If you desire the ultimate in shifting, the JH Motorsports B6 A4 Solid Linkage Upgrade is the perfect solution. This linkage upgrade replaces the OEM rubber/plastic socket assembly with a steel spherical bearing (similar to what the JHM Solid Shifter does for the OEM shifter box). This will give you a full mechanical race car feel, and eliminates sloppiness allowing you to optimize shifts on the street or at the track. The linkage is most purposeful when used with the JHM Solid Shifter and the JHM Delrin Shifter Stabilizer Bushing, however these parts will compliment any SS kit, including stock shifters.
Check both linkage upgrades out here in our store for more details (in stock and ready to ship) --> http://www.jhmotorsports.com/shop/ca...6ecb796276e514
JHM "Solid" Linkage upgrade for B6 A4 6-speed (04-05 shown)
Video of what the linkage upgrade does here (this video does not do it justice since you can't explain it unless you feel it) --> http://audishifter.com/videos/JHM_B5...parisonWeb.wmv This video was shot on a B5 S4 but the linkage for your car works exactly the same.
JHM Delring Shifter stablizer bushing for B6 A4 (all) (great compliment to the linkage upgrade and solid shifter)
Video of what the stabilizer bushing does here --> http://audishifter.com/videos/JHM_st...parisonWeb.wmv This video was shot on a B5 A4 but the bushing for your car works exactly the same.
If you are confused to where these are located and want to know where they go, check out this video --> http://audishifter.com/videos/Extern...peed_trans.wmv (I shot this a while ago on a B5 S4 linkage which is 90% the same as the B7 A4 linkage and before I had these upgrades available.) So the concept is the same.
NOTE: These rods are not extremely difficult to remove on a 4 cylinder turbo car since it only has one downpipe located on the passenger side. The main linkage rod is on the drivers side where there is no downpipe in the way.
Check both of them out here in our store for more details (in stock and ready to ship) --> http://www.jhmotorsports.com/shop/ca...6ecb796276e514
5-speed owners go here for our shifter and linkage products --> http://www.jhmotorsports.com/shop/ca...6ecb796276e514
If you are not familiar with our "solid" shifters check them out here --> http://www.jhmotorsports.com/shop/ca...6ecb796276e514
And of course a pic for good measure.
