Results 1 to 12 of 12
    Jan 10 2008
    98 a4 quattro
    New Jersey
    i need speaker hlp asap
    so when i put my headunit in everything went bad speakers started cuttin in and out. Now i am upgrading my front and rear speakers with mbquarts, but when i try to hook up the driver side speaker allthe speakers turn off. So i decided that the best thing is to wire everything myself straight from headunit to speakers so i do not have to deal with the complicated audi wiring. The rear speakes are easy but i need advice on the fronts.
    HELP THIS IS GETTING ON MY NERVES.
    Throttle pedal meet floor board
    K04 meet (pc16 + n75h)
    Honda's meet taillights (Im not a hater I had a integra)
    Veteran Member Three Rings cyanidecologne's Avatar
    Oct 26 2006
    2006 BMW X5 4.4i Sport Package, 2006 Audi A4 2.0T Quattro
    Tustin Ranch, Ca
    Re: i need speaker hlp asap
    Best if you want the best sound quality is run all new heavier gauge wire straight off the back of the headunit directly into your doors. Forget about the factory speaker wires all together.
    Built not Bought
    Custom One-Off CSL Style Trunk Lid/Rotiform 19x9.5 ET25 Kandy Purple BLQ/Toyo Proxes 225/35/19/Full Custom Interior/Hotchkis Sways/Tein Coilovers/AWE Boost Gauge/AEM Intake/Britalman Quad Tip + Test Pipe/Revo Stage 2/Custom Paint Color/One-Off Oettinger Kit/Anzo Led Tails/Infinite Auto Design Vented Carbon Hood/Carbon Interior Trim/Carbon S4 Blades/3 Arc Audio 15s /Etc...
    Jan 10 2008
    98 a4 quattro
    New Jersey
    that is what i was planning on doing but how do i get the wire into the front doors
    Oct 26 2006
    Tustin Ranch, Ca
    Run it through the rubber wire loom that runs from the front of your cabin though the door jamb by the hinges and into the door.
    Built not Bought
    Apr 25 2007
    millersville, maryland
    yeah it just pops off either side and you can push the wire through easily. Some of the easier doors to run wires into.
    Veteran Member Three Rings B5 Quattro's Avatar
    Feb 10 2008
    2000Audi A4, '88 VW Jetta 2.0l16v, 2011 Golf....
    Hamilton.Ont, Canada
    Did you get it ?
    What does it look like ....What does it sound like ???
    LOL. Any pic.s?
    Jan 10 2008
    98 a4 quattro
    New Jersey
    i will do it tomorrow morning i hope this stops the speakers from cutting out.
    Senior Member Three Rings Spykce's Avatar
    Aug 06 2008
    Indiana
    Also interested in your results as I am considering new speakers, amp and head unit soon.
    Current Car: 2000 A4 1.8TQ Frankenturbo Build | 2012 Passat TDI
    History: C6 A6 4.2, B7 S4, Mk V GTI, Mk IV GTI Vr6, Audi 80, Audi 4000 Q, B5 A4 1.8TQ x 5, B5 A4 V6, Mk II Cabriolet x 4, B5 Passat 1.8T, Mk II Scirocco, Audi TT 1.8TQ, Mk III GTI Vr6, C5 Allroad 2.7T x 3, '86 VW Quantum Wagon
    Senior Member Three Rings urban96's Avatar
    Aug 09 2007
    Syracuse, NY
    i found it kinda a pain to run the wires because of the double firewall there and limites access into the holes. I used a old coathanger and stuffed it in from the door, connected the wire and then pulled it back out
    -06 A4 2.0T
    -97 A4 1.8T
    Jan 10 2008
    98 a4 quattro
    New Jersey
    so i wired it all up today works great except, when the driver side is connected none of the speakers work. but when i unplug the driver side front speaker the other three work fine.
    Senior Member Three Rings A4Shizzle's Avatar
    Mar 19 2006
    San Jose, CA
    Weird, if you ran new wires I'd say your deck is the culprit, or maybe you got the wrong outs. Like you wired the negative up to the mute function or something...
    No time to mod with so many things to fix...
    Aug 09 2007
    Syracuse, NY
    maybe a bad speaker?
    -06 A4 2.0T
    -97 A4 1.8T
