Results 1 to 40 of 61
Thread: Gt28R problems
    Sep 04 2008
    p
    Gt28R problems
    The car doesnt pass 3.5k rpm, before it runs completely out of fuel making the spark plugs go white. The car can go beyond this rpms but with a big missfire.
    Veteran Member Four Rings A4TUNE's Avatar
    Sep 14 2006
    Mass
    Re: Gt28R problems
    wrong injectors? why not call AWE or the shop who installed it?
    -Max
    2004 A4 1.8T M6 Quattro Ultrasport
    REVO Stage 1 | AWE Boost Gauge | Carbonio CAI | Valeo Single Xenon Black Ecodes | RS4 Rear Sway Bar | 18x8 OZ Superleggera | DTH USP Splitter
    Sep 04 2008
    p
    Re: Gt28R problems
    it has the injectors that come with the kit, everything else is fine, checked 100 times.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: Gt28R problems
    Did they flash your existing ECU?
    If not, is the ECU they gave you the same p/n as the one that came in your car?
    Might want to talk to Tom/A.W.E. He is a member on here and I'm sure he will treat you right..
    -Doug
    Sep 04 2008
    p
    Re: Gt28R problems
    Offcourse they will help, but its to late to call and i was just trying to see if someone had an idea so the car could work.
    They flashed my current ECU.
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Re: Gt28R problems
    check timing if you can. Mine did the same thing and I was running to much timing and the ECU didnt like it and was cutting at 3.5k RPMs
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Sep 04 2008
    p
    Re: Gt28R problems
    how did you fix it? with lemiwings?
    Sep 04 2008
    p
    Re: Gt28R problems
    OK so i just read this http://www.audizine.com/forum/showth...light=missfire
    his car was doing more or less what my car is doing, difference is that he says his spark plugs where accumulating carbon and mines are going completely white.
    how can i know if i also have to change coilpacks and ecu like he did?
    Thanks
    Sep 04 2008
    p
    Re: Gt28R problems
    Fault codes after scan
    Address 08: Auto HVAC Labels: 8E0-820-043.LBL
    Part No: 8E0 820 043 H
    Component: A4 Klimaautomat 1016
    Coding: 00000
    Shop #: WSC 63351
    5 Faults Found:
    01809 - Actuating Motor for Temperature Flap; Left (V158)
    41-10 - Blocked or No Voltage - Intermittent
    01274 - Air Flow Flap Positioning Motor (V71)
    41-00 - Blocked or No Voltage
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
    30-10 - Open or Short to Plus - Intermittent
    00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
    00532 - Supply Voltage B+
    53-10 - Supply Voltage Too Low - Intermittent
    ANYONE???
    Sep 04 2008
    p
    Re: Gt28R problems
    143 views... 3 answers?
    To make it a little clearer.. my car has NO faults in the engine, electronics or abs. But it doesnt get enough fuel, so everytime i accelerate and it feels like boost is coming starts to fail...
    Sep 04 2008
    p
    Re: Gt28R problems
    for all the "magazine" mechanics around this forum. It was the fuel pump.
    So if anyone in the future have a similar case, can know where to start from.
    Mar 31 2004
    CA
    Re: Gt28R problems
    Quote Originally Posted by msr1 View Post
    glad you got it fixed... sorry I posted earlier and came back today and saw it was the fuel pump.
    to be honest though... it could have been a million things and you can't always expect people across the internet to know it with out proper diagnoses.
    glad you got it fixed though man...
    Sep 04 2008
    p
    Re: Gt28R problems
    Thanks. I know what you are saying but i even got pm's sayin it was the software....
    Mar 31 2004
    CA
    Re: Gt28R problems
    yea, thats a big assumption to go right to software. ahha
    Sep 04 2008
    p
    Re: Gt28R problems
    well my engine blew, dont know why
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: Gt28R problems
    lack of fuel....maybe you bent valves? Be interested to see what failed on the motor. Sorry this happened to you though. Sucks for sure...
    May 24 2007
    Southern California
    Re: Gt28R problems
    bummer.
    Kyle
    2.0L Revo GTRS Eliminator
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: Gt28R problems
    After fixing the fuel pump? Care to elaborate?
    -Doug
    Buncha motorcycles
    Memphis, TN
    Re: Gt28R problems
    no one here is a car mind reader. you said it was running and driving just not going past 3.5k. when my fuel pump failed it went completely and wouldnt run period. others who have had fuel pumps fail have the exact same symptoms as me.
    glad u fixed it
    APR Stage 2/AWE Intake
    Mar 31 2004
    CA
    Re: Gt28R problems
    Holly Shit.. earlier today I check back and your good and fixed... now I check back and it blew?
    I am really curious for exact details, pics etc on what exactly happen to the motor.
    Hang in there man.
    Sep 04 2008
    p
    Re: Gt28R problems
    Dont know what happened, started sounding like a diesel engine and it shot off. I think it popped a rod. I will open it in a few hours and will know what the damage is.
    After waiting 2 months for a flash, and having for 5 days a problem. The car started running fine last night. I drove the car with the kit maybe 10 miles, and maybe accelerated 1/2 a mile. And now a blown engine.
    When you where driving in 1st gear and pushed the gas the car had trouble to light up the tires, it wasn't fast at all, if the car runs like this when ive fixed it. it will be a huge disappointment for $5k on a kit, that is not that far from my previous car with a $30 mbc and ebay testpipe.
    Buncha motorcycles
    Memphis, TN
    Re: Gt28R problems
    so how many gt28r kits have blown motors now?
    Sep 04 2008
    p
    Re: Gt28R problems
    Quote Originally Posted by Papachristou View Post
    This is a real ignorant comment, since you dont know what has made those engines to blow. Ive heard the storys...
    My car had a diferent problem... that wasnt the kit either the turbo.
    Aug 26 2005
    Re: Gt28R problems
    For future reference, when the symptoms/evidence is that there is not enough fuel as you suspected, do a fuel pressure test. The fuel pressure/pump isn't monitored by the ECU, so there won't be any fault codes for a bad pump or low fuel pressure.
    Sorry to hear of the bigger problems, any details yet?
    Sep 04 2008
    p
    Re: Gt28R problems
    Te oil pump broked. The exhaust cam is grinded as the head as well. Will take the engine down in about 2 hours and will let you know about damages in the block and how many valves are bent.
    What happened was that the intake cam stucked, so when the timing belt continued running broke the lip thats inside of the cam gear wich made the car go out of timing and the engine stoped.
    I need a head my car is BFB heard that the best is AEB, if someone has one shoot me an offer.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: Gt28R problems
    So, sounds like the oil pump broke and starved the head of oil causing an intake valve to die and the cams to excessively wear?
    If I were you, I would replace the internals in the bottom end too. Who knows how much they were starved of oil as well.
    A tear-down and inspection will yield further results and confirm any suspicisons. Best of luck. I am sorry to hear of this issue. It is no fun, esp after just getting your new turbo kit onto the car and running.
    -Doug
    Sep 04 2008
    p
    Re: Gt28R problems
    It really sucks. I saw my turbo today and the inlet had oil and the turbo outlet had lots of oil in all the outlet tubes and some on the intercooler. I imagine that my turbo isnt good.
    I have pics but dont know how tu upload.
    Veteran Member Four Rings QuattroRocket's Avatar
    Sep 01 2004
    2103 S4, 2014 Nissan Pathfinder
    Vancouver Canada
    Re: Gt28R problems
    Jeez sorry to hear your troubles man. My Gt28r kit runs like a freight train (well ok compared to McHammereds setup its a little train but its mine !). I have about 6000 miles on my GT28r and am loving every minute.
    Gone but not forgotten : 2000 A4, 2002 A4, 2004 A4, 2013 S4 Premium, 2013 Q7, 2017 SQ5 Dynamic Edition
    Current Audi : 2017 RS7
    May 24 2007
    Southern California
    Re: Gt28R problems
    mine was a champ too. but i think its days are over now that im going 2.0
    sorry to hear.
    Kyle
    Sep 04 2008
    p
    Re: Gt28R problems
    Quote Originally Posted by QuattroRocket View Post
    wich kit do you have and how manys hps?
    I would really like to hear your opinions about that turbo, truth is that my car felt like a k04 upgrade. I would like to know to what cars you could compare yours power wise or that you have raced against...
    They say a gt28r could beat an e46 m3,,, as my car felt i doubt it, as i doubt the 300hp the kit offers.
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Re: Gt28R problems
    Well you didnt really get it running for long in the high rpms where these kits shine.
    IE is having a sale right now on their piston/rod combos, just so you know. They have multiple options based on what you end up doing to the bottom end.
    Sorry to hear the bad news... so is life sometimes when you put lots of mods on cars.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Sep 04 2008
    p
    Re: Gt28R problems
    Quote Originally Posted by lookaught View Post
    This is true, the car had difficulty to get to the 7000+rpm, so i was shifting at about 6.5krpms.
    Someone here knows if you can put and adjustable fuel pressure regulator on this cars.
    Thanks
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: Gt28R problems
    Thanks
    The B6 fuel filter contains the FPR. So, you can not install an adjustable FPR unless you retrofit a different fuel filter with a separate FPR. If you go that route you might as well get a return style fuel rail (like the B5) and use the FPR up there. Then run a separate return fuel line back to the tank and a B5 style fuel filter.
    However, If you are sticking with the AWE GT28R kit you should not need to touch your stock B6 fuel system. The stock fueling system is more than capable for that turbo kit.
    -Doug
    Sep 04 2008
    p
    Re: Gt28R problems
    Will those B5 parts fit my B6? I was asking so in the future if i want to run more boost, i can adjust gas as i raise boost watching a wideband gauge.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: Gt28R problems
    You can probably get them to fit but you won't be exceeding the fuel system capabilities with a GT28R even on higher boost.
    -Doug
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Re: Gt28R problems
    The B6 is different from B5 although anything is possible given the money. O34Motorsports I think has the parts for the conversion.
    The B6 controls fueling with the ECU, injector size, pulse-width, etc.
    There is a little bit more to increasing power than just boost & fuel. Most people are saving up to just pick a turbo, build their engine/buy parts, & get the software/tuning for their needs... gud luk
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Mar 31 2004
    CA
    Re: Gt28R problems
    reminds me of back in the day when I had my Honda. We were in such a hurry when swapping my cams, we put the cam towers in backwards and blocked the oil passage.
    about 20 mins of driving the cams seized up from oil starvation.
    sorry to hear about this man... it is always a pain in the ass when modding and doing BAT but hang in there and dont let it shut ya down.
    tear that bitch down and check everything.
    Sep 04 2008
    p
    Re: Gt28R problems
    How much boost do you think the gt28r can handle? The GIAC software makes it boost 20psi, do you think 5 more is possible?
    p.s. http://cgi.ebay.com/ebaymotors/OBX-E...ayphotohosting
    That manifold looks interesting, someone here has tested it or know something about its efficiency?
    Sep 01 2004
    Vancouver Canada
    Re: Gt28R problems
    I havent dyno'ed the car yet, will do so early spring when I go in for my tubular exhaust manifold and I will get back to back dynos to see the results of adding the mani.
    I have been in K04 cars and this is no K04. The boost is far less "spikey" and pulls further to the red line than a K04 which suffers from a rather short boost curve like the K03 does.
    The story suggests that the original GT28r setup is what ran a 300hp dyno and since then GIAC and AWE found that the tuning on the kit was too aggressive for stock bottoms so they detuned the software. I would be surprised to see 300hp with this kit. I am going on the dyno hoping for 220+ wheel hp which would roughly translate to 275-285 hp at the crank. I am hoping that with the custom manifold (as well as the other supporting mods I already have) I will see the 300/300 that the AWE dyno suggests.
    Oh and ... I dont street race No kills.
