Results 1 to 9 of 9
    Sep 11 2007
    North
    RS4 brake rotors. Options besides OEM?
    The front rotors are toast. Does anyone make a nice rotor or do I have to visit the Audi dealer for new ones?
    Veteran Member Three Rings MisanoRS4's Avatar
    Sep 15 2008
    Northern VA
    Re: RS4 brake rotors. Options besides OEM?
    Ceramics if your willing to drop a ton
    2010 GT3- Sharkwerks muffler bypass
    "The reason my car has 4 rings is because my gf has 0" -ngng
    Registered Member Two Rings Lake Powell's Avatar
    Apr 07 2008
    2007' RS 4
    Salt Lake City
    Ther is this company:http://www.movit.de/rahmen/audi.htm
    They have a couple of different setups from what I have been able to find out.
    They have a full 4 wheel 370mm steel rotor brake and caliper system that looks incredible for $8k.
    Oct 14 2006
    Denver
    OEM is all that is availble unless
    you want to go with a new BBK like the Alcons. Frozen Rotors will treat a set of OEM's for you...
    Veteran Member Four Rings Beelzeebub's Avatar
    Oct 08 2008
    B7 S4
    Adam (iirc) makes custom rotors. check the group buy section of the forum.
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    i dont know why every thinks you need the most expensive brake kit. unless you are tracking or autoxing, stock brakes are fine
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Quote Originally Posted by ngng View Post
    baller status
    If you just want the replacement that looks better GSG has some nice options.
    Sep 11 2007
    North
    I don't want to replace the calipers, just need new front rotors and pads. It looks like OEM Audi is the only way to do it
    Veteran Member Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    check your P.M.
