Results 1 to 19 of 19
Thread: MAP Diode?
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    MAP Diode?
    Well some of y'all have seen my block 003 logs where I am constantly having my ECU close my throttle during WOT.
    It will close down to about 60% throttle around 5300k.
    I turned the boost down today like 2 psi and it delayed the close till 5700k.
    Should I do the diode mod with the 4.7? Is that what could solve my problems?
    I hear of people using the diode because the ECU wont let them boost past a certain amount, but in my case, I am boosting perfectly fine however my throttle closes.
    -Chris
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Re: MAP Diode?
    I vote trying the diode mod since it's a cheap and reversible mod if you just toss it in there. Good for testing just to see if it works. If not, pull it out then try something else.
    Dec 05 2007
    Re: MAP Diode?
    In for this one. I came across the same thread the other day (that sparked my intrigue) and was thinking of trying that out as I am having the same issue. Hey biketsai, since there are a couple of us having the same issue with our DBW please post your resluts. I ordered new fuel filter, new air filter, and new IAT sensor to see if that can fix the issue. I will post my results on that matter. But if the diode method works, you will end up helping a lot of people out. As from what I have been told, people have yet to figure out how to fix this issue.
    I was actually thinking of replacing the MAP sensor altogether, but that is a pricey test (~$110) not knowing if it will fix it or not. I was going to do that if after what I ordered does not work.
    Edit: I remember a while back, Maxspeed said he has diodes for sale (in his sig). You might want to hit him up if you need them.
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    Re: MAP Diode?
    my maps been clamped for years at this point, i did because i was getting an EPC issue
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Jun 04 2007
    Austin/DFW, TX
    Re: MAP Diode?
    Quote Originally Posted by maxspeed View Post
    Do you have a diode for sale?
    My 5-Speed Swap DIY
    - B6 USP
    Dec 14 2005
    Re: MAP Diode?
    i dont have any at my apartment, i could send them to you when im home at thanksgiving if you feel like waiting, otherwise there on ebay for cheap
    1999 Subaru Outback
    Jun 04 2007
    Austin/DFW, TX
    Re: MAP Diode?
    Does ebay ship quick?Can you link me to one youve bought before?
    My 5-Speed Swap DIY
    - B6 USP
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: MAP Diode?
    Quote Originally Posted by biketsai View Post
    $1 for 5 too much?
    Jun 04 2007
    Austin/DFW, TX
    Re: MAP Diode?
    Thanks Mike, just put the order down.
    My 5-Speed Swap DIY
    - B6 USP
    Dec 14 2005
    Re: MAP Diode?
    1$ for 5 is waaay to much, though its not like you need 2, let alone 5, but i got 75 for 1.25 shipped lol
    1999 Subaru Outback
    Jul 07 2004
    socal
    Re: MAP Diode?
    Well most people wont sell singles and for under $3 it's not like he is wasting a huge amount of money. I would rather spend $3 then spend a shit load of timing trying to save $1-$2.
    Oct 30 2006
    B8 A4 Avant 6spd
    Re: MAP Diode?
    Since you got 5, send one my way .
    -18 718 GTS
    Dec 14 2005
    Re: MAP Diode?
    Quote Originally Posted by Militant-Grunt View Post
    uhm, you could just have your programmer write this issue right out of your ecu, we dont have the luxury, you dont need this
    1999 Subaru Outback
    Oct 30 2006
    B8 A4 Avant 6spd
    Re: MAP Diode?
    I know, I'm just busting his chops, we were talking about this on Aim
    -18 718 GTS
    Jun 04 2007
    Austin/DFW, TX
    Re: MAP Diode?
    I just installed the diode and I keep on having problems. Everytime it is connected (I tried 3 different ones,) I get a code for an implausible signal. If I clear the code, my car idles like shit, smells rich, and then dies. So for the time being I just removed it all together. What is wierd that when I did it yesterday, it didnt idle funny, but it had the codes. The diode is removed right now at the moment. I have the black line side going towards the black wire (ground) and the other side going towards the blue/grey wire. What am I doing wrong?
    Chris
    My 5-Speed Swap DIY
    - B6 USP
    Jun 04 2007
    Austin/DFW, TX
    Re: MAP Diode?
    On a side note: my car ran 100% throttle yesterday when it was installed. I was just trying to remove that code.
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    Re: MAP Diode?
    so is this a viable fix or are you still having issues?
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Jun 04 2007
    Austin/DFW, TX
    Re: MAP Diode?
    Well I just removed the diode.
    My 5-Speed Swap DIY
    - B6 USP
    Established Member Two Rings oneighty's Avatar
    Aug 30 2007
    Re: MAP Diode?
    Did you ever find a fix to your problem?
    -Jonathan
    '00 A4 1.8T K&N | InMotion Tuning | Forge004 | AutoMeter boost gauge | Eibach ProKit | ST sports | Avus S4 | 6000K HIDs
