Originally Posted by
Ih8OEM
but slamed with a nice tire strech will not rub at all, if you do it right: if it were me, id run 215/40/19 on those tires, and u wont rub if ur low
It's all up to you if you want to rock the stretch or not. In my opinion, I don't like the stretch at all. Here are a few pics... The first is my setup with 245/35/19 on 19x8 et35. As you can see, there is a little bit of room for more et and the sidewall of the tire is pretty much flush with the spokes on the wheel.
This pic has a lot of tire stretch... Your wheels won't be poking this far out of the fender because you only have an 8" wide wheel and et 32. However, it does give you an idea of what a 215/40/19 wheel will look like when it's stretch out on your wheels.
Like I said, it's up to you what style you think you would prefer. Also, what wheels did you end up going with?
Edit: You probably wouldn't be stretched as much as those pics because I think those are 225/35/19's on a 19x9 wheel.
