Results 1 to 21 of 21
    Nov 14 2008
    NH
    NEED HELP 2001 audi s4 thermostat
    Hello I live in an area where there is no audi or vw dealer for like 100 miles. I need directions on how to replace the thermostat in my 2001 audi S4. I am sure the problem is the thermostat. when I start the car up the engine temp sensor is already at the half way point the heat blows fine but the temp of the engine rises up quickly I dont let it overheat but it would if it got the chance and it would happen probably in about 10 minutes. I really need detailed directions of where the thermostat is and how to get to it and replace it. car has 105000 miles n it. I really appreciate anyone who takes the time to help me out. Thank you all very much.
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    Re: NEED HELP 2001 audi s4 thermostat
    have the timing belt and water pump been changed? cause the thermlostat is just to the passenger side of the water pump and to get there, you pretty much have to to a t-belt job... but it doesn't sound like a thermostat necessarily...
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Doesn't sound like thermostat. But you are basically doing a Timing Belt job when you replace the thermostat.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Feb 28 2007
    S4 Stage 3+
    Las Vegas
    I got the opposite problem... My car cools down after it warms up... I need to change my thermostat too. A lot of work for a 25$ part.
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Quote Originally Posted by Coughdrop View Post
    You're telling me. Mine's been like this for at least half a year. But my timing belt isn't due yet, so
    Feb 28 2007
    S4 Stage 3+
    Las Vegas
    Ya same... waiting til I hit the 50,000 mile mark to do it...
    Nov 14 2008
    NH
    Yes the timing belt and water pump have been changed at an audi dealer i bought the car from a dentist who put about 8 grand in the car in maintence money wasnt and object to him apparently .
    Nov 14 2008
    NH
    Do you guys think it is something else? like I say my engine temp gauge is at half way mark as soon as I start the car. I use it to go like a mile or two just to the corner store i leave the heat cranking full blast but the temp gauge rises like 3/4 way doesnt overheat but i know it will if i keep going. no warning lights come on or anything. as soon as i start it everything checks out and say "OK" I know something is wrong but no mechanics here dare touch it.
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Sounds more like a temp sensor then anything. That's a $10 part and a 2 second fix.
    Nov 14 2008
    NH
    Temp sensor sounds good to me. i havent really dared drive this car much for months. where abouts is the temp sensor? I truly appreciate you taking the time to help me out. I bought this audi because of all the maintence that was done to it by the former owner the dentist. I figured I would be good for quite a while.I have only put a couple thousand miles on it.
    Feb 28 2007
    S4 Stage 3+
    Las Vegas
    Has the temp gauge ever gone past halfway or are you assuming it will? I'd drive it until you see it go past halfway. If it does, then you know for sure something is up.
    -Nevermind... just read more and answered my own question...
    Veteran Member Four Rings will175's Avatar
    Apr 25 2007
    Las Vegas..Hawaii..Nor Cal
    Yah rated S always has good info and always tries to lend a hand. Is it true that if our T stat goes out it stay in the position so the car does not overheat?
    Train Hard, Go Hard, But always be Humble.
    Veteran Member Four Rings HighDesertAudi's Avatar
    Mar 09 2005
    NorCal
    When the thermostat breaks it breaks open so your car will run cold and never heat up. Your problem sounds like a bad coolant temp sensor which is a cheap easy fix. Replace that before you do anything else.
    Previous Audi's
    1999 Audi A4 1.8T Quattro 5spd Laser Red
    2000 Audi S4 6spd Nogaro
    1990 Coupe Quattro 5spd Lago Blue
    2000 Audi S4 6spd Laser Red
    2004 Audi S4 6spd Dolphin Gray
    2004 Audi A4 6spd Brilliant Black
    Feb 28 2007
    S4 Stage 3+
    Las Vegas
    My car warms up then cools down then warms up again, this all under constant freeway driving. I'm still thinking the thermostat is stuck open, but wouldn't that prevent the car from warming up at all...
    Sorry Jason... not trying to jack your thread or anything.
    Mar 09 2005
    NorCal
    Reread my post and STFA.
    Previous Audi's
    Aug 06 2008
    Canadia
    you can change the t-stat without removing the timing belt, i did it.
    when it comes time to remove the t-stat housing, crank the engine over by hand while shifting the timing belt away from the engine, move it over about 1/2" and that gives you just enough space to squeeze the aluminum housing out, then install the new t-stat and the o-ring, carefull that you don't pinch the o-ring or anything.
    shift the belt back over and put it all back together, re-fill the coolant and bleed out the air (theres a 5mm hex cap screw to the right of the throttle body when your looking at the car from the front)
    the B5 S4 is like the mafia... there is only one way out!
    Nov 14 2008
    NH
    Ok guys Thanks for all the input. Where is the coolant temp sensor located?If someone could tell me how to change it that would be great.
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Quote Originally Posted by will175 View Post
    I appreciate the kind words. And, yes. Our T-Stats fail in "open.'"
    Your car can still warm up. Your problem sounds exactly how mine did. If it's consistent enough, it should be throwing a DTC/CEL for (says either t-Stat or temp sensor is broken).
    Quote Originally Posted by JasonP View Post
    I'm going outside to take a picture right now.
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    I have skinny arms so I can usually reach things easier then most, so it might be easier and faster (less hand cutting) if you remove your MAF accordion hose, which is that big black ripped tube inbetween MAF and Y-Pipe.
    Nov 14 2008
    NH
    Rated S you are the best. Thanks for taking the time to take pictures and give me directions. I will let you guys know how I make out.just got to wait for the sensor to come.
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Happy I could help!
