Results 1 to 32 of 32
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Cool AMS's gt42rs+little friend, motor
    very outside the box on this one. unforturnately they were unable to tune it in time for the Castrol Top Shop Challenge they built the motor for.
    they ended up going with a single 42rs and still won the competition. they sadly beat out 034/eurotuner for which i was really rooting for
    but must say, quite amazing. i would have gone a slight bit of a different way and led the smaller turbo's charge pipe into the IM instead of the 42rs's inlet.
    but hey, this is AMS im talking about. what do i know
    and what they ended up going with to win the competition
    made 1035hp on the engine dyno
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Nov 19 2005
    Pair of (. )( .)
    Re: AMS's gt42rs+little friend, motor
    this is def not street legal, LOL
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Senior Member Two Rings Dday216's Avatar
    Sep 10 2008
    Las Vegas
    how does that twin turbo setup work. i see the manifold running into the big turbo. but where does the small turbo get the exhaust from. and wouldnt the pressurized air from the small turbo just blow out the filter? is there a one way valve? am i missing something?
    Sep 10 2008
    Las Vegas
    ok i now see the exhaust inlet for the small turbo, but i still dont get why they send the pressurized air to the point before the big turbo.
    Sep 17 2006
    SLC, UT
    im not sure either. some type of motorized block off plate is what i assume that housing is on the inlet pipe for the 42rs.
    this is also why i would have just gone with your normal sequential twin turbo setup like the RX7 and Supra guys do. have both compressor outlets flow right into the intake manifold. it would certainly be easier from a hardware prespective. but either way tuning will be a nightmare. but nothing AMS can't handle.
    keeping my eyes peeled to see if they finish this concept here in the future
    Current:
    Previous:
    Veteran Member Four Rings audirs's Avatar
    Mar 22 2005
    Kitchener, Ontario
    insanity
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Veteran Member Four Rings chadb2434's Avatar
    Oct 07 2008
    East Texas
    wow. ^he said it!
    02 A4 3.0Q6MT
    -chad
    Jun 13 2007
    2005.5 A4 2.0T 6MT
    Leesburg, VA
    that thing is so crazy I want to see them finish it
    2000 A4 1.8TQM Ebony Pearl
    210K on the Clock and going...
    2005.5 A4 2.0T Quattro 6MT Moro Blue
    Heated seats. Winter calls.
    Future Plans
    B8.5 S5... at some point... or a Cayman.
    Sep 10 2008
    Las Vegas
    P.S Those welds are sexy!!
    Veteran Member Three Rings Jdubya's Avatar
    Apr 05 2006
    05 S4
    Dayton Ohio
    Compound charging. That's what the diesel guys are doing for big...torque.
    FI DP | FI CB | JHM IM | JHM TUNE | JHM N20 | SB STAGE III/LWFW | PORSCHE BBK | BBS CH | KONI/H&R
    Registered Member Two Rings
    Jun 19 2008
    florida
    i like it. i cant imagine the tuning issue... or still the lag time to spool that turbo... i wonder if once they hit the operating rpm range if the smaller turbo is just blocked off cause im sure it is out of its range....
    01 a4 1.8tqm, apr tip, custom intake, labree hfc, custom 3" back, apr chip, greddy oil ic, eibach pro street coilovers, GodSpeed FMIC, gauges to monitor, and a loud stereo so i dont hear any squeaks or problems plus weight to help handling lol
    Sep 17 2006
    SLC, UT
    Quote Originally Posted by Jdubya View Post
    torque. sooooo over rated
    Current:
    Previous:
    Apr 05 2006
    05 S4
    Dayton Ohio
    Guess you've never owned anything that actually had it. :)
    Veteran Member Four Rings B6driver's Avatar
    Sep 14 2006
    XBOX LIVE GAMER TAG: b6driver
    Eagle Rock, LA, Ca
    Quote Originally Posted by milehighpilot View Post
    its like a classic jdm twin turbo setup.. the small turbo is used for low-range RPMs while the larger one takes it all the way to redline. it almost looks like the smaller turbo is helping the larger one spool. lol. but even with the setup, i dont know how in the world that car is going to spool that massive turbo.
    2004 A4 1.8 Turbo 5 speed gone...
    2010 Candy White VW CC R-Line
    Active Member Four Rings
    Dec 11 2006
    Boston
    Is all of the top shop challenge info released? Link?
    Sep 17 2006
    SLC, UT
    owned no. driven a lot, yes.
    my moms Maxima(02) and my brothers titan are very torqey. they both light up the tires very easy from a stop and sometimes slow roll. but after that, it's 20mph...30....40.......50.........60......wait.... 70..........etc.
    it's just kinda an illusion on how fast it is. throws you back into your seat, but doesn't keep you there. my little 1.8t keeps you there..
    oh, and same thing with my dads souped-up F350 and that thing has like 700 ft lbs....
    Quote Originally Posted by B6driver View Post
    massive turbo? for an evo? you must be new to the Evo world.
    they made 800hp by 7000rpms. and 1035 at 9500rpms.. could have easily been taken farther and higher but they were limited to only 100 octane fuel and low boost (40-45psi rather than 55+ on c16)
    same exact turbo 034 did on their 2.3L I5 motor and the 2.0l 4g63 had a lower boost threshold by about 500rpms.. but used an equal length twin scroll manifold where as 034 didn't.
    Quote Originally Posted by deb38 View Post
    the results are in the new eurotuner. 034 had some issues on dyno day though. might have placed better than third if all went well..
    this is all i have for links though--->http://www.syntectopshop.com/
    Current:
    Previous:
    Veteran Member Four Rings Silvant's Avatar
    Feb 12 2004
    Past: 95 Stg3 UrS6 Avant, 01 Stg3 A4 Avant
    LA | CA
    Quote Originally Posted by sean1.8t View Post
    hahahahaha..........
    Mr. Inappropriate Porno Avatar Man.
    " So do us all a HUGE FAVOR silvant...STOP breathing our air..and go kill yourself...you punk POS...."
    Veteran Member Four Rings ProOnThaSnow's Avatar
    Oct 10 2006
    97 Civic HB 6266'd K24 build/1992 NA1 NSX/03 Yukon/01 F350 CC PSD
    S1 T1S R25E MT
    Quote Originally Posted by Silvant View Post
    I'm not going to lie, I was laughing also. I would classify my buddy's Duramax as torquey, putting down ~650 or whatever god awefull number of ft lbs is torque. A maxima, lol. Not VERY torquey.
    "There should be a few 'woman free' days when men can take to the streets without the fear that some female, all hopped up on estrogen and bitterness, is going to put their life or property in danger..." - $4c@b
    Sep 17 2006
    SLC, UT
    Quote Originally Posted by ProOnThaSnow View Post
    did you read the line about my dads F350?
    and torque is a relative term. as is horsepower.
    it was a scenario of which the car has much more torque than horsepower. and what the care feels like.
    but i guess it's over your head.
    oh, and go drive a 02+ maxima. you'd be suprised
    Current:
    Previous:
    Veteran Member Four Rings Howard Hughes's Avatar
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    Sequential?
    789whp
    Active Member Three Rings
    Dec 10 2004
    Seattle WA
    Horsepower sells cars... torque wins races.
    Mar 30 2004
    jersey
    my evo is pretty torquey. Bolt ons, stock cams, and pump gas.
    made around 350whp/350wtq. at the weight of sub 3000 it moves out. I guess you need some torque to light up these 255s.
    http://www.youtube.com/watch?v=aGg1mGfs9uY
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Quote Originally Posted by ROUGHEDGES View Post
    Dude I could do that with my last turbo making like 300whp/300wtq spinning 19s
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Sep 17 2006
    SLC, UT
    Quote Originally Posted by B528QM View Post
    that's actually false.
    torque is what keeps you at that constant 5mph in the pit area's.
    hp is when you are flying at 7k+ rpms on the track reaching for redline.
    think about it. a racecars's(or any internal combustion) motor makes peak tq between 2000 and 5000rpms depending on motor and components. when do you ever see a racecar on the track at below 5000rpms?
    answer, never
    Current:
    Previous:
    Mar 30 2004
    jersey
    Quote Originally Posted by A4 TSCHUSS View Post
    the 30r b5?
    Apr 24 2005
    E55 AMG, CTS-V
    no my b6 with the gtrs on stock 1.8t engine running 93 octane and meth injection at 20psi which dynoed 301whp 300wtq on a mustang dyno.
    My car is now the 2.0 stuff. That B5 in my sig which im assuming you are asking about is a friends car I drove. Stock 1.8t AEB with a ATP 3071r kit with tapp tuning. Havent got a chance to run mine at the track again since the engine/turbo upgrade
    ~David~
    CTS-V 9.6@148
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    holly shit, is that like a turbo for the turbo?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Mar 30 2004
    jersey
    on the launches with the evo i have to backpeddle off the throttle to reduce spin. I had a s4 with xr chip running vp103, dps, catback, no cats, custom intake, ported and polished intake mani and heads, rs4 clutch and about 200 lbs in weight reduction. It didnt spin them close to the evo out of the whole.
    Apr 24 2005
    E55 AMG, CTS-V
    Who knows, evo is hundreds of pounds lighter than S4 though. I could leave like 20' of black marks on the road with my car. Now it is easier but I have a descent amount more power too.
    ~David~
    CTS-V 9.6@148
    Apr 05 2006
    05 S4
    Dayton Ohio
    Then someone should go tell that Carrol Shelby guy he's full of sh*t. He obviously doesn't know as much about racing as you.
    He's the one that "coined" that phrase.
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    so AMS > Buscher Racing? true?
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Sep 17 2006
    SLC, UT
    Quote Originally Posted by Maverick View Post
    hard to say. both have acomplished amazing things.
    but if you go off of peak whp and track numbers, AMS > all
    Current:
    Previous:
