Results 1 to 10 of 10
    Established Member Two Rings MacTiki's Avatar
    May 01 2008
    Imola 04 S4
    Sacramento Area
    Clutch replacement in Sac-Town area...
    I want to avoid the Stealerships; Niello and Elk Grove both quoted over 3K!
    04 S4 42K on her
    Anyone recommend a good independent shop in the area?
    Thanks in advance...
    Tiki
    Nov 19 2005
    Pair of (. )( .)
    Re: Clutch replacement in Sac-Town area...
    JHM, 034, streetwerke....
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Veteran Member Four Rings DoThisMyWay's Avatar
    Aug 24 2004
    B9Q5
    Honolulu, HI
    Call 2Bennett in Davis.
    Current:
    2024|A5 SB PP+ S-line, 2019|Q5
    Previous:
    2017|S3, 2016|A4 2.0T Quattro, 2006|A4 Avant 2.0T Quattro S-line, 2005|A4 3.0 Quattro UltraSport
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    If your gonna head all the way to Fremont or just the bay area...use East Country European Autoworks in Brentwood. /thread
    another stereotypical Audi
    Veteran Member Three Rings A4Avant02's Avatar
    Feb 05 2008
    '02 A4 Avant, '74 Triumph TR 6
    Folsom, Cal
    In Sacramento try IPB Autosport: http://ipb-autosport.com/
    In Davis try 2Bennett: http://www.2bennett.com/
    In Roseville try Bertini's German Motors: http://www.bertinis.com/
    May 01 2008
    Imola 04 S4
    Sacramento Area
    Got a hold of Andrew at 2Bennet...
    Sounds like there who I'm gonna go with!
    Thanks for the help.
    Tiki
    Veteran Member Three Rings dak360rt's Avatar
    Apr 17 2008
    Sacramento, Ca
    If you dont mind what did 2Bennett quote you for labor?
    Light Silver Metallic - 2001.5 S4 - APR Stage 2+
    Piggy Pipes --- CC Mod --- Darintake --- Samco TBB
    AWE Boost Gauge --- 1 touch rear windows up
    JHM Weighted Shift Knob --- JHM Solid Short Throw Shifter --- Custom Straight Pipes
    May 01 2008
    Imola 04 S4
    Sacramento Area
    11 hours at 95 an hour...
    More than I wanted to spend but I'm going to have them do some other work while its there,
    Tiki
    Apr 17 2008
    Sacramento, Ca
    Did you check with JHM, they had the best install price ive seen on DPs (aside from DIY)
    2B is a really good shop though
    Senior Member Two Rings danielt's Avatar
    Oct 09 2007
    Black B7 A4 2.0TQ
    Frisco / Sac / Reno
    2bennett is a great shop, quite expensive though. But not as much as stealership.
