Results 1 to 10 of 10
    Oct 06 2008
    Los Angeles, CA
    Got my tires rotated today.....
    and now when I drive it's very NOISY, and it annoys the hell outta me.
    Before I got them rotated, I had no problems and they were quiet.
    It's quite weird to me though because when I hit 80-up (even past 100) on the freeway, it's quiet again, but then right when I go under 80 it gets REALLY loud, so it's like I have to speed now cuz I can't stand the road noise.
    Anyone know what the problem might be? Alignment? I have noooo idea.
    Oct 15 2006
    From a few to one...
    Arlington, VA
    Re: Got my tires rotated today.....
    does it feel like its vibrating? if so, i'm gonna say you need an alignment...
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - Kohlefaser Luft-Technik Intake
    Oct 06 2008
    Los Angeles, CA
    ^Nope...no vibration. All noise.
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    There should be an arrow on the sidewall.
    Make sure it's pointing in the direction of travel (nose of the car).
    If it's not, then that's probably why you're hearing the noises.
    Many of the tire shops fail to even look at the sidewall and will rotate your tires in a x formation, rather than a front-rear rotation.
    If you have directional tires, the proper way to rotate is front to rear, rear to front.
    Double check every tire. That may be it. I'm 99% positive.
    GL
    Z
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Oct 06 2008
    Los Angeles, CA
    ^That was the first thing I checked before leaving the place and they were correct. I've had that happen before on my other car, so I make sure it's correct everytime I get my tires rotated now.
    That was a good idea to what the problem might have been though...thx.
    Anyone else?
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Check the tread wear on the tires... especially around the outer edge. If they are wearing down correctly, everything should be smooth. If the outer blocks of tread appear to be wavy, then that's the cause of the noise. The uneven wear could be due to multiple reasons: under/over tire inflation, alignment, tire rotation, etc. Since you have been rotating the tires, I think that can be removed from the list.
    USP CLUB MEMBER #34
    Sep 23 2006
    Houston TX
    I agree could be tread wear. When I moved my directional tires front to back, I experienced some new road noise. But I knew my alignment was slightly off and my tread was not totally even. The tires were not expensive or that great so I didn't really care to pay for another alignment to get maybe another 5-10k miles out of them.
    Jan 10 2007
    VA
    If your tires aren't wearing evenly and you rotate them the contact patch changes which can cause added road noise until the tires wear a little more. The noise shouldn't be that bad unless the tires are really unevenly worn.
    Established Member Two Rings sloweryucf's Avatar
    Feb 21 2008
    2003 A4 1.8T (sport package)
    Orlando, FL
    Tires could be cupped. Might have to give it a little bit to wear into a pattern, but the tires could be past the point of no return.
    I have some Yoko Avid H4s on stock rims that are cupped as hell and noisy as sh*t. Tires have plenty of tread on them. Gonna suck it up until they go bald. Never again go with the Yoko's though.
    GO KNIGHTS!
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Check pressures and for feathering. Feathering can make the LOUD as hell.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
