Results 1 to 18 of 18
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    hotchkis sway bar question!
    So there is a group buy for h-sport bars right now and I am torn between the s4 kit and the rs4 kit.
    RS4:
    35mm front
    29mm adjustable rear
    S4:
    35mm front
    24mm adjustable rear
    what do you guys think would be better. I am afraid the 29mm might be too much and cause a lot of oversteer. Anyone have any experience with this?
    btw my car has eibach springs with bilstein sport shocks.
    Input please
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Re: hotchkis sway bar question!
    I think the RS4s are adjustable so, i doesn't have to have full stiffness all the time.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Sep 02 2005
    Montreal
    Quote Originally Posted by downhillracer View Post
    You're giving it too much credit... It wont.
    Dec 06 2007
    ^^exactly, we have such heavy understeer a bar twice that would barely cause us to oversteer.
    -Kirk
    BetaAlphaTau Member #58
    Aug 20 2007
    97 Jeep Wrangler
    ^^ so ur saying go with the RS4 bar?
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    I just put a hsport RS4 on!
    Aug 20 2007
    97 Jeep Wrangler
    ^^^ and how is it????!!!
    Dec 06 2007
    ^^he's got an S4 so diff story, but the issue with the hotchkis front is it will cause more understeer, this is why people only get rear.
    -Kirk
    Aug 20 2007
    97 Jeep Wrangler
    ^^ how can a front sway bar increase understeer??
    Oct 15 2006
    From a few to one...
    Arlington, VA
    Quote Originally Posted by AudiA4Turbo22 View Post
    i was under the impression that the kit with both the front and rear was far better than just the rear for h-sport.
    getting the rear only works out well when you are looking into the oem rs4 rear sway since i believe they use the same front.
    it just keeps the car balanced in terms of stiffness.
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - Kohlefaser Luft-Technik Intake
    Aug 20 2007
    97 Jeep Wrangler
    ^^ agree! So I think im gunna go with the RS4 kit
    Jun 30 2007
    Raleigh, NC
    yeahhhhhh... read the posts under the one i quoted.
    namely the one two above me.
    get the rs4 kit, im intrigued lol
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Dec 06 2007
    ^^well for like months people were saying getting a front sway is retarded etc etc etc
    -Kirk
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    I have the S4 because at the time the RS4 wasn't out yet. I've tried it with and without the kit's front bar.
    The car is more stable with less roll with the H-Sport front. Yes, the understeer is a tad greater. But the car is more predictable.
    Running the H-Sport rear with OE front, the trade off between gaining oversteer and decreasing overall stability and roll wasn't worth it.
    It just didn't feel as "balanced". That's the best way I could describe it. While I'd love to swing the back end out more, with the OE front, it seemed like the car handled differently at different speeds and off-cambers and such. With the whole kit, it's always the same regardless, and I like that reassurance.
    As such, I've switched back to the full front/rear kit and I think it handles much better.
    As mentioned, it takes a hell of lot more than that to get rid of our understeer. I'll take the stability of the entire kit, knowing that I'm not going to decrease the understeer much by using OE front anyhow.
    My 2004.5 APR Stage 3+ is SOLD
    Dec 06 2007
    ^^awesome Lee, but one question:
    does it understeer lees than stock?
    -Kirk
    Feb 28 2006
    Pittsburgh-Philly
    Oh, yeah. But remember, your suspension has a lot to do with this, too.
    Understeer can partially occur when your front end is diving from braking or cornering, as well. All that weight being shoved to that outside front corner is going to cause understeer. If you take away some of this with a better bar and good suspension, the car is more "flat" through a turn. And while the tendency is still to understeer, it isn't as bad as stock.
    Plus, I got used to it anyhow and learned to drive differently. When I want to hit the brakes, I instead floor it. Quattro FTW.
    Dec 06 2007
    Thanx Lee i'll look into both front and rear then, sounds like it makes more sense.
    -Kirk
    Aug 20 2007
    97 Jeep Wrangler
    Thanks for all the input guys! RS4 It is! I will let you know how it is when i put it on!
