Results 1 to 18 of 18
    Registered Member Two Rings
    Sep 25 2006
    2004 Audi A4 1.8T 6sp QM
    Ventura County
    Help! Car won't start!
    As much as I love my B6 I sometimes have to try very hard not to throw my fist through the window.
    I just got finished towing my car back home after it broke down today. Here's the details. Any advice would be very appreciated.
    On my way home, when I attempted to accelerate the car started to hesitate similar to the way it would act if I was running out of gas. When I pulled over into a parking lot it died. I started the car again and it started just fine. When I attempted to pull forward it died again. Each time getting worse until it eventually would not start. Now it will turn over but not fully start. No warning lights, no indication of the immobilizer being activated.
    For the last month or so I have noticed an odd sound. Unfortunately I have not had the money to look into it. The sound is hard to explain. It's kind of a very faint humming sound that seems to come fromt he back right of the car near the rear wheel. It is loudest when starting in the morning when it's cold or when you've driven for quite a while. At first I thought it might be an exhaust leak but not sure because the sound does not change when you rev the car. It doesn't go away or get louder. It doesn't happen all the time but it does still happen whether the car is moving or parked.
    A friend of mine suggested it might be the fuel pump which seems to fit the symptoms. I'm going to look into this when I get off work but in the meantime any other suggestions or even just assurances that it is the fuel pump would be greatly appreciated.
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Re: Help! Car won't start!
    Quote Originally Posted by Sweet Mike View Post
    Yes your friend is most likely correct, sounds like a failed fuel pump.
    Beta Alpha Tau member #56
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Veteran Member Three Rings Drew-B6's Avatar
    May 15 2008
    Syracuse, UT
    It could be a fuel pump. The fuel filter is located on the passanger side rear near the tire.
    Drew-
    2013 Audi S4
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    The whining is your fuel pump.
    You will need a new fuel filter and a new fuel pump.
    That will fix your problems.
    GL
    Z
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Sep 25 2006
    Ventura County
    Quote Originally Posted by A4 Moda View Post
    GL
    Z
    Thanks man. Do you know of any good way of testing this to be sure first? I don't want to drop $400 on a fuel pump/fuel filter if all along it was something smaller like an O2 sensor or something.
    Veteran Member Three Rings fitch303's Avatar
    Jan 03 2008
    Columbus, Ohio
    I just got caught for drunk driving and the cop drove e home yay
    Senior Member Three Rings 04_A4_1.8T's Avatar
    Apr 13 2008
    04 Audi A4 1.8T
    Utah
    pull out an injector stick it in a bucket see if it squirts
    My Cars...
    1998 Honda Civic Ex... *sold*
    2004 Audi A4 1.8T Giac Stage 1+ *current*
    *Honda Cbr 600rr* Springtime
    Feb 09 2008
    2002 A4 1.8T 5-speed
    Austin Texas
    Quote Originally Posted by fitch303 View Post
    Lmao, i'm lost.
    Capt. Obvious: It's like fucking your cousin, just because you can doesn't mean you should.
    Veteran Member Three Rings favianjanitra's Avatar
    Aug 05 2005
    A6 3.0T Quattro S-Line & VW Tiguan 1.4 TSI R-Line
    Balikpapan
    definitely fuel pump
    Sep 25 2006
    Ventura County
    Update To This Thread
    My A4 is currently in the shop getting taken care of. The mechanic determined it's the fuel pump. The only thing now is that he's put 2 different fuel pumps in and the pump is still making a loud whinning noise. He's trying to find out but if anyone has any input it would be appreciated.
    Could my software have anything to do with it?
    Veteran Member Three Rings B8Buckeye's Avatar
    Mar 14 2005
    2011 Audi A5 Cabriolet - Ibis White and 2016 Mercedes Benx Metris conversion van - Obsidian Black
    NW Ohio
    Re: Update To This Thread
    make sure he is replacing the fuel filter too. if you just replace the pump but keep the old clogged filter, you'll kill the new pump in short order. fuel filters are $50-60.
    2011 A4 Avant 2.0T Quattro ZF8 - Brilliant Black - Sport & Cold Weather Packages
    Magma S4 Seats & Door Cards with Brushed Aluminum Trim, B8.5 S-line Auto Shift Knob, RSNav S3 10.25", 19" OEM 5-Arm Cutters, RS4-style Honeycomb Center & Fog Grilles, deAutoLED Turns & Fogs, OEM B8.5 Euro LED Tails, OEM S-line Stone Guards & Rear Valence, IE HFC/DP, Milltek CBE, UM Stage 2, ECS Coilovers
    Aug 05 2005
    Balikpapan
    ^^ what he said.
    I did the same mistake as you did by replacing the pump first without checking/replace the filter.
    As soon as the new pump was installed, it was still making noises.
    Changed to a new filter and bam everything is back...smooth.
    my filter was really clogged and it killed my old pump
    Sep 25 2006
    Ventura County
    Quote Originally Posted by B6Buckeye View Post
    Thanks a ton. He just called back and said it was the filter as well. It's all getting replaced. I can't wait to get it back!
    Sep 25 2006
    Ventura County
    Looks like it's all getting taken care of. Thanks to everyone for offering such quick advice. Audi owners always seem to know whats up. haha.
    Aug 05 2005
    Balikpapan
    because our cars break down time and time again.. haha
    Sep 25 2006
    Ventura County
    Quote Originally Posted by favianjanitra View Post
    Man, you're tellin' me. It's been a rough year
    * Replace clutch $750.00
    * State Referee Ticket $350
    * Replace Instrument Cluster $1,200.00
    * Replace Fuel Pump/filter $600
    * The fact that I know more about how to hook my car up to a flatbed towtruck than the driver - PRICELESS
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    ouch... could have done the fuel pump on your own
    http://www.a4mods.com/index.php?page.../fuelpump.html
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Sep 25 2006
    Ventura County
    Quote Originally Posted by martini View Post
    Yeah, I would've but Then I would've had to tow my car back home and still pay an $80 diagnosis fee. It was worth the extra few bucks to not have to deal with it.
