Results 1 to 15 of 15
    Established Member Four Rings Yaktizzle417's Avatar
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    So, my car won't start.. When its warm?
    And I can't check my CEL's, no OBD2 reader can connect to it. Not even my VAG-COM that I've been using for almost a year.
    Any ideas?
    ÖMGHI2Ü
    Photography
    Senior Member Two Rings NK2007's Avatar
    Mar 25 2008
    2000 Audi A4
    Ft. Collins & Colorado Springs
    Re: So, my car won't start.. When its warm?
    First off... Search much?
    That being said, i can offer some help, at least what i have run into
    Do you have a Boost/Vacuum Leak?
    When i first bought my car it would start right up in the morning, when it was cold, but once it warmed up, it refused to start. Built a boost leak tester, and found about 5 brittle hoses with holes in them. Fixed that, no more starting problems.
    There are other related issues, and im sure they have been covered in a million topics already...
    |00 A4 TQM|K04|Revolver Cams|Greddy FMIC|Custom GIAC|Full Custom Exhaust|OEM RS4|S4 Rear|S4 Interior|HID|
    More to come!
    F.S. Rieger Side Skirts in Silver- will trade for S4
    Apr 14 2008
    a4 avant
    marlboro
    coolant temp sensor
    -vrt-
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Hall senders are also common culprits, that cause hot-starting issues.
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Quote Originally Posted by 1fstavant View Post
    coolant temp sensor
    +1
    Mine never through a CEL on my old A4, but it did throw a code. Got mine at a VW dealership for about 30 bucks. They should have them in stock.
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Apr 14 2008
    a4 avant
    marlboro
    deoes it feel like you need to flood the car to start it
    -vrt-
    Veteran Member Four Rings arorem's Avatar
    Mar 24 2008
    '99 A4 1.8TQ, '74 Triumph Spitfire
    Illinois
    we need more info than that man, what does it do when you turn the key?
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    Yeah, like its not getting any fuel. It only does it randomly too.
    Not much I can do, if I can't use my VAG-COM to check for codes. I know like 4 months ago I got the code randomly for a coolant temp sensor, maybe its finally gone.
    The big problem is that I can't check my codes.
    ÖMGHI2Ü
    Photography
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    is your abs light on?
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    No, its been doing the usual bad wheel speed sensor symptoms. Like randomly kicking in and at low speeds.. etc.
    It has come on before, but went away after like an hour or so.
    ÖMGHI2Ü
    Photography
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    unplug your ABS Control Module and see if your car will talk to a vagcom then.
    because racecar.
    Established Member Two Rings hans j's Avatar
    Feb 02 2005
    TDI Syncro Westy, 2001.5 S4, Caddy, bicycle
    utah/ united states of america
    Crank position sensor.
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    Quote Originally Posted by Kyle H View Post
    DIY?
    I is lazy.
    Hans:
    I just did one like a year or so ago.
    ÖMGHI2Ü
    Photography
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Just a guess but my money is on the coolant temp sensor. The ECU thinks the car is cold so it uses the cold start map which just doesn't work well on a warm engine. When my sensor was bad it would almost start then crank for at least 30 seconds and then smell like it was flooded.
    Jim
    I Do Werk.
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Quote Originally Posted by Yaktizzle417 View Post
    DIY?
    I is lazy.
    Hans:
    lawl. lazy ass.
    http://www.modulemaster.com/en/Audi/A4_info.php
    because racecar.
