Originally Posted by
channad
If so, I have some quesitons:
1.Where did you buy them?
2.How much were they?
3.Which spring rates did you go with?
4.Did you upgrade the rear sway bar?
5.Do you track or auto-x your car?
6.How long was install?
7.Is it easy to adjust height?
8.Did you corner balance?
I'm thinking of getting a set. My only issue is that I'll raise the car up for winter and put snow tires on. For those cruises up to Mammoth during winter. Whenever that comes around, it was 85 in LA today. Then I'll have to car lowered when it's spring time, and swap in some 19s, hopefully. Seems like kind of a hassle to me. Any thoughts would be appreciated.
I have had mine installed for about 2 weeks so far very happy.
1. I purchased mine through Ryan at ICS, it was a GB on "another" forum
2. $2200.00 with shipping
3. I have the spring rates specified by Stasis, I don't think there is an option for anything different.
4. Before I did this mod I was certain that a sway bar upgrade would be necessary but not now, the handling is now much better.
5. Nope, I'm certain I'd wreck somehow.
6. Install took better part of the day, did it my self, but I work rather slow.
7. As other have said the fronts are easier than the rears. One thing that has made adjusting the rear easier is cut about 3" off of the handle of one of the spanner wrenches, it made it fit in close quarters better.
8. No, but I did a 4 wheel alignment, and I am very happy with the car.
As far as wanting to adjust he ride height for snow conditions, I really don't think it will help you much. From my experience the roads are generally plowed then if not they're packed. It you happen to try to plow through powder then the amount of depth will have to be just right for a small increase in ride height to make a difference. Usually the snow depth at the bottom of the hill is much less than the top.
Case in point, I got 6" of snow in my yard last weekend, Snowbird ski resort got 46", I live 9 miles away. Lifts opened last friday.
