Results 1 to 12 of 12
    Veteran Member Three Rings ringmaster2.0's Avatar
    Nov 05 2006
    phila
    Update: flickering headlight finally fixed
    So after over a year of procrastinating and fighting with the dealership about my flickering hid, I resolved the issue. I went ahead and ordered new bulbs (Philips Ultinon 600K's) and after waiting a month had them put in. When my mechanic took out my factory driver's side bulb he noticed it the glass housing around the bulb was broken. This caused the bulb to turn off randomly, especially over bumps and on turns. All this time I was concerned it was the ballasts and even thought the bulbs aren't cheap (500 bucks), I'm just glad the problem is no longer. So, if anyone is having the same issue (which I know there are plenty of others) it could be a matter of swapping your bulbs.
    Cheers
    Nov 15 2008
    La Crescenta, CA
    Re: Update: flickering headlight finally fixed
    I had that problem, fixed with with vag com :)
    08 A4 S-Line 2.0T - H&R Springs, 20% Tint, 6000k HIDS, 3000k Fogs, 19" Axis Penta's, H&R Spacers, Blacked out Grille, NE Prototype Intake, APR 91 oct.
    Aug 11 2008
    Washington
    Had the problem, fixed because the dealership installed a new bulb free of charge :)
    Veteran Member Three Rings grizzles's Avatar
    OC, CA
    Quote Originally Posted by ringmaster2.0 View Post
    Cheers
    Good to hear you got it fixed but why are you paying $500 for bulbs? I paid $375 for bulbs and ballasts (OEM)
    Nov 05 2006
    phila
    I wanted to go with 6000k and wanted the philips. I couldn't find them anywhere but suvlights. Anyone else have a resource for those? (I didn't think the dealer could get 600k's)
    OC, CA
    The only other place I found them was cargym and they were the same price. Yeah, the dealer will only get you 4300Ks.
    Registered Member Two Rings
    Sep 20 2008
    colorado
    Quote Originally Posted by Arman@nureuro View Post
    how do you fixed the problem with Vag Com??
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    What about the zine member LowestA4? I just purchased a set from him Very nicly priced and should be here i guess by early next week maybe sooner depends on the mail.
    But im sure LowestA4 can chime in with better info than me!
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    500 each or per set? per set is the dealer price
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Established Member Two Rings Imprezin's Avatar
    Feb 18 2008
    the shop i am at has them for 350..
    Current Car : 2011 Audi
    Previous Cars : 1999 Eclipse GST, 2005 Subaru WRX, 2008 Audi A4, 2011 Subaru WRX, 2012 Jeep Wrangler Unlimited.
    Nov 05 2006
    phila
    i paid 500 for the set..i couldn't find the philips in 6000k anywhere else cheaper than that.
    Jan 27 2007
    NC
    pm lowesta4.... He may be able to help.
    vizi
