Results 1 to 40 of 41
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    *** Production Run - 034 Exhaust systems - Dyno Test inside!! ***
    Everyone here likes results so we will let the following speak for itself.
    Quote Originally Posted by 034 Motorsport
    So I've been running a Neuspeed exh. system on my 2001 B5 A4 for a few years now. Its a nice system, quiet at idle and cruising, no droning, very unassuming and definitely wouldn't turn the head of the Po-po
    Neuspeed system:
    But one thing that's bothered me, the system makes a sharp hissing sound, like a lot of very high velocity air is being forced out of a hole that is too small. It definitely sounded restrictive, so I wanted to do some testing to see if there were some gains that could be had.
    My A4 info is here: http://www.034motorsport.com/article...rticles_id=144
    Its a very nice daily driver car IMO, dead nuts reliable, fast, good mileage, my Mom or Wife can drive it. Its been putting down about 230whp with the Neuspeed system, but there must be more.
    So I bolted in one of our 034Motorport 3" dual muffler systems, pictured here:
    This system is 3" from the turbo back, one 3" straight through Borla muffler at the center, and a Magnaflow 3" inlet dual 2.5" outlet. All connections are v-bands, all tubing stainless, etc.
    Takes about an hour or two to install if you have a lift, bolts right on.
    The results were pretty dramatic.
    First off, the custom Motronic tuning was calling for about 22psi boost with the Neuspeed system, with the 034 exhaust boost now spiked to 32psi and wanted to hold to redline - holy! :o
    So we had to actually retune the boost profile back down to 22psi just to get a good comparison.
    The exh. system is definitely louder, but its not so loud that it sets off car alarms or attracts attention from the police. Most importantly, it doesn't drone or become loud on the ears cruising on the freeway. It certainly opens up when the throttle is mashed, and no more hissing, the exh. note sounds wonderful for a 1.8t IMO.
    The gains:
    30+ Wheel HP
    25+ Wheel TQ
    Full Boost approx 500rpm sooner
    Turbo spools faster in transients, motor just feels more snappy all around.
    See the dyno chart here:
    The car obviously feels a lot faster now, and this was a great upgrade.
    Some more pictures of the exhaust system installed:
    We are now running a Production run of B6 034 Exhaust systems.Users can choose between a cat back system or a full blown turbo back system.We will have a complete unit to show by Friday the 21st.
    Cat Back system consists of a 3" inlet Magna flow muffler with dual 2.25" outlets flowing into 2.25" mufflers which finally exit to 3" tips.The Turbo Back system is simply the cat back system with our high flow catalytic converter all in 3".Pricing is as follows:
    * Cat Back system - 939US + Shipping
    * Turbo Back system - 1099US + shipping
    To see the B5 set ups simply click the following links:
    http://www.034motorsport.com/product...ducts_id=13698
    http://www.034motorsport.com/product...oducts_id=1274
    Select the options you want and send me a PM when you are ready to order.
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    Re: *** Production Run - 034 Exhaust systems - Dyno Test inside!! ***
    whats the pricing on these for the b6
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Senior Member Three Rings OCMI_Teddy's Avatar
    Sep 12 2008
    03 Audi A4, 1996 Jeep Cherokee
    San Diego, CA
    +1
    Orange County Mobile Infantry
    Proudly Supported By: | Tippmann Sports | Tiberius Arms | SC Village | JT USA Paintball | Behind The Mask/Sunday Clothing
    GIAC FX, TT225 injectors, 004 BOV, RS4 rear SB, B5S4 Brakes, Kosei K1 TS wheels, Passport 8500 x50.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    What does it look like on a B6??
    I LIKE the V-Band connections.
    -Doug
    Feb 26 2006
    Earth
    Quote Originally Posted by gotboost View Post
    Single exit or dual?
    Veteran Member Four Rings Dolphin18T's Avatar
    May 17 2007
    I'm interested. Still wondering about price and how it looks as well. Thanks Issam
    -Ryan
    Maestro Tuned
    Now with slushbox-delete mod!
    May 17 2007
    Quote Originally Posted by Issam@034 View Post
    Dual, on a 1.8T Tiptronic?
    -Ryan
    Maestro Tuned
    Oct 29 2005
    10speed
    San Francisco, CA
    OMG YES... Issam u know I'm in
    - Clint
    Established Member Two Rings smarrick's Avatar
    Apr 07 2008
    04 A4 18T 6MT QT SPORT, 07 X3, 74 Lincoln Continental
    Fort Collins, CO
    That system looks sick, looks excellent quality but wheres the B6 love. You posting here to torture us?
    Fort Collins Drinking Team Member #2
    Feb 26 2006
    Earth
    Ok
    I am revising the first post so that it was more B6 friendly as my PM box just blew up.
    The system is going to either be Turbo back or Cat back (up to the purchaser).Pricing will be similar to a complete B5 unit but we are working out how much you will save for a production run so sit tight...
    System will be single 3" magna flow inlet with dual 2.5" out let which will go into 2 separate 2.5" magan flow muffler into a 3" tip.
    May 17 2007
    Are these Tiptronic friendly?? If so, i'm down for SURE!
    -Ryan
    Maestro Tuned
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    What about getting ONLY a downpipe and HFC?. Im interested in a 3" to the bottom of the car, then mating to a Milltek. I realize I'll have to adapt it to the milltek. I see there is a similar option for the B5 right now.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Veteran Member Three Rings whiteUSPflow's Avatar
    Feb 22 2008
    2004 USP 1.8tQ, 2003 RS6
    Richmond, VA
    hey bud im really interested in one but i got a couple questions for you so when your not swamped anymore shoot me a PM that would be awsome thank you so much system looks great.
    USP CLUB MEMBER #97
    APR tuned K04-Carbonio-Forge-Podi-Stasis-034 Motorsport-RAI motorsport
    Unitronic tuned RS6
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    Ive driven Javad's car and it was really impressive!! Of course it was the first time I drove a BT, but I was surprised how civil it was until you hit boost!! 034 was very helpful when they did my FMIC install.
    Issam you have a PM...need to ask you about something.
    another stereotypical Audi
    Feb 26 2006
    Earth
    Quote Originally Posted by lookaught View Post
    Send me a PM and I will see what I can work out for you.
    Quote Originally Posted by whiteUSPflow View Post
    Never too swamped.Send me a PM with what you have in mind.
    All PM's replied.
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Well, I guess, I be getting a custom 3 " exhaust set-up.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Feb 26 2006
    Earth
    Pricing information has been updated.Whoever is ready to send payment please send me a PM.Pricing will NOT remain the same once this production run is over.
    Feb 26 2006
    Earth
    Should have an exhaust system completed for the masses very shortly :D
    Feb 17 2005
    Sarasota, FL
    So let me get this straight, over the Neuspeed exhaust, yours gained 30whp and 25wtq? Dyno graph looks like a 28RS setup however it only made 230whp on 22psi? Hmmm ...
    Jul 27 2004
    Bay Area 925
    Quote Originally Posted by A4ringedONE8T View Post
    Shawn I don't remember what type of dyno they have in house, but Ive been told its a heart breaker..
    Javad also told me his car was on conservative tune for daily driving and also we have crappy 91 octane here in norcal...
    Veteran Member Three Rings PhunkFX's Avatar
    Oct 11 2005
    2019 TTRS, 1989 VW Cabriolet, 1986 VW GLI, 2015 Cayenne Diesel
    Post Falls, ID
    Issam! I think there might be a decent following if you offered the 3" downpipe from the turbo by itself. Just like you do for the B5. I know I'd be buy one!
    I know many drivers already have an exhaust and may be looking for a nice 3" catless downpipe all in one shot. Rather than finding a DP or using the small ones that come with the exhaust system and then alone buying a cat-delete pipe. Let us know if you plan on doing that!! I think its time!
    -Ricky
    2019 Audi TTRS Prestige | Stage 3
    2015 Porsche Cayenne Diesel | Stage 2
    2015 VW Golf SEL TDI 6MT | Stage 2
    1986 VW Jetta GLI Wolfsburg Pirelli w/11k Orginal Miles
    1989 VW Cabriolet | 1.8T K04 w/nitrous
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by PhunkFX View Post
    Why? There are no other 3" exhaust systems on the market, and this V-band setup wouldn't mate to anything else. This is an awesome option for us, and I am one of the first people to get it
    - Clint
    Apr 20 2007
    Lander, Wyoming
    Did you ask him? Im ordering one just like that. I have to custom fab it to a midpipe back exhaust, but he'll make it for you, just like the B5 version.
    Clint pointed out the most important thing (and I mentioned it as well), you can't bolt it to any other system... it has to be custom. So if you want to go that route, PM him and I'm sure he'll sort you out.
    Jon
    go > show
    Ich liebe mein Audi
    Apr 20 2007
    Lander, Wyoming
    Issam do you have any idea when a full setup will be built? Im thinking about just ordering the whole exhaust now, but am really curious about how loud it is and how it looks in its finished form.
    Jon
    go > show
    Ich liebe mein Audi
    Veteran Member Three Rings A4p's Avatar
    Mar 06 2006
    Audi 1.8TQM6 S-line USP 2004
    Sweden
    +1
    USP CLUB MEMBER 861
    Rev0 stage I file - 300+ bosch injector - OFE SS - APR Snub mount - Nitrogen - RS4 Swaybar - K&N air filter - **-
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by a4wd View Post
    Peak power for a 28RS setup, understandable, though that dyno would also make it much harder to show significant gains between something as simple as an exhaust swap, hence the reason a 30whp gain just from changing exhaust seems extremely far fetched
    Oct 29 2005
    10speed
    San Francisco, CA
    either way more flow = more power, you can get an exhaust for the same price that wont make the power or you can get this one, I prefer more power
    - Clint
    Feb 17 2005
    Sarasota, FL
    Clint your missing my point, this isnt going from stock to an aftermarket exhaust, this is going from an already enlarged Neuspeed exhaust to another, and still gaining 30whp? Shit, it would be hard to gain 30whp going from just stock exhaust to this. Remove your head from Issam's ass and think logically. And make your car run before you spend another grand on exhaust ...
    Oct 11 2005
    Post Falls, ID
    I most certainly will... customizing to fit another exhaust wont be that big of an issue for me at least. I'd be willing to add a vband end to my current exhaust!
    -Ricky
    Apr 20 2007
    Lander, Wyoming
    Sounds like a good fit then, as the 034 downpipe alone comes with a second vband flange and the clamp to attach to your current exhaust, you just have to line it up and weld it on.
    Jon
    go > show
    Ich liebe mein Audi
    Oct 29 2005
    10speed
    San Francisco, CA
    yea but there is a ton of restriction in a Neuspeed 2.3" exhaust, not to mention it bottlenecks down where the test pipe meets the exhaust. I dont know why Audi exhausts are so damn restrictive, because VW tuners offer a bunch of 3" exhausts... Also Shawn, I would have to assume that having the bigger exhaust freed up a few psi, which would add power also
    and I need this exhaust to get my car running LOL
    - Clint
    Feb 17 2005
    Sarasota, FL
    His info states that just changing the exhaust raised the boost from 22psi to 32psi without any other changes, the car was then retuned (perhaps some of the power came from the retune, hmmmmmm .... ) to 22psi where the 30hp gain was made and noted as coming from the exhaust change only, meaning same boost. I understand 2.5" vs 3" and bottle necks and all that, but a 30hp gain from an already aftermarket exhaust that supposedly gives 10-15whp over stock, which we all do know it improves performance via the butt dyno, and you want to tell me that this setup goes 30whp ABOVE that already +15 or so over stock. Honestly that doesnt seem a bit far fetched to you? And in case you forgot, I went from Neuspeed catback to full v-banded 3" to 2.5" splits on my setup. Imagine that boost didnt change one bit between the two and I can tell you that my car didnt gain no 30whp, if it gained anything at all it would be difficult IMO to show even a 5-10whp gain and not show it as being due to some environmental/operating change. And this with a 3076R which a big exhaust would make WAY more gain on over a dinky 28RS
    Registered Member Two Rings
    Dec 01 2008
    NM
    I'd just like to chime in and request a turbo back tiptronic version be produced at some point...hopefully soon.
    Oct 29 2005
    10speed
    San Francisco, CA
    I know Sean (Don Supreme)'s car jumps boost almost instantly when he used to open up his cutout and the shit would pull SO much harder
    - Clint
    Feb 26 2006
    Earth
    I would explain that but you have done a fine job explaining Clint.Removing a bottle neck from the system does free up horsepower...infact alot.
    Shawn if you would like,next time you/the folks @ 1552 perform a similar test and then question the results.Until then enjoy the dyno's
    Feb 22 2008
    Richmond, VA
    I just ordered my 3in custom exhaust turbo back for a pretty good deal. ill post some pics once i get it in the mail because there still isnt any up here. but ya issam was great to work with and got everything done as soon as he could. so I cant wait to see it when it comes.
    USP CLUB MEMBER #97
    Unitronic tuned RS6
    Feb 26 2006
    Earth
    Going to love it on the car especially with your "meaty" combo
    Apr 20 2007
    Lander, Wyoming
    So have any of these been built yet? Im still on the fence between getting a full system and just the downpipe.
    Jon
    go > show
    Ich liebe mein Audi
    Feb 22 2008
    Richmond, VA
    god your going to kill me bro, im already exited enough as it is.
    USP CLUB MEMBER #97
    Unitronic tuned RS6
    Veteran Member Four Rings aaronz's Avatar
    Jun 10 2008
    Spiders
    Chicago And NJ
    Anything up on these? Anyone get theirs? Pictures?
    2016 TTS Launch Edition
    SOLD!!! 2013 S4 DSG Build Thread
    VAG-COM equipped if you need help
