indicate that the engine is running too rich and oxygen sensor control is therefore making it more lean by reducing the amount of time that the injectors are open. Positive values indicate that the engine is running too lean and oxygen sensor control is therefore making it richer by increasing the amount of time that the injectors are open.
    It is totally normal for both the first and second fields to be something other than zero. In fact, zeros IN BOTH FIELDS indicates that either you just cleared codes (which will reset fuel trim values) or something isn't working properly. If values get too far away from zero, it will cause a DTC (fault code) and can set off the MIL (commonly referred to as the Check Engine Light, or CEL). Specifications for normal operation are usually somewhere near +/- 10%.
    In general, an out-of-spec value in the first field (Additive) indicates a vacuum leak since it is mostly present at idle, when vacuum is highest. An out-of-spec value in the second field (Multiplicative) indicates a fault at higher RPM, and may point to a faulty MAF.
    Here's a good sanity check for the status of your MAF. Do a full-throttle run all the way to redline in a single gear (second works fine). Group 002 usually shows air mass in g/s. Your peak airflow should be roughly 0.80 times your horsepower. So, if you have a stock 150 hp 1.8T, expect around 120 g/s. If you see significantly less than that, you MAF may be on the way out. This still works if you are chipped, but "race" programs may make more power through timing, rather than airflow. Therefore, take all readings with a grain of salt.
    Oct 31 2005
    Ashburn
    Here's some audiworld post, in one of them the guy said log 001 and 002.
    I know your not getting the codes but you still have the syptoms. I'm also looking at these so hopefully they can be fixed.
    http://forums.audiworld.com/s4/msgs/2863481.phtml
    Mar 07 2007
    Belmont, MA
    great info!
    im going to be doing some more work on it tomorrow, hopefully i can figure this out
    ThorTechnik.com
    Oct 31 2005
    Ashburn
    I wanted to try new plugs so i bought some denso Iridiums IK22 and i had misfire issue's after about 1,000mi
    Below are the plugs i'm going to purchase and install, i have used these plugs for the 3+ years I owned my car with no problems, so I'll be changing back to these soon as well. Just wanted to post these as
    is no need GAP them.
    Bosch Tri-Electrode Copper Plug, Heat Range 6, Non-Resistor$4.75
    Click to enlarge
    This is the high quality Bosch plug we use in our ultra-high output engine builds and our 950+HP Audi 20v 80 Quattro. One heat range hotter than the F5DPOR, we've found that this plug does not foul as easily and provides a hotter, more powerful spark than any other plug we've tested, including much more expensive "Iridium" plugs. Also outperforms Bosch Platinum plugs.
    Bosch heat range 6, good all around turbo plug, can also be used for NA applications as well.
    We do not recommend this plug for engines with distributors as the gap is too large and causes spark scatter inside the distributor cap.
    Pre-gapped from the factory, just thread in and use.
    Highly recommended for high output 20v I4, 2.7tt and I5 turbo applications.
    Oct 31 2005
    Ashburn
    MAF TEST- sorry i couldn't paste it with the pics but i'm trying to put some good info in the thread.
    • Function test
    • Connect diagnostic tester => page AUDI-B5-FU09-ST-001-03ST-5.
    • Start engine and let run at idle.
    • Under address word 33, select "Diagnostic mode 1: Checking measured values."
    • Select measuring value "PID 16: Air flow quantity at Mass Air Flow (MAF) sensor".
    • Check specified value of air flow quantity at Mass Air Flow (MAF) Sensor at idle:
    PID
    Diagnostic text
    Specified value:
    16:
    • • Engine running at idle
    3.00 to 5.50 g/sec
    Display field: Specified value
    Possible cause
    Corrective action
    Smaller than 3.0 g/s
    • Large false air mass between intake manifold and Mass Air Flow (MAF) sensor
    • Voltage supply of Mass Air Flow (MAF) sensor or wiring connections to Engine Control Module (ECM)
    • Check intake system for leaks (false air) => page AUDI-B5-FU09-24-002-0924-84.
    • Check voltage supply and wire connections => page AUDI-B5-FU09-24-002-0224-36
    Larger than 5.5 g/s
    • Engine under load due to power accessories.
    • Reduce load (A/C system/power steering/Generator)
    • End diagnosis and switch ignition off.
    • If specified value is obtained, but DTC memory has a DTC concerning Mass Air Flow (MAF) sensor:
    • Check voltage supply of Mass Air Flow (MAF) sensor => page AUDI-B5-FU09-24-002-0224-36.
    • If specified value is not obtained:
    • Check signal and Ground (GND) wires of Mass Air Flow (MAF) sensor => page AUDI-B5-FU09-24-002-0224-38.
    • Voltage supply for Mass Air Flow (MAF) sensor, checking (Hitachi)
    • Note:
    • For Bosch Mass Air Flow (MAF) sensors see page AUDI-B5-FU09-24-002-0224-39.
    Jun 27 2008
    Boston
    ^^ Great information right there, we'll have to check it out this weekend with VAG
    Oct 31 2005
    Ashburn
    UPDATE. (aleast for me)
    Took it for a drive and the o2 readings are way off on B2 S1 for block 032- -1.7 and -.08 and at times it would read zero. and the MAF G/S reading were @ 5.5-5.7 at idle so
    I tried cleaning my MAF, used alittle alci to clean the honeycomb and just used alittle air to spray at the sensor, Also i was getting misfire codes p0300 and p0302.
    So i replaced the coilpack on cyl 2.
    Then reset all the codes which were misfire codes drove to get some gas, Did 2 runs there and back @ WOT and no misfires car pulled fine, but my MAF reading were alittle higher than before but still no misfires. I think it was because i reset the ECU, i'm going out tonight so i'll run it and see how it does, also i'm only running about 8-10psi but i'll turn it up tonight and see how it runs.
    Maybe it was just a coilpack after all, but we'll see.
    Mar 07 2007
    Belmont, MA
    changed out my plugs again to oem ones - the ones AWE says im supposed to use and im still getting the same problems as before. when i did a WOT run i got a flashing cel, and this time it stayed on. ill be pulling the codes real soon to see what is stored this time.
    ThorTechnik.com
    Mar 07 2007
    Belmont, MA
    pulled the codes:
    random/multiple misfire detected
    cylinder 4 misfire detected
    cylinder 5 misfire detected
    ThorTechnik.com
