Results 1 to 6 of 6
Thread: vag com help
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    vag com help
    This might be a sin on this board and I actually am not sure as the topic isn't really ever spoke of.
    I borrowed a serial to usb ebay cord for so i can use the 311 vag com software that i downloaded. all i get is 'port status: inaccessable' when i try to test which port i need to use. the friend who i borrowed the cable from, never got it to work either.
    any idea how to get around this probably and get the cable to work.
    yes, i actually plan to pay the money for all the real vag stuff when i get paid, but i need to log my car, tba my wifes car and tba a friends car as well this weekend.
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Veteran Member Four Rings 3.0L AUDI A4's Avatar
    2004 A4
    Central Jersey
    Re: vag com help
    That software is either very old or not vag com?! I am using 805 Software and I believe this is the latest version. However, I do have the genuine cable which was $250 +
    I recommend buying the best cable available to suite your needs because you don't want to screw around with your car's computer just in case you screw something up.
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Re: vag com help
    Quote Originally Posted by 3.0L AUDI A4 View Post
    He can use the older software like vagcom 311 or 409 with an ebay cable. The fact of the matter is that the cheaper cable will not screw up your car.
    Once you pay to have the license for vag-com and use the cheper ebay cable the only way you are going to screw up your computer is by modifying a value or setting within the ecu that you shouldn't modify. The same goes for the more expensive (overpriced) cable and latest software.
    Jun 26 2008
    00' Noggy Stg2
    Re: vag com help
    I cant even get it to read the cable once, to get to the point of needing a serial #
    Registered Member Two Rings
    Lambo diablo, 01 1.8T
    Daygo
    Re: vag com help
    which version of vag did you download?
    Jun 26 2008
    00' Noggy Stg2
    Re: vag com help
    i got it all worked out and working 100%.
    but i am using 311.2
