ok.. so here's what's going on.
for about the last week my car has had an increasingly erratic idle - this has gone from a 75 or less rpm dip to such a large bounce that the car was occasionally stalling out.
this has now progressed so far (without me making any headway on what's going on ) that if i don't give the car gas it stalls... it won't idle at ALL. very very occasionally it'll idle for a couple seconds (bouncing between 400 and 1200 rpm) and then it just dies again before i can get up front and try to listen for anything strange.
also, during this time (and especially yesterday after i think *hope* i got my OBD port working) i noticed that when it would idle out the A/F was TERRIBLY rich (11.5) however during driving the car acts like absolutely NOTHING is wrong. (except the wideband is intermittently reading leaner A/F's than what i've been seeing)
same with the idling problem - it doesn't bounce or hesitate at any other rpm... just while idling.
at first i was thinking that this may be an electrical issue or that maybe one of my injectors had shit the bed.... but if that was true i don't think i'd have the rich idle A/F and i'd think my WOT A/F's would be WAY leaner than 11.9/12.1... which is as lean as it gets.
my question and only guess as to what's wrong is this:
could an exhaust leak before the turbo be enough of a problem as to fool both the primary o2 and my aftermarket wideband into thinking that the engine is running leaner than it really is, and consequently make it dump fuel trying to correct the problem and flood out the motor?
i fixed an exhaust leak (TERRIBLE) after my downpipe and before the rest of the exhaust, and noticed that i have one at my turbo to manifold gasket. i guess i could never hear the other one, or maybe it's just now totally let loose... i dont know. all i know is that in the last couple days this idle problem has just gotten terrible and i'm completely stumped. i'm going to try just tightening up the bolts to see if that helps the problem at all (the gasket will get replaced either way.. i just want to get this figured out first before i go chasing down exhaust leaks.)
FWIW - i've never had an issue with a bouncing idle before, and no lean issues since swapping fuel pumps... im just running out of things to point a finger at which can cause a lean and rich condition, bad idle, and stalling motor.
