Results 1 to 40 of 77
    Registered User Four Rings CTS Turbo's Avatar
    Nov 12 2008
    01 S4, 04 A4, 15 GTI, 15 S3
    Vancouver
    **Anyone interested in a K04-015 special**
    Are you looking for a bump in power and torque over the entire power band? If so then you've found the answer in the Borg Warner K04-015 and the Kinetic Motorsport 1.8T Hi-Flow Manifold.
    K04-001 Turbo - 895USD shipped
    K04-001 Turbo and install kit - 950USD shipped
    K04-001 Turbo and install kit with manifold- 1225USD shipped
    Buy Borg Warner K04-015 here
    To get free shipping or if you have any questions email us here: [email protected]
    Nov 12 2008
    Vancouver
    Re: **Anyone interested in a K04-015 special**
    All PM's replied
    Veteran Member Three Rings msharifi's Avatar
    Aug 13 2008
    Orange County Cali
    how much more HP for a stock A4 1.8T?
    Nov 12 2008
    Vancouver
    Quote Originally Posted by msharifi View Post
    The B5s came with quite a small turbo K03S, for the B6's which had the K03S I would say about 20 more HP over stock, more torque, and a wider power band.
    Nov 12 2008
    Vancouver
    PM's replied
    Active Member Two Rings JVK's Avatar
    Apr 15 2008
    Portland
    What other upgrades are needed with this Ko4; injectors and program?
    Nov 12 2008
    Vancouver
    Quote Originally Posted by JVK View Post
    Fuel injectors, software, the install kit, and you're good to go.
    We have a few sets of siemens 36lb/380cc injectos that have the same conical spray pattern as the 60lb/630cc siemens, most software upgrades for the B6 use 380cc injectors, and these ones would work great.
    Nov 12 2008
    Vancouver
    All IM's replied
    Feb 17 2005
    Sarasota, FL
    Hey Clay do you have any transverse K04's? If so shoot me a PM with pricing please!
    (this is Shawn @ Fifteen52)
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    What's the difference between the K04-001 & the K04-015?
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    Quote Originally Posted by AudiOso View Post
    001 is shaped differently (it's for the TT if i remember correctly), so it wont' fit in a B6 A4 without a good amount of custom work. 015 is the one you need.
    Waste of money putting a K04 on a B6 A4 but i'll save that argument for another thread.
    Veteran Member Four Rings Hamann's Avatar
    Oct 14 2006
    2017%20VW%20Touareg%20Executive%3B%202015%20S8
    Tampa, FL
    ahhh yes...the K04 days.
    Great upgrade for the cost guys...
    2013 S4
    Oct 14 2006
    Tampa, FL
    Quote Originally Posted by widgget View Post
    I thought it was a great upgrade for the tip...
    2013 S4
    Dec 18 2007
    nj
    Quote Originally Posted by Hamann View Post
    not at all, the TQ spike is awful for the tiptronic.
    To properly do a K04 it'll cost in the range of $2000 and you won't end up with too much difference over a chip and EFIs (i've been both, i know). for $3500 you could be into a stage 3 setup which is has a much smoother TQ band and really flys.
    of course there are situations there a K04 might be the best choice for whatever reason but i wish i had saved my money and put it into something else.
    sorry to rag on the turbos your trying to sell guys.
    Nov 12 2008
    Vancouver
    Sounds good to me, All PM's replied
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    Wow way to threadjack!! Save that for the PMs
    Good luck on the special CTS!!
    another stereotypical Audi
    Nov 12 2008
    Vancouver
    Quote Originally Posted by a4wd View Post
    Thanks
    Nov 12 2008
    Vancouver
    All PM's replied
    Dec 18 2006
    03 A4 1.8t | 04 IB M3 SMG
    Hanover, NH
    Can you go BAT on tip?
    Now: RNS-E | Debadged | GIAC 1+
    Soon: Caractere front and sides | S4 Rear | S4 Doorblades | Bi-Xenon E-Codes
    Future: GTRS BT Kit | Tip Tranny upgrade for BT Kit
    Nov 12 2008
    Vancouver
    Quote Originally Posted by 47Ronin View Post
    Why not, you can always go TIP -> 5/6spd
    Nov 12 2008
    Vancouver
    All PM's replied
    Nov 02 2007
    03 B6 1.8T TIP
    Richmond
    yes we can do BAT with TIP just with a torque converter for our tranny, but KO4 will have much less turbo lag
    "When you love somone, you let her sleep well"
    My...2005
    Coiming this Summer: VIS Carbon Trunk w/carbon lip spoiler. CF splitter...
    "The fastest B6 TIP in Richmond BC"
    Nov 12 2008
    Vancouver
    All PM's replied
    Senior Member Two Rings Alphazuzu's Avatar
    Oct 05 2008
    Holly Springs, North Carolina
    any idea how much this will put out with 380cc injectors and a stage II unitronics tune?
    Nov 12 2008
    Vancouver
    Quote Originally Posted by Alphazuzu View Post
    somewhere around 240hp/280lb-ft
    Nov 12 2008
    Vancouver
    All PM's replied
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    Fresno/Los Angeles, CA
    what is the recommended mileage to change turbo as a preventive maintenance since its my daily drive and long distance?
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Quote Originally Posted by mrbacardi35 View Post
    There is no preventative turbo swapping schedule. Just drive until it dies... which may be never. Some people have put well over 200,000 miles on the stock k03. If the turbo is failing it usually starts to whistle pretty loudly because the turbine and/or compressor gets out of balance with shaft play or has foreign object damage and the blades are bent.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Nov 12 2008
    Vancouver
    All PM's replied
    Sep 18 2006
    can i get a shipped price of the ko4-015 to 90745.
    Sep 18 2006
    Quote Originally Posted by lookaught View Post
    thanks for the info.
    Veteran Member Four Rings NightRoller USP's Avatar
    Aug 23 2008
    2008 Rs4
    So supporting mods include exhaust, software, injectors, TIP, TP and FMIC?
    Jacob
    AWE ll APIKOL ll PODI
    USPCLUBMEMBER#190
    Sep 18 2006
    Quote Originally Posted by NightRoller USP View Post
    yup, you got it, maybe clutch upgrade too
    Nov 12 2008
    Vancouver
    you could bolt it on with your stock setup, but to optimize gains those mods would be nice, injectors depend on the software you pick
    Nov 12 2008
    Vancouver
    All PM's replied
    Feb 23 2009
    2018 Tiguan (SOON)
    York, PA
    Man, wish I'd seen this 5 months ago.
    For what it's worth, I swapped out my K03S for a K04 a few months ago and ran it like that for about a month until I had time to put in 380's and get the APR K04 chip (I had a regular APR Stage 1 chip before), and noticed a difference even before I reflashed and put in bigger injectors.
    If you're not looking to spend a lot and don't want to worry about rods or anything, IMO it's a good mod to do. You can save a few hundred by installing it yourself, as long as you have the right tools.
    Veteran Member Four Rings KPC1.8TQuat's Avatar
    Mar 20 2006
    2003 A4 1.8T Quattro, 2006 Triumph Daytona 675
    North Shore, New England
    Maybe just under 200 ahwp with all supporting mods including full exhaust and a FMIC.
    Nov 12 2008
    Vancouver
    Quote Originally Posted by KPC1.8TQuat View Post
    Good numbers for AWHP
    Most 1.8T Transverse guys are in the 210-220whp range on a k04-001
    Mar 20 2006
    Quote Originally Posted by CTS Turbo View Post
    All of the dyno's I have seen for 1.8T's with k04's are under 200 awhp, with the exception of the MTM k04 setup. I think that one was just over 200 awhp. Anyway, assuming drivetrain loss of 20% (25% for triptronic owners) you're looking at maybe 250 bhp. I'd be happy with that, and it's OEM. Can't go wrong.
    Nov 12 2008
    Vancouver
    Its not all about peak power, its about powerband, and a wider torque curve.
