Results 1 to 8 of 8
    Registered Member Two Rings
    Nov 02 2008
    uk
    Lowering & camber
    Quick Q, couldnt find anything on the search. Does lowering the front of the car increase the negative camber?
    Oct 16 2008
    South Florida - Ft Lauderdale
    Re: Lowering & camber
    Quote Originally Posted by kosmickid View Post
    Yes it will but if you lower the car, aligment is mandatory
    Apr 06 2007
    Arcadia, CA
    Camber is not adjustable on front wheels on B7
    07 B7 A4 Quattro Manual Sline.
    APR Software | Ecodetuning Testpipe | Milltek Exhaust
    RS4 Rear Sway Bar | ECS Snub Mount | AWE Boost Gauge
    Forge DV | PSS9 Coilover | Hartmann RS4 Replica with Falken 452
    Nov 02 2008
    uk
    Quote Originally Posted by edkwok View Post
    Yes i know but i just wanted to know whether the camber will increase when i lower it?!
    Veteran Member Four Rings Louis J.'s Avatar
    Dec 26 2007
    PNWR
    Yes, it will increase negative camber and it is adjustable, but only within a very narrow range. Many people on this forum don't align their cars after a drop for some reason, but I highly recommend that you do.
    Black B7 Titanium - Sold
    APR93 | Carbonio | Vogtlands | RS4 sway | Abt quad-tip | Podi | BBS RCs w/RT-615s | RS6s w/W300s
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Yes.
    Camber is not individually adjustable on each front wheel. It can only be equalized left/right between a very small margin.
    If you want to add adjustability check out our adjustable Control Arms in the GB section. These will add camber and caster adjustments to your suspension.
    Nov 02 2008
    uk
    Thank you guys. How it is adjusted as a pair then?
    Apr 06 2007
    Arcadia, CA
    Our car should be between 1 to 2 degree on camber when it is lowered.
    It is not that bad if the tires are rotated regularly and corner it hard on turns.
