    Registered Member Two Rings KOU's Avatar
    Jul 30 2008
    '08 Ibis: S-Line ext & SE pack
    Tire Pressure Light...
    For the past month or so the tire pressure light on the DIS keeps turning on but when I go to check the tires the pressure is fine....
    has this happened to anyone else?
    Thanks
    Apr 15 2007
    WNC
    Re: Tire Pressure Light...
    the TPMS tends to break. Take it in to the dealership
    2013 RS5, 2014 Q7
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    either that or tell your car that this is the right psi and it should be fine.
    The usual things!!
    Resistor Install
    Veteran Member Three Rings golfvdude's Avatar
    Mar 11 2008
    2006 Audi A4 2.0T
    Abbeville, LA
    I have the same problem. Supposedly the dealership will be changing out the module for me next time. THis is after I already told them it couldn't be the sensors. AND after they checked every sensor and had the right amount of psi in each tire.
    Senior Member Two Rings vroompshert's Avatar
    Oct 14 2007
    Irvine, Orange County
    I get this warning light usually at night...but eventually goes away
    What else could be the problem?
    '08 Audi A4 2.0T Quattro MT6 / S-Line / Titanium / Navigation/ Convenience Package/ Bluetooth /19" Piano Black Rotiform MIA's w/ Hankook Ventus V12 Evo -235/35/R19/ H&R 10mm rear Spacer/ EVOMS V-Flow/ 6000k HID Fogs/ 6000k D1S
