    Registered Member Two Rings
    Aug 19 2007
    central oregon
    Clutch Ticking Noise?
    I searched but couldn't find anything..
    About a month ago I installed a stage 3 sb clutch. I resurfaced the stock dmfw and installed it all myself. I am pretty sure I did everything right. I replaced the throw out bearing, but NOT the pilot bearing.
    Tonight when I was idling in a parking spot in neutral, I noticed a ticking sound. Its coming from under the car. It got louder and louder until it was worrying me a lot. I hear it clutch in, out, or engaged at low rpms. It stops sometimes. When I stop and put it in neutral, it takes about 15 seconds to start this ticking again, and sometimes it doesnt tick, unless I depress the clutch. It is very loud though.maybe 4-5 times a second it goes tickticktick. Any ideas?
    Help please!!!
    Aug 19 2007
    central oregon
    Re: Clutch Ticking Noise?
    No one ??!! Is this "chatter"? What is the cause of it and is it bad?
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    It's quite possible it's not clutch-related.
    Hard to say without any means of hearing the noise, could be more a tappet, exhaust noise, but idk.
    I'd have though if it was the clutch, it'll be more regular, rather than occassional.
    Aug 19 2007
    central oregon
    well when it happens, when i let car idle for 15 seconds or so. It sometimes is nonexistant with the clutch out and when i push it in, it ticks. Its REALLY loud. definately my clutch. il try to get a recording of the sound.
    Jan 09 2008
    United Kingdom
    I get you.
    yes, a soundclip will help.
