Results 1 to 10 of 10
    Dec 12 2006
    Charlotte,NC
    ECM Power Relay Load Circuit: (J271)
    Where is this located on my 04 audi A4 1.8T. Freakin coilpack blew up, caught on fire a little. Replaced the coilpacks but dont know where this relay is located can anyone help me out. thanks
    MK4 GTi 1.8T converted to AWD
    New 1/8th mile 7.36@102mph-27psi 93 octane, no meth
    New build times 23psi pump 11.9@126mph-96mph in the 1/8th
    04' A4 1.8t frontrak converted to quattro, was RWD for a lil now its quattro finally
    2011 JSW Tdi 6speed manual
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Re: ECM Power Relay Load Circuit: (J271)
    It is located in the ECU box. Clicky click (Be sure to scroll down)
    Cheers!
    Dec 12 2006
    Charlotte,NC
    found it, Dont know how i missed the 30 amp fuse on the side of the dash.
    Jan 25 2006
    A4 2.0T
    MD
    How much did the replacement cost?
    Dec 12 2006
    Charlotte,NC
    Quote Originally Posted by Don Supreme View Post
    It was just a fuse
    Jul 23 2011
    Nevada
    The info you posted for the other guy was helpful... leading me to my problem... which is: Performed all tests till I got to "test box" in reference to pin 23 because I read other than system voltage between 4 and 6 to check for relay activation. Would love to know where to obtain book that you got the info from or any info at all would be greatly appreciated. Original OBD 2 code was P0688 and after messing with it, can now only get a P0600. Thanks.
    Veteran Member Four Rings tchuck's Avatar
    Apr 11 2010
    '04 A4 1.8T Avant tip
    Portland, OR
    Cheers!
    I just wanted to raise this thread from the dead to thank old guy for being such a badass in general, and also for this link. My B6 died randomly in my driveway today and after pulling no less than a bajillion fault codes and following the procedures outlined in this link I was able to diagnose a faulty J271 ECM voltaqe supply relay.
    EDIT: It wasn't the relay. I replaced it and the issue persists. Upon further investigation I found my coil plug harness is shorting. Repair in progress.
    ŠTimtronic
    Jan 09 2007
    2003 A4 1.8TQ sport
    Chicago, IL
    Quote Originally Posted by tchuck View Post
    Just curious what was the part number for the relay and harness and costs for both? I am in the same mess you are in right now.
    Oct 29 2005
    10speed
    San Francisco, CA
    - Clint
    Apr 11 2010
    Portland, OR
    Quote Originally Posted by sepanskB6 View Post
    My problem was the coil harness, and I rebuilt it with new Oem connectors. They are $15 each from le dealer, but you can find them cheaper.
    Currently it's wrapped up in the thick Oem heat shielding and looks just like it did before.
    ŠTimtronic
