Originally Posted by
revhards4
Look at Vag motorsports website...475whp on a mustang dyno on pump gas. They were saying the best stage 3 KO4 car on race gas only made 390whp on that same dyno.
The old ASP GT25r car made 412 or 415whp on pump gas at CPT's dyno I think with boost in the high teens and then a stage 3 on race gas and all the trimming made 403whp right after with boost 24psi taper to 21.
Proof is in the pudding right there my friends. Plus if you look at the VAG GT25r car is makes more torque and power all over the graph at all rpm's than most KO4 cars on pump.
When you post, if you would please speak to peak HP being the goal, that would help. You have a way of implying that 18 PSI on a GT turbo is somehow generating more power than a K04 turbo on the same car.
You can damned sure bet that if I went GT, I would upgrade just about everything, since the entry fee is so high. The logic is that the costs on GT fitment is so high, that you may as well spend a percentage of that larger pie to generat more power all around.
At the time that I researched replacement turnos, there wer no ceramic ball bearing options available that spooled where the K04 does. Additionally, supporting the turbos was going to require an extra ~1500 dollars. The cost/benefit was not where I wanted it, and the kits were very untested in a 4 seasons, daily driver non-track use.
I certainly appreciate learning of a turbo that spools similar to the K04 by Garrett. Unfortunately, if i is not ball bearing, there is little incentive to spend a dime on extra plumbing and adapting to the compressor map.
Gen- we've covered this/ Yes, a 3 liter GT car with expensive engine mods will put down more power at 18 PSI than a K04 car at 20/21. It will also outpower a poorly tuned or overworked K04 running outside peak efficiency. I would run a K04 at 24PSI as insurance that my non-trak car would develop more PSI with less throttle input than a lower peak would produce. In other words, since I am not racing, the 24 PSI never/seldom gets used, but 3/4 pedal nets me 18 PSI instead of 14, due to engine load/boost ratios.
It's easy to make unqualified blanket statements, and then qualify them if called on it. Saying "GT cars" and "PJ K04 cars" is leaving a LOT of latitude. Using that tactic, I could claim that a 1.8T BT car makes more power than a stage 3 S4. Unfortunately, it would be true on paper, under optimal situations, but false under many others.
You don't have to "sell" ceramic/ball bearing turbos to me. They have their value. I just cannot justify them for the "stock, but faster" experience. The same holds true for huge turbos on a 1.8T. Fast, but the experience differs greatly from stock, and seems more geared towards track.
Again, ceramic ball bearing that spools as early as K04, and I would have already done it. Maybe down the road i'll go that route with an overbore, but it would be for longevity, not peak power.
