Results 1 to 14 of 14
Thread: My k03 is dead
    Apr 12 2007
    Chicago
    Unhappy My k03 is dead
    well i have a 2002 a4 1.8T and I had the diode mod pushing out 19psi for a few months. Then I started to hear a whining noise and I just assumed it was a boost leak because it dropped to 15psi. Then today it just showed me 0psi and figured I must have a huge boost leak (but in the back of my mind I already knew the turbo was toast) and continued driving until I saw my blue smoke screen coming out of my car and realized it's game over.
    So my question is can I salvage the turbo and buy a rebuild kit or am I going to have to find a rebuilt or used k03/k04. I don't have money to spend so I want the cheapest solution and I need my car to get to school so I'm stuck.
    Veteran Member Four Rings jackyaudi's Avatar
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    Re: My k03 is dead
    Cheapest solution? Look for a used Turbo in the Classifieds in your area.
    Even cheaper? Call up the scrap yards in your area for a B6A4 used K03 Turbo and take it out the salvaged car and put it on yours.
    Take a look on ebay too, u never know.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM.
    Stuff F.S: http://www.audizine.com/classifieds/...4-parts&cat=21
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: My k03 is dead
    Sent you a PM
    -Sami-
    Apr 12 2007
    Chicago
    Re: My k03 is dead
    Thanks for the quick reply and suggestions, I guess I'm going to look around
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    Re: My k03 is dead
    i had my k03s rebuilt for 250, but you can find a used one cheaper and also not worry about down time. only downside is you dont know how long the seals or thrust bearing will last in the used one.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Senior Member Three Rings 04_A4_1.8T's Avatar
    Apr 13 2008
    04 Audi A4 1.8T
    Utah
    Re: My k03 is dead
    newb question whats the diode mod?
    My Cars...
    1998 Honda Civic Ex... *sold*
    2004 Audi A4 1.8T Giac Stage 1+ *current*
    *Honda Cbr 600rr* Springtime
    Veteran Member Four Rings durfA4's Avatar
    Jan 01 2006
    2012 A7 Stage 2, 2014 Q5 3.0T SLine, 2001 Laser Red S4
    Boston
    Re: My k03 is dead
    just a word of warning from my previous experience, the diode mod works to let you run what ever boost you want, good for the most part, but it has a couple drawbacks
    first of all the diode mod is a simple work around to prevent the map sensor from reading over 17 psi (going from memory) by placing a $5 diode in the wiring that limits the voltage that sensor sees.
    Boost- The k03 can only provide so much boost at xRPM so if ran off a manual boost controller you can push the turbo to overspin and reduce the life span of the bearings, you learned this lesson. the reason the chip companys can get more boost is that they adjust the n75 valve constantly to keep the boost pressure optimal based on the map sensor, which is now negated by the diode. this is just hurting the lifespan of the turbo and not providing optimal performance but is a cheap way to make a few hp.
    the really bad part of the diode mod is if you have an issue with your MAF then your engine is running off the 02 sensor only. which is fine for open loop driving, but full throttle will use those setting and can cause a unsafely lean condition even with a k03. maybe not a blown engine but melting of the Cat-converter or pistons rings, valve seats etc...
    so if you have a large turbo that you can keep in its efficiency range and want to maintain the diode mod it can work, but on the smaller turbos the money you spend to replace the turbo is more than the cost of the chip.
    fiscal lessons learned are often the toughest.
    now if you were planning on a upgrade and needed to convince the wife/girlfriend that you "needed to spend X amount on a turbo upgrade then you are not alone my friend.
    2012 A7 3.0t EPL Stage 2
    2014 Q5 3.0t
    2001 S4 STUKLR tuned
    Veteran Member Four Rings QuattroRocket's Avatar
    Sep 01 2004
    2103 S4, 2014 Nissan Pathfinder
    Vancouver Canada
    Re: My k03 is dead
    I have a perfectly good K03 if you need. 30,000 miles on it before I went BT.
    Gone but not forgotten : 2000 A4, 2002 A4, 2004 A4, 2013 S4 Premium, 2013 Q7, 2017 SQ5 Dynamic Edition
    Current Audi : 2017 RS7
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    Re: My k03 is dead
    Quote Originally Posted by durfA4 View Post
    so this has me thinking; would it be possible to use the diode mod to lets say a GTRS with correct injectors, would it be possible to drive like this without a chip? because it sounds to me like this diode mod defeats the whole purpose of havin a chip in the first place.
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Re: My k03 is dead
    ^^^ive been googleing that exact same thing......havent found anything. But i too have done the diode mod, and i cant tell if my turbos on the way out but i want a BIGGG ONE!!! im considering a 50trim kinetic or rotomaster with manifold, then mod the software and motor internals down the road. Im talking 12-15psi here, nothing crazy, but itll have to do for up to many years to be 100% complete...hope hope hope lol
    barrett
    2019 SQ5 Prestige
    Jan 01 2006
    Boston
    Re: My k03 is dead
    the whole point of a chip and a tune is to allow the injectors the right calculations based on the amount of boost that the turbo will build up to.
    you SHOULD NEVER bolt on a bigger turbo and not get a CHIP/Tune.
    the ecu is more complicated than most other companies and has very small adaptation windows. so if you change the injectors and then diode mode the the MAP sensor your MAF readings will not match the injectors.
    you will get a rich idle and a lean WOT the worst combination.
    the money you save do this diode WILL be lost when you blow your engine, the diode mod is a band aid, to allow more boost than specified by the ecu, but if you look at all the BT and larger turbos on this board None run a Diode Mod, because it will not allow the ecu to effectively calculate the A/F ratio.
    I do not understand why any one would be willing to spend so much money on a turbo, and then skip the part that will allow it to perform optimally.
    2014 Q5 3.0t
    Apr 01 2007
    houston texas
    Re: My k03 is dead
    ^^^relax man breathe. I am not trying to be some radical nor am i disagreeing that a bt with proper software is optimal, all i was asking was if it could be done relatively safely, that is all. and i guess the answer is no lol
    barrett
    2019 SQ5 Prestige
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    Re: My k03 is dead
    if it was tat easy noone would buy software.
    Feb 19 2007
    Charleston, SC
    Re: My k03 is dead
    I am just doing the diode mod, because there is no point to buy software now (I would have to ship ECU out for god knows how long and I need my car EVERYDAY)
    When i go with a bigger setup, then it will be "worth" having to live without a car while the ECU is out....
    I honestly dont see anything wrong with the diode mod if you are SENSIBLE with it.
    -Sami-
